Question about Brother Office Equipment & Supplies
Each time i fire up my dcp130-c i get a copy of a receipt i received ex internet ex asb which i printed off . it is not in the queue and nothing showing where it is lurking . how can i get rid of it ?? cheers john
Don't know ... oh dear !!. so sad too bad ..
Posted on Sep 29, 2008
HP LaserJet 4100 for all applications in windows 7. When I go to print a document and click on print. The print screen exits, the print job doesn't processes, and the print queue stays empty. Noth
Ideas? Yes. I had this happen on an LJ 1000 while trying to print my tax return. I tried emptying the queue, removing power from the printer, etc, etc. What finally worked was to empty the queue (again), disconnect power from the printer, shut down the computer, plug in the printer again, restart the computer, queue up a print job again, and hit PRINT.
Hope this works for you
Apr 11, 2013 | HP LaserJet 4100 Printer
CAN NOT DELETE A DOCUMENT THAT IS IN THE QUEUE, THEREFORE, NOTHING ELSE WILL PRINT. THE DOCUMENT SAYS IT IS DELETING, BUT DOES NOTHING. i POWERED IT OFF, THEN UNPLUGGED IT FOR A WHILE AND IT IS STILL...
There are 2 simple methods to resolve any print job stuck in queue issue. However, both the methods will not fix printing issue if the HP Printer is in Error mode. Make sure your printer is able to print self test page to prove its functionality,
First method.
This Utility program resolve all the printing issue for HP Printers Only ( Network and USB connection )
This Utility will Resolve :
1. Check Connectivity between the Pc/laptop and HP Printer
2. Check if there any Documents stuck in Queue
3. Check if all the software/Drivers are correctly Installed
4. Check if the HP Printer icon is the default icon to print
5. Will Resolve Printer Spooler Issue and few more issue
Download the file on Desktop and Run the program ( Ex. File name = HPPDU.EXE )
Click Here to download the Utility and save on Desktop location
Run the HPPDU file and follow the instruction on screen to fix.
If this does not fix, try the 2nd Method given below ( this is manual process to clear the print job stuck in queue )
This works for all brands of printers ( HP, Canon, Epson, Brother etc )
Click Start > Programs > Accessories > then select Command prompt, then the black window will open and there type NET STOP SPOOLER and hit enter that will confirm service is stopped , after that on the black window type NET START SPOOLER and hit enter. Repeat this step 3-4 times and end the command with NET START SPOOLER and hit enter. Open the Printers folder and Refresh the Window ( Press F5 on the keyboard )
The service will be started and all print queue should already be remove.
// Above given solutions help in resolving print queue issue, however check the printer functionality if it is working fine ( the printer should be in working condition and should be able to print self test page, this utility cannot fix printer hardware issue //
Regards,
Ron
* Please rate this solution with Thumbs up and comment to help us improve providing support
Jul 02, 2011 | HP Photosmart Premium C309A All-In-One...
When I goto print something, it just does nothing. When I check the print queue, the document is there and restarting does nothing. When I goto the printers and devises it shows the printer as...
First method.
Regards,
Ron
Jul 02, 2011 | Office Equipment & Supplies
HP Designjet 5000 Error..
Some time it depends on what you are trying to print. If this is a receipt or something off thre internet, try to copy the page and pate it on a blenk microsoft office page, it this work try to print, if it works, the email is corrupted.
Feb 07, 2011 | HP DesignJet 5000 Printer
Every time i hook up the kodak esp9 to the computer it keeps spitting out copies of a picture i made a month ago
The problem with this is that the previous printing jobs are still on queue
To delete the Printing queue try doing the ff:
Double click the Printer Icon under Printers and Faxes then
Delete all the printing queue
Click Start then Run then type print stop spooler
Click Start then Run then type print start spooler
Try hooking the printer again
Hope this will help
Regards
Byron
Aug 21, 2009 | Kodak Office Equipment & Supplies
I had problem with dymo, so we printed receipt thru other printer and now got dymo fixed, so i tried to print, but it's not printing, i looked in printer que, there's some printing items that i cann't get...
right click the items in print queue and delete them. You have to wait a few secs before the print queue is clear. You can also try to reprint the same thing by right clicking the item in print queue.
Jan 02, 2009 | Dymo LabelWriter 400 Turbo Thermal Printer
Receipt not printing
I believe this might help, not exactly familiar with this exact model but here it goes.
Receipt ON/OFF function
When you use the printer to issue receipts, you can disable receipt printing in the REG mode to save paper
using the receipt ON/OFF function. To disable receipt printing, press the Rkey in the OP X/Z position. This
key toggles the receipt printing status ON and OFF.
The register will print reports regardless of the receipt state, so the paper roll must be installed.
To issue a receipt when receipt ON/OFF function is set to OFF:
If your customer wants a receipt after you finalized a transaction with the receipt ON/OFF function being OFF
status, press the Rkey. This will produce a receipt. However, if more than 30 items were entered, the
receipt will be issued in a summary receipt.
Copy receipt
You can print a copy receipt by pressing the Rkey when the receipt ON/OFF function is in the “ON” status.
To realize this function, you must enable the function. Please refer to page 62 (Job code 63).
Nov 11, 2008 | Sharp XE-A404 PC Desktop
Printer hangs up.
1. check the printer, make a copy
2. check connectivity, open device manager - USB Printing Support(under Universal Serial Bus Controllers) must be there - swap cable/port if it´s not
3. uninstall, reboot then re install printer driver
Jan 03, 2008 | Epson Stylus CX5800F All-In-One InkJet...
22 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
