Question about Toshiba CF32F50 TV
Toshiba cf32c50 tv will not turn on
When i plug in tv their is a relay click and power up sound
when i push on/off switch again relay click and power up sound with no picture or sound
it seems to shutts down righaway
what do you think is the problem?
  • Toshiba Master
  • 5,568 Answers
This is a typical condition if the power supply has failed or a power-consuming circuit the supply services has exceeded a predetermined current draw. The relay you hear is preventing further damage or even fire.
You will need local tech help with this.
Posted on Sep 29, 2008
Toshiba 32A41 32" TV - I turned the TV off at the power switch on the front of the TV. The solid red LED turned off as it has for 12 years. NOW, neither the remote nor the power switch on the front of
Sounds like the power supply is down mate unless it's just a fuse replacement it's probably more cost effective to buy a new one.you could try gumtree or eBay for one with a damaged screen.
Dec 01, 2014 | Toshiba Televison & Video
I have a Toshiba tv model cf32c50 I have no sound I checked external speaker jacks and still no sound when I push volume button it appears on the screen and shows the volume increasing and still no sound.
check circuit board for contamination. looks like white powder. if there is, clean with alcohol let dry. before plug set backin. if you can't fix you can use a stereo to get your sound thur.just hook up your cable box or what ever through the audio video jacks on box to audio in aux. jacks on the back of srereo
Oct 02, 2013 | Toshiba Televison & Video
Toshiba tv, model cf32c50 has a garbled sound issue.
distorted sound sometimes accompanied by buzzing is caused by detuned circuit in the SIF amplifier and sound detector circuit. a distorted sound alone is caused by a breakdown in AF amplifier circuit so try to change the sound ic since its the only options left. good luck!
Jul 27, 2010 | Toshiba Televison & Video
Red light flashes on power switch, but no picture or sound on tv
tv will not power on. red light on switch blinks. power relay clicks, but no picture or sound.
Jul 28, 2009 | Toshiba DVD Recorder AND Series2 TiVo...
No picture on my philips 42PF7321D/37
Bad caps in the power supply must be replaced .
Jul 21, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Power problems problem on
I would try a power drain:  Unplug the TV's power cable so the TV is not grounded to the house.  Then press and hold in the TV's own power button for one minute to drain the capacitors. Plug the TV back in and see what happens.  If the TV will still not turn on, I would say you have a problem with the TV's mainboard as a dead power supply will not light any LED's for you.
Mar 24, 2009 | Toshiba CN36X81 TV
TP55Hwon't turn on, after unplugging, click and red light flashes
I HAVE THE SAME PROBLEM ,I FOUND OUT AFTER OBSERVING FOR QUITE SOMETIME THAT THE CLICKING NOISE I HERE AFTER PLUGGING IT TO THE OUTLET CAME FROM A RELAY SWITCH LOCATED ON THE POWER BOARD AFTER TAPPING ON IT THE SET WOULD POWER AND THE BLINKING RED LIGHT GOES TO NORMAL..I BELIEVE THIS RELAY IS CAUSING THIS PROBLEM FOR ALL THE FELLOWS OUT THERE WITH THIS TV SET AND THE BLINKING RED LIGHT..IN MY CASE THE RELAY WENT SO BAD NOW THAT THE COIL THAT MAGNETIZES TO CLOSE THE CIRCUIT GAVE UP ,SO I PULLED THE COVER OF THE RELAY TO UNVEIL THE TWO METAL STRPS THAT COME IN CONTACT AND HAVE BENT ONE SLITELY TO REMANE CLOSE THIS POWERS THE TV UP NORMAL BUT IN ORDER TO SHUT IT DOWN I HAVE TO PULL THE OUTLET. THIS IS TEMPORARY UNTIL I CAN FIND WHERE TO GET RELAY SWITCH. PLEASE DONT TAKE MY RESEARCH AS A SOLUTION BUT FOR WHAT EVER ITS WORTH. I WILL GET THIS UP AND RUNNING AGAIN ITS ALL WORTH EVERY DOLLAR TO FIX.
Nov 18, 2008 | Toshiba TP55H60 55" Rear Projection...
Toshiba tv will not turn on
I have a toshiba tv and it will not turn on. There is a flashing green light that comes on, but there is no picture or sound.
Oct 31, 2008 | Toshiba DVD Recorder AND Series2 TiVo...
Won't turn on - relay clicks, power supply squeals, relay clicks, etc,
need check B+, standby power supply, and Horizontal defletion and components
Oct 23, 2008 | Zenith C34W37 34" TV
Theatre View Toshiba Rear Projection TV 50 Inch with no sound or picture and a red light keeps blinking
I have the sames t.v you have to go in the back flip the power cord switch...then reboot the t.v.
Jun 27, 2008 | Televison & Video
Televison & Video Logo
277 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
