Question about Brother LS-2125 Mechanical Sewing Machine
The hook thing falls down
The thing by the needle, im not sure what itz called, but it keeps falling down and wen i try 2 put it together it still falls down.
  • meagain098 Oct 11, 2008
    I also have this problem. I don't know what the part is called, how it came loose or how to make it stay in place. Any info is appreciated. Thanks
    Problem Solver:
  • 5 Answers
Look for the nut in the needle holder and tight it.
Posted on Oct 17, 2008
My needle keeps falling out. I unscrewed the set screw, put the new needle in, then it falls out. I had just taken out an old needle by unscrewing the set screw and didn't touch anything else. Help
Be sure to unscrew the set-screw and extra turn and then insure you are pushing the needle all the way up before tightening it. Could also mean the set screw is stripped...
Dec 11, 2016 | Sewing Machines
How do I thread the 960 Bernina Bobbin?
I'm assuming you have a front loading bobbin. Look at your bobbin. Hold it so the thread is falling down from the top to the right side. Slip it straight in to your bobbin case, and pull up through the slit, until it snaps in through the side clip.
Generally, if you are missing stitches, the hook isn't picking up the thread from the needle, and you will need to take it in for service at a Bernina dealer.
Mar 03, 2015 | Bernina Sewing Machines
After replacing the needle in my singer 8280, the needle clamp is not holding the needle tight, the needle falls down even after tighening it..how do i make the needle get fixed?
It sounds like you have lost the tread guide. When you press the clamp as far up as it will go, there should be a slot in the post underneath the clamp visible. You may need to use a mirror to see it. The thread guide snaps into that slot and keeps the clamp from falling down. Take it to any repair shop. It will not be expensive to repair.
Nov 30, 2014 | Singer 8280 Mechanical Sewing Machine
Hi. I have a Juki DDL-5550N. While I was sewing the needle broke so I replaced it then the was a noise like a click and the the froze. ..I cannot move the wheel that moves the needle holder at all, it's...
first did you find the broken needle. A lot of times the part that broke off will fall down in your hook assembly and lock up the machine. That is what it sounds like. If its the drop in bobbin the take your needle plate off and check your bobbin case. It probably has popped out of where it should be. Take it out make sure there is nothing in the hook area and put the bobbin case back in. That should fix your probalem
Apr 29, 2014 | Sewing Machines
Metal Bobbin Case falls down in machine when I try to sew
the bobbin case needs to be checked to see if it needs to be replaced
and also checked the hook and hook race.
Feb 16, 2013 | Sewing Machines
Needle keeps falling
the best thing would be to take the machine to a sewing machine shop & have them check to see what's wrong with the needle holder, cause if there's a something broken it will have to be replaced
May 29, 2012 | Singer 7444 Mechanical Sewing Machine
The needle shaft wont go up or down when I step on the foot pedal and I cannot turn the wheel to try to do it manually.
If you can not turn the handwheel at all there is a bind in the machine somewere. The most comon place that this will happen is in the hook/bobbin/race area. Follow these steps and it may fix your problem.
Remove needle and bobbin case.
We need to open the race and remove the hook. (The race is the black round part that the bobbin goes inside.)
On the left part of the race there is a small steel clip that you push to the left and it should fall open.
Then remove the hook, it may have fallen out alreay. (It is just right behind the race.)
Clean out that area and make sure there is no broken needle/lint/ ect.
Test to see if handwheel is moving freely with the parts out.
If so lubricate the hook and put it all back together. Should be ready to sew.
Hook needs to be lubricated every 2-3 bobbins
If this does not fix it probably will need to take it in for repair.
Also check to make sure your bobbin winder is not on (I dont think that is it but ill mention it).
Hope this helps
Apr 05, 2011 | Bernina Virtuosa 150
While sewing the bobbin case moves, wheel locks up, needle locks
Im not sure if this will help but thought I would pass it along. My Pfaff 6122 tells me to check bobbin for thread unrolling clockwise before you place it back in the machine. I had mine turned to un roll counter clockwise, this is wrong, the bobbin will fall out when you pull on the thread while you are holding it in your hand. You may just keep putting it in backwards. Hope this works for you. J.R.
Feb 05, 2009 | Brother CS-6000
Broken needle
Remove the needle plate and Turn the machine upside down and shake it or just leave it alone. It will not get into your gears. If you can see the needle you can take it out with some tweezers.
sewman7
Jun 17, 2008 | Brother Sewing Machines
Putting back the pieces of bobbin case on Kenmore Mini Handi
This is for front loading bobbin..........
The Shuttle hook will look very much like this, and marries this to the "half moon" of the fixed shuttle.
The retaining collar ring that holds it all together has a plate like protrusion (like bull horns), this faces to the top and to the back.......there should be a small lug (or two) with corresponding small hole or slot on the fixed housing (hook race) that locates the ring tightly in the correct position.
There should be 2 swivel arms (black plastic at 4 o'clock & 8 o'clock)) that move to hold the whole thing together by clipping onto a small lug on each side of the ring.
If you tip the machine 30 degrees on its back while you do all this, it makes the process easier, as things are less likely to fall out.........support the back with a soft object for convenience (tissue box, pillow etc)
The bobbin case goes in after the housing is assembled, if you try to do it first, it will prove more difficult.
If this is not quite accurate for your model a photo of the bits would be helpful
Feb 27, 2008 | Kenmore 11206 / 11306 / 11506 / 11606
Brother LS-2125 Mechanical Sewing Machine Logo
69 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
