I have one Stanton T60 turntable on channel 1 of the mixer and the other on channel 4. The problem is that the one on channel 1 is not as loud as the one on channel 4 even thought the gains on the mixer is set equal to each other. I've found that when you take the headshell off and clean it, it "sometimes" fixes the problem for a while. Is there any major problem? What can I do to resolve this annoying problem?
  • 515 Answers
SOURCE: left output from one of my turntables cuts out regularly leaving a hum
No, the issue is either with the RCA cables or the tonearm. You might also want to check your cartridge and headshell connection. Make sure the contacts are nice and clean, and securely on the headshell. Have you tried swapping out your turntables? Take the left turntable, and put it on the right channel's input, and vice-versa? This will tell help isolate the issue. If the problem just moves, then we know it's not your mixer. If the problem remains on the same side, then you know there is something wrong with your mixer.
If the problem moves, then you can safely say it's your turntable with the issue. The STR8-30's aren't the greatest quality, so it's also possible that you have a faulty tonearm or RCA cables.
Hope this helps.
Posted on Jan 19, 2008
  • 515 Answers
SOURCE: Headshell for Denon DP-45F Turntable
Any Half-Inch / Standard mount headshell will work on this turntable. Luckily for you, these are very common.
- Davis
DJ Pro Audio
Posted on Aug 08, 2008
  • 1512 Answers
SOURCE: I have a Stanton T.80
Hi gium
Sounds like we have reached that point where progressive crossover in technologies means that the usual cautions of earth continuity for the tone arm when using a phono preamp has gone the same way as phono preamps on home theatre.
Have you tried switching to the line level and set the mixer up for that level also. That may reduce any gain induced hum. However it sounds like an earth loop problem, where both decks will need to be earthed in the mixer. Check also that all the gear is running of the same power point. Different mains phases are sometimes available near each other, having any gear (power amps also) on a different phase will cause an earth loop problem.
Is the hum all the time independent of the volume levels, or change with levels adjustments and not at all when turned right down. Let me if changing to line levels helps. We can try some more things, like connecting a temp hookup wire earth to the RCA earth to mixer chassis. Cheers
Posted on Oct 04, 2008
  • 4234 Answers
SOURCE: Tonearm Weight, Good Replacement Stylus, Gain level
Most good turntables will track with weights between 1.25 and 1.5 grams. Any more than that and you are putting alot of pressure on the needle. Experiment a bit and make sure that the needle tracks well and that the sound is good. The less weight you use, the longer the needle will last and the less wear on the record.
Posted on Aug 11, 2009
SOURCE: Need a cartridge stylus with headshell
I also own this turntable. The latest research I found on this unit is the needle is made by Crosley. This is the same brand that makes those nostalgic looking all in one audio products. If you can find who carries the Crosley replacement needles for those units it will fit the Ion turntable.
Posted on Aug 13, 2009
Just got my pair of Stanton T60 decks out of the box for the first time in a while, and I'm not getting a signal out of either. I changed one of the cartridges with no luck. Whats likely to be wrong?
Have you checked what you have them connected to?
The best way is to connect your deck to the amp and remove the wires to the cartridge. Switch on the amp. With your finger, touch each of the cartridge wires one at a time. You should hear a loud buzz, one on either channel, from two of the wires. The other two wires may produce a slight buzz, but it doesn't matter if they do or don't. If you get no buzz from any of the wires then either the connections between the deck and amp are faulty or the pre-amp inside the amp has failed. This will not affect any other amp functions.
If you get a very weak buzz on the two channels, you have no magnetic cartridge pre-amp on your amp. In which case you need to connect the decks to a dedicated "phono" socket, which has one built in, or buy a Magnetic Cartridge Pre-amp.
Dec 28, 2015 | Stanton Audio Players & Recorders
I have a Stanton T60, but I connect to my Bose, but my bose has no phono input, tried aux but low volume... Do I need to buy a preamp?
You don't need a PRE-amp but you do need an amplifier. The auxiliary plug on the Bose is only for iPhones etc which have a margin of their own amplification which your turntable has none. The phono plugs are for the turntable to supply a low power signal to the amplifier to boost it to be audible at volume.
Oct 06, 2015 | Stanton Audio Players & Recorders
How do I connect a Stanton SCS.4DJ turntable to my pc
This is a simple to use unit. Just plug the "line out" of the turntable to your "line in" on your PC or laptop. This is to just straight up record what you're mixing or playing as an audio file.
Jul 12, 2014 | Stanton SCS.4DJ Mixer Console
How can i use my laptop with the stanton t60 turntables?
Plug the turntable into a phono preamp and plug the preamp into your computer.
Jan 22, 2013 | Stanton T.60 Turntable
Technics 1210 poor sound
it must go in to a mixer,if you have then the channel select on the mixer is wrong.
Jul 05, 2012 | Technics SL-1210MK5 Turntable
Both Technics SL1210 mkII's loud hum and almost no sound...
You seem to have some feedback hum from somewhere. I would think it might be caused by a faulty connection somewhere.
Mar 12, 2017 | Technics Audio Players & Recorders
are the gnds connected(earths) you get a buzzin noise if not earthed
May 15, 2008 | Stanton Sk2f DJ Scratch Mixer - Good...
