Question about GE GSS20IEM Side by Side Refrigerator
Water in door will not shut off.
I have a GE GSS20IEMB WW I think. Was working fine when suddenly over the weekend, the water in the door started coming out on its own. Could not get it shut off. Had to turn water off at wall. The funnel was not being pushed in or any thing. Sounded like a humming from behind the fridge..The icemaker door opens and shuts fine and ice comes out..Just can't get the water to shut off..Would this be the inlet valve??? Please help...cc
  • 725 Answers
Most like the dispenser micro switch is stuck open.. it could also be the inlet water valve.. but I could check the switch first...let me know
Posted on Sep 29, 2008
How do you get the water dispenser on a GE side by side model GSS201EPD WW to work?
Chances are that the=> WR57X10050 Water Inlet Valve has become defective on the dispenser side of the valve.. I am here should you have questions, Thanks John T. Appliance 911
Jun 28, 2015 | GE Refrigerators
Ge gss20iemb
Valve is GE WR57X10032
Replace with SUPCO WV10032 sells on Amazon for $17.76 There is usually a sheet inside package with diagram
Amazon com Supco WV10032 Refrigerator Water Valve Replaces WR57X10032 Home...
Jan 06, 2018 | Refrigerators
Model #GSS20IEMB WW. Neither freezer nor frig are cooling... all above 32 degrees. May have over-heated due to freezer door left ajar. Is there a reset button, or other solution to kick start it. Motor...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Sep 03, 2010 | GE Profile 23.1 Cu. Ft. Side-by-Side...
Where is the defrost timer on a GE model gss20iemb ww
Good day,
Doesn't have one. It functions thru a motherboard mounted on the bottom back rear of the machine.
Normally 5 thermistors are used (3 in the freezer 2 in the fresh food compartment) to operate the machine.
Defrosting cycles are controlled by the motherboard with the input as well from compressor running time and the number of door openings.
May 01, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Fridge - model gss25tgma ww - will not dispense water. Ice
solution part # wr49x10173. door heater. comes with instruction. install in 15 min. good luck.
Jan 19, 2010 | GE GSS25TGMCC / GSS25TGMWW Side by Side...
GE side by side by side,water drips from bottom freezer door
I have the same problem. Just talked to a friend that's a great appliance repairman. he said I have to remove the panel in the back inside of freezer and there is a drain that gets clogged up, a little hole or tube.
clean that and should work fine and stop leaking. I haven't had time yet, but this weekend I'll do the deed. Hopes this helps ya!
Jan 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
No water flow
turn the freezer side to zero fridge side will zero also . click for water it should work . just worked for me no water for 1month replaced the filter and everything.
Dec 06, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
GE ESS25XGMC WW Side by Side
its possible that your water tank has frozen up, try turning the refrig off and leave the doors open for about 10-15 mins and try it again. if that works just reset temp controls a little lower..
Dec 15, 2007 | GE GSH25JFR Side by Side Refrigerator
Water leaking out of freezer door water dispenser
The fill valve that supplies the water may not be shutting off completely. Also check to see that the lever is closing completely.
Apr 04, 2007 | GE GSS20IEP Side by Side Refrigerator
GE GSS20IEM Side by Side Refrigerator Logo
145 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
