Question about Philips Magnavox 51MP392H Rear Projection Television
Magnavox 51MP392H -- Multipoint Converge blue faded around edges
I recently replace the ICs for my 51MP392H to remove blue "3-D" like shadows.  The replacement worked to solve that issue, but now the blues and whites appear washed out.  When trying to adjust the multipoint converge, the symbols look blue in the center of the screen, but green towards the outside.  When watching TV or a movie, the whites look okay in the center, but yellow towards the outside edges.  All blues look a little "off."  Is this just a CRT issue, or could it be something else?
  • Anonymous May 06, 2009
    No degaussing coils in projection sets.
    Scholar:
  • 33 Answers
Hey guys here is a great thread on this subject, its were I posted most of my pictures and there is a link to the manual in there. hope this helps,
BTW, IF ANY OF YOU GIVE UP ON YOUR 51MP392H/17 PLEASE LET ME KNOW!!!! I WANT TO BUY YOUR CONVERGENCE BOARD... "I killed mine" edwinkraus@hotmail.com
http://www.techlore.com/forum/thread/16736/Magnavox-51MP392H-17-51-quot--TV-has-double-vision/?page=1
Posted on Nov 14, 2008
    Problem Solver:
  • 5 Answers
Sounds like you have a grayscale problem. Did you use a soldering gun when replacing the parts? Did you turn the TV? Sometimes just turning the set off and letting it cool down will automatically degauss it when you turn it back on. Do you have the service manual? If so let me know where you got it as I'm looking for one. The manual should tell you how to adjust purity and grayscale. If not, mark the screen controls for each tube and turn off two of them to check the purity of each CRT. If there is a purity problem you will need to degauss the set and mark the position of magnets on the neck of each. A white paint pen will do. Adjusting the magnets can be tricky and will affect the convergence so you could end up with a bigger problem. Good luck.
Posted on Sep 30, 2008
I have a Philips 51PW9303 Rear Projection TV that had blue shadows around the sides of the screen and now has a green and red bowed line at bottom. Does I need a convergence board to solve this?
If the following doesn't work the tubes could be at the end of life:
Adjusting convergence:
Note: For best results, the Projection TV needs to be turned on for 15 minutes or longer before adjusting the picture tubes (convergence).
To adjust the convergence of the picture tubes:
  1. Press the 'MENU/SELECT' button on the remote.
  2. Press CURSOR RIGHT to enter the PICTURE menu.
  3. Use CURSOR DOWN and RIGHT to select and enter MANUAL CONVERGE.
  4. Press CURSOR RIGHT to select CONVERGE RED or press CURSOR RIGHT and DOWN to select CONVERGE BLUE.
  5. A crosshair will be shown on the screen. If there is any red or blue fringe around the crosshair, use CURSOR RIGHT, LEFT, UP, DOWN to try and merge the fringe colors with the crosshair.
  6. Press the 'MENU/SELECT' button to return to MANUAL CONVERGE menu.
  7. Press the 'EXIT' button to exit the menu.
If you are satisfied with the convergence you may stop now. Otherwise, you can continue and adjust the convergence more using mult ipoint convergence.
To Adjust multipoint convergence:
  2. Use CURSOR RIGHT to enter the PICTURE menu.
  3. Use CURSOR DOWN and RIGHT on the cursor ring to select and enter MANUAL CONVERGE.
  4. Press CURSOR RIGHT and DOWN on the cursor ring to select MULTIPOINT RED or MULTIPOINT BLUE.
  5. A grid of crosshairs will appear on the screen. If there is any red or blue fringe around any of them, press CURSOR RIGHT to enter NAVIGATE mode.
  6. Use CURSOR RIGHT, LEFT, UP, and DOWN to move to a crosshair that has a color outline.
  7. Press the 'EXIT' button to enter ADJUST mode.
  8. Use CURSOR RIGHT, LEFT, UP, and DOWN to merge the color with the crosshair.
  9. Press the 'STATUS/EXIT' button to return to NAVIGATE mode. Repeat as necessary.
  10. Press the 'MENU' button to return to the MANUAL CONVERGE menu.
  11. Press CURSOR DOWN until SAVE MULTIPOINT is selected.
  12. Press CURSOR RIGHT to save the multipoint settings.
  13. Press the 'EXIT' button to exit the menu.
Apr 03, 2010 | Philips 51PW9303 51" Rear Projection...
The screen is starting to have red and green blurring
sounds like the coolant if it appears as halos. If it appears like a 3D picture its the convergence ICs.
Jan 30, 2009 | Philips Magnavox 51MP392H Rear Projection...
Phillips projection tv will not converge
Replace Both convergence ICs STK392-120s use 180s better ICs they are big black ICs will have STK on them Mat Electronics for parts 1-800-628-1118.Also CK 6.8 ohm resistors around STKs.
Dec 30, 2008 | Philips Magnavox 51MP392H Rear Projection...
51MP392H/17 Red Convergance Problem
you need to replace the two Convergence ICs they are STK392-120 and also about four of the 6.8 ohm 1watt resistors. You can get replacement ICs and resistors at the following link and they provide free instalation instructions
http://servicemanuals.vstore.ca/
Jul 15, 2008 | Philips Magnavox 51MP392H Rear Projection...
Magnavox rear projection
you will need to replace both convergence ics they are both STK392-120 and you will also need four 6.8 ohm 1 watt convergence resistors. You can get replacement ICs and the resistors at the following link and they provide free instaltion instructions with pictures so you can do the repair yourself.Here is the link.
Jul 06, 2008 | Philips Magnavox 9P6034C 60" Rear...
Magnavox 51MP392H/17
No, if the Red doesnt adjust with the remote, You will need to replace both STK392-120 Convergence ICs. Its a fairly easy job if you have basic soldering skills, and you will also need about four 6.8 ohm 1 watt resistors for your model. You can get replacement ICs and resistors at the following link and they provide free instalation instructions with pictures. Heres the link.
Jun 16, 2008 | Televison & Video
RED AND BLUE AURA
need to replace your Convergence ICs they cost about 10.00 each. You need to replace both of them they are available at electronix.com
Feb 12, 2008 | Philips Magnavox 51MP392H Rear Projection...
Maganvox TV with red-shadow to picture
Hi Emily,
Your TV has bad convergence amplifiers. They are large integrated circuits that are mounted on large metal heat sinks. They have a part number on them, but might be covered up by a bracket. The part number should start with STK. They are replaced as pairs. You will have to find someone with the skills necessary to replace them.
Best Regards,
MyTvGuy
Feb 10, 2008 | Philips Magnavox 51MP392H Rear Projection...
Blue Multipoint converge failure Philips 55PP9753
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 12, 2008 | Philips 55PP9753 55" Rear Projection...
Distorted picture
tv has red & blue converge problem,tried to fix it with remote by multipoint lining the t,s up didn,t help
Jan 12, 2008 | Philips Magnavox 51MP392H Rear Projection...
Philips Magnavox 51MP392H Rear Projection Television Logo
427 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
