Question about Garmin GPS
I have a Garmin Nuvi 660 and the suction cup fell off the inside of the windshield and broke the screen on the GPS. I believe it is only the touch screen portion because the picture looks and acts fine. Where can I get this repaired or is the repair easy enough to do it myself?
  • Garmin Master
  • 2,130 Answers
If the unit is under warranty, then send it back to the manufacturer. I had one customer that had the same thing happen and the manufacture offered to replace her unit free of charge.
If the unit is out of warranty, the manufacturer will not sell you a replacement screen. You can find them on eBay, but unless you know how to take the Nuvi apart, you face damaging the unit further.
If the touch screen is bad, the Nuvi will not recognize any presses on the screen. Having worked on many of these units, there is really nothing to go bad on a touch screen unless its physically damaged or has become disconnected from being dropped. If it appears that the glass is cracked, then it is the LCD display that is bad. The touch screen is a clear film layer that lays over the LCD display.
I would strongly suggest that you purchase a Garmin friction mount and no longer use the window mount. With a friction mount, your Nuvi will not fall and the friction mount is legal in all 50 states, whereas a window mount may not be.
- Jim
Posted on Sep 29, 2008
I need instructions on how to mount the nuvi 200w to my windshield
To secure the nuvi 200w to your windshield with the included suction cup mount (pictured below),
center the GPS on the clip, and tip the bottom edge on the bracket. Push the top of the GPS against the top clip until it clicks into place. Hold the bracket and GPS near the windshield where you like it best. Note where the suction cup is on the windshield in relation to the mirror, etc. Remove the GPS from the mount's clip by pushing the top tab back from the top of the GPS.
Clean the windshield (or portion that the suction cup will be stuck against) with a paper towel or newspaper and ammonia solution like Windex, etc. Clean the suction cup with the paper towel and Windex, too.
Lift the lever at the base of the mount - is shown in the picture above - if it isn't already. With the mount oriented as shown in the picture above, press the suction cup against the windshield where desired with one hand. Hold the mount firmly against the glass and use your other hand to press the lever on the base back toward the suction cup and glass. Press until it lays flat against the base / suction cup. Plug the power cord into the GPS and reinstall the GPS in the mount clips as done earlier.
To remove from the windshield, release the GPS from the mount clips, and lift the lever away from the base / suction cup. Locate the tab that is connected to the suction cup edge near the lever. Pull on the tab away from the glass to break the suction seal and remove from the windshield.
If this was helpful, please rate it 4 thumbs up. Thanks & good luck!
Sep 20, 2011 | Garmin GPS
My garmin nuvi 350 suction mount falls from the windshield after several days.
I believe they all do that, I own a Garmin and I bought what looks like a bean bag because I got tired of my suction cup mount falling off my windshield. The nice thing about the bean bag mount is that you can move it closer to you and place it anywhere on your dash. I bought mine on ebay from the Mount Guys they have a big selection of mounts for all types of GPS's take a look you might want to make the change too.
I hope this helps you out and if it did please leave me some feedback
Apr 03, 2011 | Garmin GPS
Can't connect garmin nuvi 660 to PC USB
Your Nuvi should be Off before connecting....
My Nuvi came with a patch cord that connects from Nuvi to laptop
its a usb cord, same usb cord you find for cameras
Your computer should see that a usb cable is connecting
go to.... www.MyGarmin.com and update maps
Mar 24, 2010 | Garmin Nuvi 660 GPS Receiver
Garmin 660 "Display unit " won't seperate from mount
If you have the suction cup holder in the middle of the bottom of holder there is a tab there... hold gps while thump underneath and press thump upward to release and pull out unit
Mar 13, 2010 | Garmin Nuvi 660 GPS Receiver
The end screwed out of the sigar power supply and
Yes
Try Radio shack, or get a new charger from ebay.
Feb 15, 2010 | Garmin Nuvi 660 GPS Receiver
Not touch sensative
In 90% of the cases it's the digitizer (the touch sensor that is mounted in front of the screen). You can try to replace it yourself or send it to a third party gps repair service.
Jul 24, 2009 | Garmin Nuvi 660 GPS Receiver
Unit will not hold suction (c330)
put a little spit on the rubber suction cup than install on window i had the same problem
Jan 01, 2009 | Garmin Nuvi 660 GPS Receiver
I have two NUVI 660's and one 360 (?) navigation systems. They all work great except all three have the same problem with the suction cup. Aftera few months, they will not stay attached to the...
Hello rkfowler,
While the suction cup mounts included with most GPS units are very effective, they certainly can fail. It sounds like you are doing everything you can to make it work: cleaning both the windshield and the cup itself. You also might try putting a few drops of water onto the suction cup before affixing it.
If the suction cup mounts aren't working out for you, Garmin does have a couple of other options including a vehicle mount that uses a super strong adhesive or a friction style mount. These are available from Garmin directly on their website (www.Garmin.com) or through your local consumer electronics store, such as Best Buy.
Best Regards,
Ken
"Go Ahead. Use Us."
Jul 08, 2008 | Garmin Nuvi 660 GPS Receiver
GPS Logo
150 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
