Question about Technics SL-MC4 61-Disc CD Changer
Small cable with spring attached not attached to unit
One end of the cable is attached to the inner sheetmetal wall using orange RTV. The other end that has the spring attached to it is not attached to anything. Where should I attach the spring/cable and how should it be routed? I can see 4 rollers on the front of the CD drive that look like they serve no purpose unless the cable rides along the 4 rollers. If that is true, I still don't know where to attach the spring, which is attached to the cable. Can you help?
  • av8trqa Oct 08, 2008
    I figured out the problem and you are right! It took a while to figure out but, the CD changer works great now. Thank you very much!
The cable does run acroos those 4 rollers on the CD drive unit. The cable is staticly attached on the right side (unit facing you) of the carrier rack, routes under the lower rifght roller, up and outside of the top right roller, across and outside the top left roller, then down and inside the lower left roller.
From there, it routes across the carrier to a small hook (black plastic). Under that hook and then up to the spring.
I can send pictures if you need them. I have this same unit with a carrier that will not fully eject the CDs. I have been in this case more than once.
Posted on Oct 07, 2008
How do i drop mower deck.
Hi James:
I don't know what machine you are using, but the deck on my craftsman will hopefully be similar.
The engage cable has two parts, an inner "slider", and an outer "sheath".
- The outer part is connected to the deck by a simple plastic fitting that has a tab that retains it. All you need to do is compress the tab and slide the entire fitting towards the "sheath" direction far enough to allow the inner cable to slide through the slot in the mounting bracket. Sounds complicated but it won't be when you look at it. A pair of long nosed pliers should work to compress the tab.
- The inner cable has a spring on the end, and the spring is attached to a hole in the idler pulley bracket.
Hope this helps.
Reply by comment to let me know.
Jul 16, 2015 | Garden
50s 1
Remove the blade, and you will normally see a hole in a lug on the inner ring of the guard and a slot with a bar across it on the upper inside of the fixed guard. Either end of the spring will hook through these. Sometimes (normally on DeWalt) the springs will be attached with a small self tapping screw with a washer at either end.
Apr 25, 2013 | Saws
I have a 1995 jeep cherokee straight six or 4.0 liter where is the radiator thermosta soo i can replace it
Hi, It is actually called an engine thermostat, as it regulates coolant flow through the engine. If you follow the top large hose coming off the radiator to where it connects onto the engine, you will find a housing there connected to the engine with 2 bolts. There may be another hose connected to this housing also. You will lose a bit of coolant when doing this, so use a bunch of rags under the work area and a catch pan beneath the vehicle.
Parts needed: Thermostat, gasket, tube of black RTV sealant, new clamps for hoses if they look rusty or do not have good resistance on removal. (for factory spring type clamps)
Procedure:
Remove hoses from housing and bend back and tape back out of the way (use some cable ties if you wish) to keep coolant from running everywhere and so they are out of your work area. Remove 2 bolts holding the thermostat housing to engine. Gently tap housing with rubber hammer to break the gasket seal on housing. Once housing is off, you will find the thermostat underneath. Remove thermostat from engine. Clean the housing and engine mating sufaces of all traces of gasket material. Surfaces must be clean and dry before re-assembly. Use a rag to soak some coolant out of engine side hole to facilitate cleanup. Scrape off gasket material and use brake cleaner to wipe off residue and dry with clean shop rag. There are 2 types of thermostats for the jeeps, one has a rubber seal around the thermostat, and requires no other gasket, the other has no seal and requires a separate paper type gasket to be sealed to the mating surfaces. I believe the straight 6 has the paper type. Install thermostat with spring end into engine cavity. Put a thin even coating of black RTV sealant on the engine mating surface. Place gasket on RTV coated surface, aligning the bolts holes to holes in gasket. Apply thin even coat of black RTV sealant to thermostat housing mating surface. Put a small amount of RTV sealant on threads of bolts (clean them first) coating the entire thread. Put housing onto engine and install bolts finger tight - firmly seated. Allow RTV to cure for 5 minutes. Some RTV will squish out, thats OK, but use the RTV as a THIN EVEN coat, as you dont want a bunch of excess sealant in the thermostat cavity. Torque bolts to 16-20 ft. lbs. or a good wrist tightening. DO NOT overtorque, as you will either crack the housing, or cause warpage making your gasket leak. Re-install hoses and tighten clamps. If spring type clamps were on the hoses, replace the small clamp with a band type clamp. If large clamp installs tightly, it can be reused. If it was rusty and goes on rather easily/weakly - replace with a band type clamp. Refill - check coolant level, add as needed. Start engine, allow to reach operating temperature and check for leaks. Done!
Please rate this answer! Thanks, Mike
Jun 20, 2011 | 1995 Jeep Grand Cherokee
Unclear as to how you adjust the rubber band strap
  1. Remove the deployant clasp from the watchband. The clasp is attached using spring bars on each end of the clasp. The method of spring bar removal varies but is usually performed by pushing a small pointed tool (one end of a spring bar tool) into a hole at the end of the clasp. While depressing the spring rod, pull the buckle away from the bracelet to detach. Repeat this for both sides of the buckle.
  2. Step 2 Measure the watchband to determine proper sizing. Use the scissors to cut along the inner grooves to remove needed sections (each section of the rubber will contain a new set of holes for the bracelet spring bars). Cut carefully and conservatively, as this step cannot be undone.
  3. Step 3 Reattach the buckle to the band after resizing. Reverse Step 1, pushing the spring bar in while sliding the buckle back into place.
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
Aug 16, 2010 | Tissot T Race Case Stainlesssteel carbon...
I'm trying to remove the coil spring on a 1981 AMC concord. Is the retaining bolts on the lower spring spindle permanate or do they come out? I collapsed the coil but can't slide the lower spring seat out...
This is for the lower control arm:
NOTE The inner end of the lower control arm is attached to a removable crossmember. The outer end is attached to the steering knuckle pin and ball joint assembly.
  1. Jack up the car and support it on axle stands under the subframes.
  2. Remove the brake drum or caliper and rotor from the spindle.
  3. Disconnect the steering arm from the knuckle pin.
  4. Remove the lower ball joint stud cotter pin and nut.
  5. Separate the ball joint from the knuckle pin using a ball joint removal tool.
  6. Disconnect the sway bar from the control arm.
  7. Unbolt the strut rod.
  8. Remove the inner pivot bolt and the control arm. To install:
  9. Reverse the removal procedure; do not tighten inner pivot bolt until car weight is on wheels. Tighten ball joint retaining nut to 40 ft. lbs. through 1976, 75 ft. lbs. thereafter, strut rod bolts to 75 ft. lbs., sway bar bolts to 8 ft. lbs., steering arm bolts to 65 ft. lbs. through 1979, 55 ft. lbs. thereafter, and control arm inner pivot bolt to 95 ft. lbs. through 1976, 110 ft. lbs. thereafter.
This is for the coil spring.....see if maybe you missed a step in here:
  1. Remove the shock absorber.
  2. Install a spring compressor through the upper spring seat opening and bolt it to the lower spring seat using the lower shock absorber mounting holes.
  3. Remove the lower spring seat pivot retaining nuts, then tighten the compressor tool to compress the spring about 1" (25.4mm).
  4. Jack up the front of the car and support it on axle stands at the subframe (allowing the control arms to hang free).
  5. Remove the front wheel and pull the lower spring seat out away from the car, then slowly release the spring tension and remove the coil spring and lower spring seat. To install:
  6. Place the spring compressor through the coil spring and tape the rubber spring cushion to the small diameter end of the spring (upper).
  7. Place the lower spring seat against the spring with the end of the coil against the formed shoulder in the seat. The shoulder and coil end face inwards, toward the engine, when the spring is installed.
  8. Place the spring up against the upper seat, then align the lower spring seat pivot so that the retaining studs will enter the holes in the upper control arm.
  9. Compress the coil spring and install the spring.
  10. Then install the wheel and tire and lower the car to the floor (to place weight on suspension).
  11. Install and tighten lower spring seat spindle retaining nuts and tighten them to 35 ft. lbs.
  12. Remove the spring compressor and install the shock absorber.
Nov 03, 2009 | 1983 AMC American Motors Concord
Starter recoil spring attachment. It clips into the cover at one end but I cannot see how it attaches to the hub of the pulling wheel
An IPL for a Oct 2004 455 can be found here:
http://weborder.husqvarna.com/order_static/doc/usa/2004/I04000/I0401113.pdf
There as a starter detail page but it may not answer your question.
I bend the inner portion of the recoil spring until the center hub can engage the retaining device located on the inner end. The inner end of the spring passes through the hub and a small ring retainer and spring tension keeps it in place. You will need about 2 revolutions against the spring for the recoil to operate properly. HTH
Lou
Oct 05, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Problem going from jack to switch
can i know what's the length of youre cable ?
Aug 24, 2008 | Leviton (102-5G108-RW5)
Ethernet cable
568-B Wiring
Pair Wires RJ-45 pins
1-White/Blue White/Blue 5
Blue/White 4
2-Wht./Orange White/Orange 1
Orange White 2
3-White/Green White/Green 3
Green/White 6
4-White/Brown White/Brown 7
Brown/White 8
568-A Wiring
Blue/White 4
2-White/Green White/Green 1
Green/White 2
3-White/Orange White/Orange 3
Orange/White 6
Brown/White 8
RJ-45 Pins are with the spring tab down and read left to right. Do you have an RJ-45 Crimping tool?
Just use 568-B or 568-A on both ends of the same cable.
Jul 05, 2008 | Computers & Internet
Technics SL-MC4 61-Disc CD Changer Logo
284 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
