Fridgidaire front load washer will not spin - Washing Machines
  • 1 more comment
  • Mom23kids Mar 06, 2009
    my fridgidaire front load washer drum will not move during any wash cycle. I can manually move it so nothing is jammed in it. what could it be?
  • Anonymous Apr 27, 2009
    FRIDIDAIRE ATF8000FS BRAND NEW MACHINE. WILL GO THROUGH ENTIRE CYCLE EXCEPT LAST SPIN CYCLE. MACHINE STOPS WITH DOOR LOCK ON.
    WE CANCEL AND THEN IT SETS ITSELF TO LAST SPIN CYCLE. HIT START THEN IT SPINS JUST FINE. ???????HELP
  • Carl Schulzetenberg
    Carl Schulzetenberg May 11, 2010
    Is there still water in the tub?
  • 1,543 Answers
Have not heard back from you, so I'm posting this as a "solution" to remove it from my "work" in box. Oldfixer has posted what sounds like a good solution. If so, give him a FixYa. Post new comment if you are still having troubles.
Posted on Oct 05, 2008
My washer will run on whatever setting you put it on. But, it does not run through the entire cycle and will not spin the water out of the machine.
Posted on Sep 29, 2008
    Genius:
  • 1,028 Answers
If wtaer in tub remove bottom cover and clean pump ..if spins but will not reach high speed and door does not lock properly change door lock
4 Suggested Answers
SOURCE: Clunking noise and vibration during final spin cycle
For all those who say they recently bought the machine, the cause of the machine "walking across the floor" and vibrating violently is the packaging bolts on the back of the machine that were supposed to be removed when the machine was installed (why it says remove packaging bolts in the installation manual). These packaging bolts hold the suspension steady and firm during shipping but MUST be removed before operating the machine. When these packaging bolts (I think there are four total, some up to 6 inches long penetrate the rear of the machine) are removed, they allow the suspesion to absorb the vibration.
Posted on May 25, 2009
localwonder
  • 6784 Answers
SOURCE: Front load Fridgidaire ftfb4000fs1 won't spin
This is a fault that resides within the motor control board. you will need to replace this failed module asap if possible. it has failed.
Posted on Jun 15, 2009
SOURCE: ATF6000ES front load washer won't spin during regular cycle.
clogged filter will cause this error code. I have the same washer and the filter located inside the rubber boot attached to the pump was full of junk. there was enough room for water to get thru but not enough for full volume. clean it out and it should work. note : its a pain to get the boot back on so be ready and take it slow. this worked for me.
Posted on Aug 30, 2009
Fridgidaire gallery front load washer doesnt spin out and leaves clothes wet
sounds like the belt that goes around the drum has come off the pulley or belt has broken you should be able to look under it to see the belt is on or off. hope this helps you.
Dec 13, 2010 | Frigidaire GLTR1670A Front Load Washer
My fridgidaire front loading washer just recently stopped working on the spin cycle, it doesn't even work on the spin/drain cycle.
More than likely a bad door switch, as it won't go into the spin if the board doesn't like the reading it gets from teh switch. They fail quite often. Part number is 131763202
Apr 04, 2010 | Frigidaire ATF6000ES Front Load Washer
My fridgidaire frontloader wont do a spin cycle
A lot of times it is the strainer clogged at the pump. That has happened to mine. Hope that helps.
Sep 06, 2009 | Frigidaire Affinity ATF7000E Front Load...
Jun 15, 2009 | Frigidaire ATF6000ES Front Load Washer
Fridgidaire Washer has a loud knocking noise during spin cycle.
You need to replace your washer, the Inner tub Spider broke.. I repaired mine, With me doing the labour, $285 just for the part alone. plus about 3 to 4 hours labour.
Mar 14, 2009 | Frigidaire FWTBB30DS Front Load Washer
Fridgidaire FTF2140ES0 Front Load Washing Machine Vibration
Try going to GVIINC.net - there product definately works.
Nov 16, 2008 | Maytag EPIC MFW9700S Front Load Washer
14 cycle front load washer fridgidaire
press cancel. (turns off washer)
press start/pause (wake up)
hold cancel and start/pause 10sec
last error code will come up.
E47 door lock error
check wires connections to the door lock..
replace door lock..
hope it helps
Aug 08, 2008 | Frigidaire ATF6000ES Front Load Washer
Fridgidaire front loading washer
Open the bottom and check to see if the shocks are good.
Apr 09, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Washing Machines Logo
141 people viewed this question
Top Washing Machines Experts
