I have a Sears kenmore washing machine, model 80. I need a diagram of the aggitor, top part
  • 172 Answers
Http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080114x00001
Click on this link, enter your model number in the box and find your model. It will show you a break down of the agitator and all of its pieces. The model number will begin with a 3 digit number then a period, then about 8 more numbers. Model 80 is only the size capacity and line level. You should be able to locate the model by opening your lid and look around the rim for the model plate. If you send me your model, I can forward the diagram for you. I hope this will help.
Mike
Posted on Sep 30, 2008
I have a sears kenmore 80 series 110.24852300. The lid switch is broken. I bought a new switch. I cannot figure out how to get inside the machine to replace the lid switch. Please help.
There are videos at www.appliancehelponline.com/servicemanual.html that will walk you thru testing and replacing this part. It may be a different model but the replacement will be the same. You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available
Apr 07, 2010 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series Model 110.28812790 - water leak inside tub
It's quite possible. First see the Sears parts list for your washer with diagrams of all major parts.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=+110.28812790&pathTaken=partSearch
Then see the Whirlpool / Kenmore Service manual for these washers and check the troubleshooting section.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Mar 26, 2010 | Kenmore Washing Machines
How do I get the back off a series 80 kenmore washing machine.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump
removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Also see the following:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131
Mar 12, 2010 | Kenmore Washing Machines
I need a diagram to put my clutch back to gether on my kenmore 80 series washer
Also see the following Whirlpool / Kenmore Service Manual.
It has a good section on how the clutch aligns with the brake and spin tube.
Jan 29, 2010 | Kenmore 15864/15862 Top Load Washer
Hot ware trickles in on my Kenmore Series 80 Model 110.92282100. I probaly need to change the water valve. How do I get access to it?
First, see the Sears Parts site for your washer.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.92282100
By looking at the diagrams, you should have a good idea of how to access the water inlet valve.
See the following for how to access the console.
This is the Whirlpool / Kenmore Service manual for top load, direct drive washers.
Dec 20, 2009 | Kenmore 24902 Top Load Washer
Top loader series 80 Kenmore doesn't stop after the whole wash cycle, it goes directly to 2nd rinse, then spins again and stops?
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
Since it does everything else, the problem points to the timer.
See the following Whirlpool / Kenmore installation and service manual for top load, direct drive washers with an extensive troubleshooting section.
Oct 14, 2009 | Kenmore 24032\24036 Top Load Washer
Bearing pac for 80 series
Since Whirlpool makes a number of Kenmore "80 series" washers, the first place I'd look is the Sears parts site.
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
You may be able to find the part you need there.
Without a complete model number, it is difficult to tell what the problem is.
Sep 27, 2009 | Kenmore Washing Machines
Kenmore 80 seies - agitator slips and doesn't turn in regular motion
There are 4 agitator dogs under the dasher go to sears,com you can pull up the diagram with your complete model number and order them right there online....
Jul 08, 2009 | Kenmore 24032\24036 Top Load Washer
Super Capacity 80 Series dryer with bad timer
If you go sears.com to the parts section and type in your model # you can view diagrams of your dryer and get the part number for the timer. You can even order it right there on line.
Jul 01, 2009 | Kenmore 22422 Top Load Washer
My Kenmore Series 80 washer model 23832100 spins slowly
It probably is your clutch. You will need to remove transmission to repair this.
May 12, 2009 | Kenmore 22422 Top Load Washer
Washing Machines Logo
153 people viewed this question
Top Washing Machines Experts
