Question about Compaq FS7600 17" Flat Glass Monitor
The monitor is not in focus and there is nothing to select in the menu to fix it.
  • halcon_124 Oct 28, 2008
    I have same problem, now can anyone tell me what is LOT ?
    It's Internal setting req to adjest LOT focus control
    check CRT base(Focussing Grid)If u find any fongus Pl replace CRT base
    Some times CRT and LOT problem also
  • 65 Answers
Posted on Oct 07, 2008
2 Suggested Answers
  • 56 Answers
SOURCE: Focus is way off...screen is blurry????
is the monitor a flat screen? if so, you can try the autoadjust button, which is found by pressing the monitor menu button, and cycling through.
Posted on Jan 06, 2008
My monitor is a bit blurry. Not sure why
Try to see if your monitor has a menu button which will allow you to select an "Auto-focus" option within it's settings.
If not,
1. Go to your desktop
2. Start Menu
3. Control Panel
4. System and Security
5. Select Device Manager (Accept administrative rights)
6. Click the drop down button next to "Monitors"
7. Right-click and select "Update Driver Software"
If it is up-to-date, then do the same thing by clicking the drop-down button to the left of "Display Adapters."
If these options do not work, then you know that it is not an issue with your hardware, it is certainly an issue with your monitor (this means you may need to purchase a new one).
Please, let me know if this has helped you at all and feel free to leave any further comments that might help me further instruct you on how to fix this problem.
I will be following this problem to make sure you have solved the issue in which you are having.
Nov 16, 2012 | Computers & Internet
Hi a cannon eos400d camera multi focusing
is there any difference with flash in off position??
have you tried a external flash??
Sep 21, 2008 | Cameras
HOW DO YOU MOVE THE ARROW KEY ONCE YOU ARE IN THE MENU?
You use the button with the <> arrows to move through the menu selections. Use the menu key to select the function you want to change.
Below is an excerpt from the Acer manual. The manual can be found at http://www.retrevo.com/support/Acer-X203H-Monitors-manual/id/23224bh549/t/2/
Front Panel Controls
1.Power Switch:
To turn ON or OFF the power.
2.Power LED:
Lights up to indicate the power is turned ON.
3.Empowering / Exit:
1) When OSD menu is in active status, this button will act as EXIT-KEY(EXIT
OSD menu).
2) When OSD menu is in off status, press this button to select scenario
mode.
4.Auto Adjust button / Exit:
1)When OSD menu is in active status, this button will act as EXIT-KEY (EXIT
OSD menu).
2)When OSD menu is in off status, press this button for 2 seconds to
activate the AutoAdjustment function.The Auto Adjustment function is
used to set the HPos, VPos, Clock and Focus.
5.< / >
Press < or > to select the desired function.Press < or > to change the
settings of the current function.
6.MENU / ENTER:
Activate OSD menu when OSD is OFF or activate/de-activate adjustment
function when OSD is ON.
Jul 02, 2011 | Acer X203H bd Monitor
Hp w19b monitor is not in focus, how can i fix it?
press your Menu Butten and go to set resulution and set your monitor Focus.
Jul 31, 2009 | HP W19b LCD Monitor
Screen shrunk
Try using the 'degauss' option of your monitor. It should be in the on screen menu, or possibly a reserved button for it. If not, you may have the options in your menu for the monitor to adjust the shape of the screen manually, you'll just have to go through the menues carefully using the various buttons on your monitor. If nothing fixes it, I would just replace the unit, as repairing it would likely cost more than buying a new one.
May 07, 2009 | Compaq 7500 17" CRT Monitor
Slightly out of focus. Is there an (internal) adjustment, and if so, where?
over time the shadow mask picks up a magnetic charge that interferes with the focus of the electron beams which makes the image look fuzzy or out of focus...to fix this.. most monitors have a deguassing coil/button..look for a DEGAUSS button or in the menu selection on the monitor..Degaussing usually makes a "thunk" sound and the screen will go crazy for a moment ..
May 06, 2009 | Computers & Internet
Acer monitor will not let me adjust screen position
HI,
YOU NEED TO GO TO YOUR OSD MENU
TO GO ADJUST TO MODE TO MODE
LOOK IN YOUR MANUAL TO OBTAIN
YOUR ACCESS BACK TO THE OSD
Feb 07, 2009 | Computers & Internet
Jan 06, 2008 | Acer X221WSD Monitor
Acer x191w monitor background is moved to the right with about 2inches of black on left side.
Here is the fix;
1. Go to Screen Resolution
2. Select Acer Monitor
2. Find Advanced Settings and click
3. Find Screen Refresh Rate and change it to 75Hz
4. After the monitor flicks, changes it BACK TO 60Hz.
This fixed the problem for me. Hope it helps. :)
Jul 18, 2007 | Acer X191WSD Monitor
Open Questions:
TECH HELP$$1%877%778%89%69$$AVG Customer Support Telephone Number? Call USA1-877-778-89-69 AVG tech support is offer the power of any time, anyplace with the assistance of AVG Antivirus support phone number . Any body will easy accessibility the AVG Antivirus Support Phone Number. AVG Antivirus Support number provides technical help and support services in respect to the software system .Our expert Solved all type of issues i.e Netwok conflicts,Firewall configuration and window issues etc. For more detail call:1-877-778-89-69. AVG Antivirus Support Phone Number AVG Antivirus Customer Service Phone Number AVG Antivirus Tech Support Phone Number AVG Antivirus support Helpline Number AVG Customer support Telephone Number AVG Helpdesk number AVG Tech support Telephone number AVG Security Tech Support Number Free AVG Antivirus Customer Support Number AVG Customer Service Tollfree Number AVG Security Tech Support Number Free AVG Antivirus Customer Support Number AVG Customer Service Tollfree Number. AVG Antivirus Support Phone Number AVG Antivirus Customer Service Phone Number AVG Antivirus Tech Support Phone Number AVG Antivirus support Helpline Number AVG Customer support Telephone Number AVG Helpdesk number AVG Tech support Telephone number AVG Security Tech Support Number Free AVG Antivirus Customer Support Number AVG Customer Service Tollfree Number AVG Security Tech Support Number Free AVG Antivirus Customer Support Number AVG Customer Service Tollfree Number. AVG Antivirus Support Phone Number AVG Antivirus Customer Service Phone Number AVG Antivirus Tech Support Phone Number AVG Antivirus support Helpline Number AVG Customer support Telephone Number AVG Helpdesk number AVG Tech support Telephone number AVG Security Tech Support Number Free AVG Antivirus Customer Support Number AVG Customer Service Tollfree Number AVG Security Tech Support Number Free AVG Antivirus Customer Support Number AVG Customer Service Tollfree Number. AVG Antivirus Support Phone Number AVG Antivirus Customer Service Phone Number AVG Antivirus Tech Support Phone Number AVG Antivirus support Helpline Number AVG Customer support Telephone Number AVG Helpdesk number AVG Tech support Telephone number AVG Security Tech Support Number Free AVG Antivirus Customer Support Number AVG Customer Service Tollfree Number AVG Security Tech Support Number Free AVG Antivirus Customer Support Number AVG Customer Service Tollfree Number. AVG Antivirus Support Phone Number AVG Antivirus Customer Service Phone Number AVG Antivirus Tech Support Phone Number AVG Antivirus support Helpline Number AVG Customer support Telephone Number AVG Helpdesk number AVG Tech support Telephone number AVG Security Tech Support Number Free AVG Antivirus Customer Support Number AVG Customer Service Tollfree Number AVG Security Tech Support Number Free AVG Antivirus Customer Support Number AVG Customer Service Tollfree Number. AVG Antivirus Support Phone Number AVG Antivirus Customer Service Phone Number AVG Antivirus Tech Support Phone Number AVG Antivirus support Helpline Number AVG Customer support Telephone Number AVG Helpdesk number AVG Tech support Telephone number AVG Security Tech Support Number Free AVG Antivirus Customer Support Number AVG Customer Service Tollfree Number AVG Security Tech Support Number Free AVG Antivirus Customer Support Number AVG Customer Service Tollfree Number. AVG Antivirus Support Phone Number AVG Antivirus Customer Service Phone Number AVG Antivirus Tech Support Phone Number AVG Antivirus support Helpline Number AVG Customer support Telephone Number AVG Helpdesk number AVG Tech support Telephone number AVG Security Tech Support Number Free AVG Antivirus Customer Support Number AVG Customer Service Tollfree Number AVG Security Tech Support Number Free AVG Antivirus Customer Support Number AVG Customer Service Tollfree Number. AVG Antivirus Support Phone Number AVG Antivirus Customer Service Phone Number AVG Antivirus Tech Support Phone Number AVG Antivirus support Helpline Number AVG Customer support Telephone Number AVG Helpdesk number AVG Tech support Telephone number AVG Security Tech Support Number Free AVG Antivirus Customer Support Number AVG Customer Service Tollfree Number AVG Security Tech Support Number Free AVG Antivirus Customer Support Number AVG Customer Service Tollfree Number. AVG Antivirus Support Phone Number AVG Antivirus Customer Service Phone Number AVG Antivirus Tech Support Phone Number AVG Antivirus support Helpline Number AVG Customer support Telephone Number AVG Helpdesk number AVG Tech support Telephone number AVG Security Tech Support Number Free AVG Antivirus Customer Support Number AVG Customer Service Tollfree Number AVG Security Tech Support Number Free AVG Antivirus Customer Support Number AVG Customer Service Tollfree Number. AVG Antivirus Support Phone Number, AVG Antivirus Customer Service Phone Number, AVG Antivirus Tech Support Phone Number, AVG Antivirus support Helpline Number, AVG Customer support Telephone Number.AVG Helpdesk number,AVG Tech support Telephone number,AVG Security Tech Support Number,Free AVG Antivirus Customer Support Number,AVG Customer Service Tollfree Number,AVG Security Tech Support Number,Free AVG Antivirus Customer Support Number,AVG Customer Service Tollfree Number.AVG Antivirus Support Phone Number, AVG Antivirus Customer Service Phone Number, AVG Antivirus Tech Support Phone Number, AVG Antivirus support Helpline Number, AVG Customer support Telephone Number.AVG Helpdesk number,AVG Tech support Telephone number,AVG Security Tech Support Number,Free AVG Antivirus Customer Support Number,AVG Customer Service Tollfree Number,AVG Security Tech Support Number,Free AVG Antivirus Customer Support Number,AVG Customer Service Tollfree Number.AVG Antivirus Support Phone Number, AVG Antivirus Customer Service Phone Number, AVG Antivirus Tech Support Phone Number, AVG Antivirus support Helpline Number, AVG Customer support Telephone Number.AVG Helpdesk number,AVG Tech support Telephone number,AVG Security Tech Support Number,Free AVG Antivirus Customer Support Number,AVG Customer Service Tollfree Number,AVG Security Tech Support Number,Free AVG Antivirus Customer Support Number,AVG Customer Service Tollfree Number.
Mar 24, 2017 | AVG Computers & Internet
See all Compaq FS7600 17" Flat Glass Monitor Questions
Compaq FS7600 17" Flat Glass Monitor Logo
144 people viewed this question
Top Compaq Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
