Question about GE DBSR453EBWW Electric Dryer
Will not turn on..
It was working fine then stopped now will not turn on and makes no noise. the top of the dryer felt real warm is it the thermal fuse or the motor?
  • 172 Answers
Hi trishis26,
If it was the motor you would still be able to hear it trying to start. The will make a loud hummmmm. Since it is doing nothing you most likely have a bad thermal fuse.
Other possible problems include the door switch, the start switch, the timer, the breaker in your home. If you need more help, just let me know and I will be happy to try to help you figure it out. Good luck.
Mike
Posted on Sep 30, 2008
My beko condenser tumble dryer is drying fine but is making a loud scraping noise. When I took out the clothes there was a strip of white felt in the washing
Looks daunting to start with but just done mine,
remove top and all rear covers and rear panel after removing drum split washer, pump hoses, belt and elec connection, remove the drum and you will see where the felt seal goes. i had some felt i cut to 12mm wide and siliconed it in place, left to dry for 6 hrs, now runs fine.
Feb 07, 2011 | Dryers
My dryer is making loud noise and after it gets warmed u it stops. I have replaced felt inside
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Oct 07, 2010 | Frigidaire Dryers
It will not turn on. Has been used before and suddenly wouldn't work. The inside light works - so we know it is getting power. The timer for the timed dry ticks, so that part is working. But it does not...
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
Sep 09, 2009 | Dryers
Location of the thermal fuse on the kenmore gas dryer 80
Feb 03, 2009 | Dryers
Back of dryer
Always disconnect power
  • Kenmore,
    the Front comes off, the back is fixed and rigid.
  1. remove the lint screen
  2. remove the screws that hold the lint screen holder to the lid
  3. there are spring clips at the front corners that can be pressed in with a putty knife or other blunt blade to unlock the top cover.
  4. raise the top
  5. there are screws either side of the front, inside the case points to the front heads to the rear, remove them,
  6. unplug the door switch, lift front off drum and supports and away.
reassemble in reverse
easy access to drum to remove it and replace felt ring, rollers belts.
When you replpace the belt, you should check the felt bearing around the open end of the drum, and the pully/idler wheels as well.
Often the cause of the belt breaking is the extra force needed to turn the drum when the felt or rollers are fubar.
Aug 03, 2008 | Kenmore 63942 Dryer
Hot point dryer
Three problems
  1. :Heater thermal fuse is blown, not a repairable/resettable item, replace the thermal fuse.
  2. the controller that turns on the heater, is fubar
    it is a relay with 120v solenoid coil and 120v terminals for the motor and 240v terminals for the heater. the 240v side has fused closed so does not turn off. not a repairable item replace the relay
  3. The scraping noise could be from drum bearings/rollers Check the roller bearings under the rear of the drum, to make sure they still turn freely and have not dropped, check the felt ring at the front of the drum to see if it is worn out
  1. as soon as you started the motor a rush of very overtemperature air travelled down the exhaust duct and melted the thermal cutout screwed on the side of the duct, inside the dryer. These items are between $7-$13, and every washer/dryer parts store has them, there are only 4 or five different ones in all the makes of dryer.
  2. Locate the run relay, and remove it, test with a ohmmeter or battery and bulb, across the load terminals, ALL load terminals should have, no light on the lamp, infinity ohms on the meter,
    solenoid coil terminals should have about 100ohm on the meter, faint glow on the lamp
    relays are $18 -$90 (rippoff but some have to use OEM parts)
  3. roller kits are $9+, felts between $12-$30
Aug 02, 2008 | Kenmore 63942 Dryer
Kenmore dryer model #11060932990
HAVE YOU CHECKED THE IDER ARM UNDER THE BOTTOM FRONT OF THE DRUM??????THANKS
Jul 23, 2008 | Dryers
Loose drum support felt
you could try using "Permatex" hi-tack adhesive.  you need to remove the door where the bearings are first.
Oct 13, 2007 | Dryers
Will not start; makes no noise
check the humidity sensor this will prevent the motor from starting
Sep 22, 2007 | Maytag PYE2300AY Electric Dryer
GE DBSR453EBWW Electric Dryer Logo
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
