Question about Memorex MMP8565 MP3 Player
MP3 is not coming on at all and it is not charging.
It want do anything for me at all
  • 2,071 Answers
Did you try charging it with the USB cord or do you have an adapter that plugs into the wall? If you tried with the USB cord, how long did you let it charge?Did you plug cord directly into computer or do you have external USB hub?Many times the hubs will not have sufficient power to charge.Was your computer"go to sleep"after a while.The MP3 will only charge while the computer is awake.
There are a variety of things that could be wrong. If the MP3 sat for a long time the battery could be completely discharged. I've not had this problem on the MP3, but on an old MP3 my sister has. I've noticed that sometimes I need to plug it in with a wall adapter to get the battery charged enough to start up quickly. If the battery is completely discharged,it can take 30 minutes or longer to see any life from the MP3. I would let it charge for few hours if you can then try the reset.
To reset the MP3 press and hold both Menu and Select (center button) for about 5 or 10 seconds. If the MP3 is alive this will reset it.
From your post, I'm not sure if you mean the MP3 was sitting for a long time without being used. If that's the case and it used to work, and it has not gotten wet or anything, then the most likely problem is a bad battery. There are services on the web you can find who will replace the battery for a fee. If, on the other hand, it just suddenly stopped working and the reset does not help you may have a more serious problem. Unfortunately there's no way to tell.
Hope it may help you; Regards, VOTIT
Posted on Sep 29, 2008
It just says gogear on the screen and it will not show anything else. i can't turn it off it seems as if none of the bottons are working. the battery lookes to be charging then this Gogear will just come...
It just says gogear on the screen and it will not show anything else. i can't turn it off it seems as if none of the bottons are working. the battery lookes to be charging then this Gogear will just come back on till the battery runs out. what can i do.
Sep 15, 2009 | Philips GoGear HDD1830 MP3 Player
My mp3 won't play music charge or anything
you can try this, on the back of the unit theres 4 very small phillips head screws, if you take them out you can remove the battery and then put it back in and see what happens, if the conditions still the same you can purchase a new one on Amazon for short money, it comes in a kit with new screws and a little screwdriver.
Mar 20, 2009 | SanDisk Sansa E280 MP3 Player
MP3 Player Not Charging!!! (USB)
The most common cause is a flat battery. There is a trick to charging
the battery in these small mp3 players. It wont charge if it is turned
on, and it won't charges if it's in sleep mode (zzzz). Here what to do...
1. plug the payer into your USB port. or wall charger
2. switch thje player on
3. turn it off by either holding down the play button, or selecting
"System" from the menu
4. The screen will go black and the battery will begin charging.
Feb 15, 2009 | Coby MP-C7092 (2 GB) MP3 Player
My samsung mp3 went though the washing machine and wont turn on.
Might be a lost cause, but you could try putting it in a bag of dried rice. Maybe for a day or two. You should have done this right after it came out of the washer so I'm not sure it will do anything. It's worth a try though.
Jan 17, 2009 | Samsung Yepp YP-T9 Digital Media Player
My RCA player will not charge
The RCA TH-1602 does not come with a re-chargable battery. It comes with an alkaline battery. It can use any AAA battery that you install. If you want a rechargable battery, buy one and install it. Otherwise, buy any AAA battery to replace the one that came with it.
Jan 15, 2009 | RCA TH1602 MP3 Player
Mp3 not working
i can't help with ur mp3 not working but i had a similar problem with my mp3 not charging i just realized you had to turn it on it didn't say on the guide book it came with but i'm creative n then i turned it "ON" and it was charging i hope i helped someone with this simimlar problem
Nov 29, 2007 | BenQ Joybee 125 MP3 Player
Mp3 player wont play songs or anything
Only 2 suggestions here: 1) Make sure your HOLD switch is not enabled. 2) Try to update the firmware If neither of these work, time to send the unit back to Sandisk
Aug 09, 2007 | SanDisk Sansa e250 MP3 Player
Help me please! My mp3 player shut off.
press the power button for 15 seconds and let go. leave it plugged in the battery should be charging.
Dec 27, 2006 | SanDisk Sansa e250 MP3 Player
Memorex MMP8565 MP3 Player Logo
60 people viewed this question
Top Memorex Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
Are you a Memorex Audio Player and Recorder Expert? Answer questions, earn points and help others
