Question about T-Mobile Dash Smartphone
Reset + gather my info??
Ok.. my second dash phone.. same problem.. the whole reset era.. wont start up.. whatever.. is there ANY WAY that i can revocver my media and phone numbers from it, before i reset it?
After i enter my simcard pin number, it freezes.. i think its because of the theme or application i put on my dash... please kindly help me with this
Posted on Oct 03, 2008
How do I reset the blu dash jr 4.ok
press the home key, volume key, and power key hold for 10-15 seconds, when screen changes only release power key and continue holding volume key and home key. A menu will appear on your screen just follow instructions to do a reset. Good luck
Feb 18, 2015 | Blu Dash Jr 4.0 K Cell Phone
Where can I buy tps alone and not the whole assembly for my 2002 Honda blackbird
Look for similar models that came out with the same injector housing, csmnl is good for comparing what part can be used off various models and makes. then search e--y with the info gathered then swap tps and reset with your ecu procedure, again search web for info.
Nov 25, 2014 | Honda Motorcycles
How to reset immobiliser
What vehicle are we talking about here need more info??
Aug 28, 2014 | Cars & Trucks
How do you reset the change oil indicator light on the dash
most unt key on run engine off
depress fuel pedal 3 times to floor withine 5 second
then start engine should reset oil life
there may also be an info button in dash panel
if so use and scroll true menu to reset
owner manual shoul also explain how to
Mar 31, 2011 | 2007 Saturn ION-2 Quad Coupe
Mobile loss some internet machine code drivers
ok, follow this steps, this will reset your phone to what it used to be before you messed with it. SAVE ALL YOUR INFO, VIDS, N PICS:
1. Select Start
2. Select Accessories
3. Clear Storage
4. Type in 1234
5. Select Yes
Second Option> Hard Reboot:
How to Hard Reset a T-Mobile Dash and HTCS620 without the operating system:
Turn the handheld off, hold the two soft keys (the dashes to the left and right of the phone buttons) hold the power button for 1-2 seconds and then release the soft keys. It should prompt you to clear storage. The “send" button which is considered as the green phone button.
hope it works
May 18, 2010 | HTC S620 Smartphone
I have a Passat TDI 140 SE saloon '06 plate, the MPG readout on the dash is playing up, it's showing random numbers constantly anywhere between 30 MPG to 170 MPG ( I wish haha) then seem's to reset (3...
The info that is gatthered on your display is taken from the engine ecu which is calculating average mpg, average distance, how many miles left in your tank etc. The only faulty part is your dash insert (speedo clocks). As you probably gather all the info is gathered electronically,from your throttle movement to the altitude of the vehicle which along with many other statistics is calculating your mpg, it wont be your ecu or would experience more seroius problems, so I am betting on your dash clocks,but get it diagnosed before spending money, hope this helps.
Mar 22, 2010 | 2007 Volkswagen Passat Sedan
Phone lock forgot my gmail account
  1. "turn off the G1
  2. Hold Home Key + End key for 20 seconds or until you see a "triangle with an exclamation point and a picture of the G1"
  3. Open the QWERTY keyboard and hit Alt+W
  4. Restored! "
Info gathered from
http://www.androidcentral.com/factory-reset-tmobile-g1
Aug 22, 2009 | HTC G1
Lost voicemail on phone system Norstar T7316E
So, voicemail does not pick up or answer at all?
Nov 19, 2008 | NorStar T7316E Corded Phone
Tmobile dash frozen on WINDOWS(DIRECT TOUCH TECHNOLOGY SCREEN)
do a sw reset....its possible it was damaged when it was dropped in the water, but not likey....
turn the phone off, press and hold the soft keys (buttons with the lines on them above the home key and back arrow key) and hold it down.....press the power button while you are doing that until the white t-mobile screen will come on, then instead of going to the green windows mobile screen, a black screen with white writing......press the green button....it will get you in your phone but it will erase your info as a result....
Nov 23, 2007 | T-Mobile Dash Smartphone
T-Mobile Dash Smartphone Logo
Top T-Mobile Computers & Internet Experts
Computer Repairing
Computer Repairing
Martin Murray
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
