I have been using the Canon Image MF4270 for scanning. It was working fine for the past few months. However, it just started having a problem a few days ago. The original document stops in the paper feeder during the scanning process (i.e. the paper just jams there). MF Toolbox just shows 9% complete and stops there waiting. I have tried to re-install the copier and the programs (including MFToolbox) but the problem still remains the same.
  • Anonymous Nov 17, 2008
    Same problem here. Looking for a solution.
  • 3 Answers
I guess the rubbers that pull the paper are worn out. Replace it.
Posted on Dec 12, 2008
When printing uisng an mf4270 I get an error "load correct paper". I am using A4 and the setting is A4 on both printer setting as well as printing driver. My OS is Win7 and editing software MS office and...
Hi
Just a thought but is the printer detecting the "type" of paper you are trying to use, as opposed to simply the size. For example, is it trying to load "glossy photo paper" specified by the printer utility and finding standard photocopy paper.
Cheers
Dec 06, 2014 | Canon Image Class MF4270 Monochrome Laser...
How to disable ECM and Reduce Baud rate for Canon MF4270 G3 Fax ?
Your approach is correct however it doesn't look like the MF4270 provides for these settings. One might expect to be able to select G3 or ECM or set a lower TX speed.
I located the settings for different Canon Fax machines here:
VoIP Fax Settings
Jul 25, 2014 | Canon imageCLASS MF4270 All-In-One Laser...
Imageclass MF 4270 scans are too light
you can Adjust the density level of scanned image manually from MF4270 read the manual
if you don't have manual please visit this link
Download Canon imageCLASS MF4270 Reference Manual
hope that it will solve your problem
Feb 04, 2014 | Canon Office Equipment & Supplies
How do I get the Canon image runner 1023if to scan documents? I have followed the instructions provided by Canon (what little there was) loaded the drivers, (as per Canon) and still cannot get past the...
Try using different software for scanning. e.g. Photoshop Select the right scanner, for Canon you usually see WIA. Then import image and select Canon. New window will pop-out and you can start scanning. Be sure to press the SCAN button of the machine before scanning.
Jan 26, 2010 | Canon imageRUNNER 1023iF Black and White...
Scans are too light to read
Make sure you have chosen the correct document type in the scan settings. If you did and it still scans lightly then check to see if the scanning LED is normal or dimmer than before, one of the most common causes for the problem you have described.
Sai.
Jan 05, 2010 | Canon imageCLASS MF4270 All-In-One Laser...
USB connection not being recognized on Imageclass MF4270 all of a
First make sure that the USB cable is OK and use another if you have one. Then make sure that the laptops have working USB ports from Device Manager. If they are OK then try powering up the Canon again without the USB cable connected to see if any errors are reported and then plug it in to your laptop to see if it is recognised. Check the status of the Canon Print Driver settings. If this all fails then you may have defective USB ports on the Canon and will need to get them repaired.
Oct 06, 2009 | Canon imageCLASS MF4270 All-In-One Laser...
I have a cannon image class mf4270 but no disk and i cant find a driver on line, can you help?
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=335&modelid=15753
Dec 26, 2008 | Canon imageCLASS MF4270 All-In-One Laser...
Question about copying direct from scan to a Word document
Check if your Canon software creates a PDF image. A scanned image is a RASTER image, a series of dots, that 'appear' like text or drawing. You cannot use Ctrl-C or Ctrl-v. If the software creates a PDF file, you can cut & paste. Usr any good OCR (Optical Character recognition) software ad convert the raster image to editable text. Then you can cut & paste.
S. Moha, Chennai
Dec 02, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
Canon Printer MF 4270 has NO MAc software but Windows only.
try downloading here - http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=335&modelid=15753 - also choose the right operation system on top
Jun 26, 2008 | Canon imageCLASS MF4270 All-In-One Laser...
166 people viewed this question
jasbo
jasbo
