The agitator in my washer, top part doesnt agitate. I need a scamatic of Model number 80 Sears Kenmore
5 Suggested Answers
Lumpy816
  • 246 Answers
SOURCE: Kenmore 80 series won't spin
Some models will agitiate for a couple of minutes even with the lid open. Try listening when you close the lid for a "click". If it is missing you may have a bad lid switch.
Posted on Jun 13, 2008
mikedurland
  • 481 Answers
SOURCE: Sears Stock# 28803 / Model# 110.28803890 / Kenmore 80 Series
this sounds like the direct drive coupling between the motor and transmission. very common problem and not very expensive. look under the machine and and between the motor and transmission you will see a round rubber coupling and 2 plastic pieces one on either side; they all connect together to mate the motor and trans without a belt.
Posted on Jun 27, 2008
  • 1028 Answers
SOURCE: Kenmore 80 Series Top Load Washer not agitating
if it will pump out ckd motor to gearcase coupling probably broke
Posted on Sep 03, 2008
onthejob5130
  • 640 Answers
SOURCE: Kenmore 80 series top load washing machine won't agitate or spin
defective motor coupling,,replace..onthejob
Posted on Jan 24, 2009
Maytag317
  • 1136 Answers
SOURCE: replacing the agitator dogs in a Kenmore 80 series washer
Hi, Remove the cap on the agitator and then remove the inside cover. There is a 7/16" bolt under the inside cover. Remove the bolt and the agitator will lift out. Seperate the 2 pieces of the agitator and replace the dogs. You might have to use a flat blade screw drive and punch out the 4 tabs around the bolt hole in the agitator if this applies.
I hope this helps you. Please let me know if I can assist you further.
Vic
Posted on Jul 03, 2009
The agitator is slipping on our Kenmore 80 series toploader. I'm not sure how to remove it.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Look at the section on the Sears site for Agitator, basket and tub.
Assuming that only the top section of the agitator is "slipping, the problem points to the Agitator "Dogs"
See the following for how to replace them.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136&osCsid=8878c06f855a89c90959d53553cf9ab8
If it's not the "Dogs" see the following that has a section on how to remove the agitators and check the splines.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Mar 02, 2010 | Kenmore Washing Machines
Washer now agitating lazily. Ken. HD 60 series. Agitator doesnt seem to be fully connected? How do you remove the agitator?
First, I'd pull the agitators and check for worn or damaged splines inside the agitator or on the agitator shaft.
Following is a description of how to take them out.
I'd also check the Motor Coupler for a worn center rubber piece.
Jan 16, 2010 | Kenmore Washing Machines
Series 80 Agitator top dosent work
If the bottom agitates and not the top, the problem is likely the 4 "agitator dogs" designed to allow the top agitator to turn only one way.
I assume that your model number starts with a 110 instead of 100.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.26842692
See the part "Dog, agitator "
Remove the fabric softener unit, lift the top agitator cap (use a screwdriver) and you should see a plastic part in the center of the top agitator with a 1/2" square drive.
Remove the drive and lift off the top agitator. Turning it over you should see the 4 "dogs", replace these and the top agitator should turn in one direction only.
Replace the 1/2" drive, the cap and fabric softener unit and the top agitator should work.
Following is an illustrated description of the above.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136&osCsid=0da65cea0e338fe930b1fde153a243f0
Jan 09, 2010 | Kenmore Washing Machines
The upper portion of the agitator (Kenmore Series 80 top load)stopped spinning as if the thread has stripped. What parts need to be replaced?
Basic top load, direct drive Whirlpool / Kenmore washers with two piece agitators use "agitator dogs" to allow the top section of the agitator to turn in one direction only.
These are plastic pieces and over time can wear.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136&osCsid=71493d5cab3d7784ad8aa7cde8e5e5d4
Nov 17, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore washing machine Model 110.4767292, squeaky agitator
I can't seem to get the Sears Parts site for your washer model number.
Can you verify that it's correct?
In the interim, here is the Whirlpool Service manual for top load, direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Following is a procedure for removing the agitator(s) on top load washers.
If you take the agitators out, I'd make sure that any "gunk" is cleaned off and check the splines inside the agitator and on the transmission agitator shaft.
It's probably not a serious problem.
Nov 04, 2009 | Kenmore Washing Machines
I have a kenmore top load washer, The top part of
The top section of a two part agitator is designed to turn only one way. If the "agitator dogs" in it are worn, it wont agitate either way.
Also see the following on how to do it.
Oct 28, 2009 | Kenmore Washing Machines
Bottom part of agitator does not work, i replaced the clutch dogs two weeks ago for the top part. kenmore series 80
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
There are a number of Series 80 design washers. You'll need the actual model number to better check for the problem.
First, I'd remove the top agitator (as you've already done), then I'd remove the main agitator.
Under it you will see a clip and what Whirlpool calls a "washer". The "washer has two prongs, one fits into the main agitator shaft drive and the other fits in the lower agitator. If one or the other of the prongs is broken, the agitator most likely wont. I'd also look inside the main agitator to see if the ridges are broken off.
I'd then start the washer on it's smallest cycle and see if the main agitator shaft turns back and forth. If it doesn't and the washer goes through it's drain and spin cycles, the problem is likely in the transmission itself with what they call the agitate gear and / or agitate cams.
Please see the Whirlpool / Kenmore PDF document on installation, maintenance and operation of direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6?OpenView&Start=1
This is a Whirlpool document with parts lists for their commercial washers (basically the same as the consumer models)
If the problem is in the transmission, although it looks complicated, it really isn't that bad if you have a moderate level of mechanical ability.
Sep 26, 2009 | Kenmore 22422 Top Load Washer
Agitator: bottom moves, top does not
On the Sears parts site:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.26902691&pop=flush
replace the 110.26902691 with your model number (lift the lid and the model number should be printed on the cabinet) and look at the section on the Sears site for Agitator, basket and tub.
This is what they look like:
pd_26_110_80040?$pddetailsth$ #21 on diagram Dog, agitator (4) Number:3366877Substitution:80040 $9.25Remove the fabric softener unit, lift the top agitator cap (use a screwdriver) and you should see a plastic part in the center of the top agitator with a 1/2" square drive.
Sep 13, 2009 | Kenmore 23822 Top Load Washer
Kenmore 80 seies - agitator slips and doesn't turn in regular motion
There are 4 agitator dogs under the dasher go to sears,com you can pull up the diagram with your complete model number and order them right there online....
Jul 08, 2009 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
18 people viewed this question
Top Washing Machines Experts
Richard Roth
Richard Roth
