Question about Canon NP 6050 Copier
Jamming at the registration
NP6050 just replaced the registration roller .and tried to test and kept jamming at the registration every time at the sam spot,
what am i over looking
thank you
  • 145 Answers
It stops at the reg flag,it seem like the sensor is not turning on,clutch was not replaced,j .did not take the drum out.and it jams from all trays .prior to replacing the roller i did get out of it 2 copys because the roller was so bad with flat spots.
what giude .and sepperation are you refering to?
thank you
Posted on Oct 02, 2008
  • Canon Expert
  • 1,326 Answers
Does it jam at the paper guides before the reg. rollers? Did you replace the reg. clutch? Also, dose it happen only with the LTR size only? Due the bottom 2 trays work & the by-pass? Also, have you made sure the OPC screw is tight? I think that it may be that your paper guides may be bent in-ward, by accident when unit one was removed.... I've done it a few times. Also, did you have the same problem before? Did you test the sensor and flag? It could also be a sepperation problem. You never said where it is stopping, at what exact spot is it stopping at?? Gave you a few ideas.... Get back to us with more info.
Posted on Sep 29, 2008
How to Problem detect & Solution for Toshiba e-Studio 232 Error Codes E210
Lower drawer transport jam (Paper not reaching the
registration sensor): The paper does not reach the
registration sensor after it has passed the 1st transport
sensor.
Open the transfer cover. Is there paper in front of the registration sensor?
?? YES ?? Remove the paper.
NO
Is the registration sensor working?
(Perform the input check in the test mode: 03-[FAX]ON/[2]/[A]
llllllll
NO ?? 1) Check if the connector of the registration sensor is disconnected.
2) Check if the connector CN305 on the LGC board is disconnected.
3) Check if the connector pins are disconnected and the harnesses are
open circuited.
4) Check if the conductor pattern on the LGC board is short circuited or
open circuited.
5) Replace the registration sensor.
6) Replace the LGC board.
YES
Are the (lower/middle) transport clutches working?
(Perform the output check in the test mode: 03-203, 205)
lllllllll
NO ?? 1) Check if the connectors of the (lower/middle) transport clutches are
disconnected.
open circuited.
open circuited.
5) Replace the (lower/middle) transport clutches.
YES
1) Check the condition of the feed roller, separation roller and pickup roller of each paper
source, and replace them if they are worn out.
2) Check the transport roller. Replace it if it is worn out.
Nov 16, 2017 | Toshiba Office Equipment & Supplies
Xerox 416 Work Centre Pro Paper Jam
You should first have a check over the roller . Mostly the problem will be the roller only .
But let me know how old is your copier ?
Depending on it we can solve your problem .
SAM ANDERSON
Sep 23, 2008 | Office Equipment & Supplies
Kyocera TASKalfa 3050ci Photocopier paper jam 0100
remove the fuser and look for paper between the induction and roller systems or wrapped around the fuser rollers
Aug 11, 2014 | Kyocera Office Equipment & Supplies
Take apart hp3005dn
Analyse what type of jam it is...based on that we can shoot the trouble.1. Paper is jamming before entry in fuser and its folds like curl in the cartridge area.. A. Fuser Teflon sleeve not rotating or slow rotation results media(paper)unable to reached the destination in specified interval. Replace fuser assm or Teflon sleeve.2. Paper jamming after fuser assembly crossed little bit ( approx 1-2 inch).A. Clean fuser out paper sensor, check sensor flag & flag spring located in fuser assm.3. Paper jammed after fuser crossed more than 6 inches..A. Check paper pick up roller warn out(tray1 or 2), check registration sensor located under registration assm.How to remove fuser assm: remove back door, see the snap shot...
Registration sensor location:
Pick roller roller tray 2 :
1_9_2012_3_54_49_pm.jpgPl try it carefully..Best of luck...
Jan 09, 2012 | HP LaserJet P3005n Printer
CANNON IR2016R WHEN I START AFTER INITIALIZING IT
7.2 Detecting Jams 7.2.1 Delay Jams 7.2.1.1 Delay Jam in Pickup Assembly 0010-4883 iR2016J / iR2016 / iR2020 / / iR2016i / iR2020i Delay Jam in Pickup Assembly The registration sensor cannot detect the leading edge of paper within the jam detection time interval after paper pickup started. T-7-2 7.2.1.2 Delay Jam in Delivery Assembly (Paper Leading Edge Jam at First Delivery Sensor/Wound Paper Jam at Fixing Assembly) 0011-0712 iR2016J / iR2016 / iR2020 / / iR2016i / iR2020i Paper Leading Edge Jam at First Delivery Sensor The first delivery sensor cannot detect presence of paper within the prescribed time after the registration clutch has been turned on. T-7-3 Wound Paper Jam at Fuser The first delivery sensor has detected absence of paper within the prescribed time after it detected presence of paper (within the prescribed time after the registration clutch had been turned on). T-7-4 7.2.2 Stationary Jams 7.2.2.1 Stationary Jam in Pickup Assembly 0010-4884 iR2016J / iR2016 / iR2020 / / iR2016i / iR2020i Stationary Jam in Pickup Assembly The registration sensor does not detect absence of paper within the prescribed time before the next leading edge of fed paper reaches the registration sensor. T-7-5 7.2.2.2 Stationary Jam in Delivery Assembly (Paper Trailing Edge Stationary Jam at First Delivery Sensor/Stationary Jam at First Delivery Sensor) 0011-0733 iR2016J / iR2016 / iR2020 / / iR2016i / iR2020i Paper Trailing Edge Stationary Jam at First Delivery Sensor The first delivery sensor cannot detect absence of paper within the prescribed time after the registration sensor has been turned off. T-7-6 Stationary Jam at First Delivery Sensor The first delivery sensor cannot detect absence of paper within the prescribed time after it has detected the leading edge of paper. T-7-7 7.2.3 Other Jams 7.2.3.1 Door Open Jam 0010-4886 iR2016J / iR2016 / iR2020 / / iR2016i / iR2020i Door Open Jam The door is opened when paper to be printed is in the paper feed path. 7.3 Cassette Pick-Up Unit 7.3.1 Overview 0010-4887 iR2016J / iR2016 / iR2020 / / iR2016i / iR2020i The paper picked up from the cassette is fed to the registration roller using the vertical path roller driven by the main motor (M204). The registration roller is not rotating when paper reaches there, so an arch is formed at the leading of the paper to prevent skewing. The DC controller PCB turns on the registration clutch (CL203) at the prescribed timing to transfer the main motor rotation to the registration roller, thus feeding the paper to the delivery tray through the transfer, sepa- Sensor/Solenoid Registration sensor (SR209) Pickup solenoid (SL202) Sensor/Registration clutch First delivery sensor (SR203) Registration clutch (CL203) Sensor/Registration clutch First delivery sensor (SR203) Registration clutch (CL203
Jan 04, 2010 | Canon iR 2016i Black and White Copier
Motor smells like it's burning. Upright Powerline Model 5847. Have kept filters clean and cut entangled hair from the rollers. Have had vacuum for about 5 or 6 years.
The burning may be coming from the roller drive belt if the roller is jammed due to debris build up or has seized roller end bearings. Remove the roller and belt and examine both for damage. The roller, without the belt, should spin freely by hand. Replace the belt if it has a burned spot as it will fail shortly. Hope this helps.
Oct 24, 2009 | Eureka Powerline Cyclonic 4484 Upright...
Brand new printer, paper stops in path
It's obviously not a brand new printer if the default has been changed, and if you're able to check that, then why not just try it?
But....
No, that wouldn't cause jamming, because changing the registration is simply changing the timing of the machine to move the image up or down the page, so regardless of the setting, it will still jam at the same spot. (I assume at the registration roller).
Is the paper setting set for the correct size and orientation of the paper you are actually using? That's what it sounds like to me. Otherwise, check paper switches.
May 21, 2009 | Ricoh Aficio SP C410DN Laser Printer
Paper jam in fuser
Sounds like a timing jam, check paper supply, fanned, good quality, check and clean paper feed rollers.
Registration rollers clean?
If you are a tech, check and clean paper feed clutches, registration clutch. Check fuser for bearings, fuser drive, fuser roller cleaner or worn rollers.
Check exit sensor, is it out of place, is the actuator worn out, is the paper curling and coming off of the paper too early,
Try these, hope it is of some help.
Ed
Apr 23, 2009 | Office Equipment & Supplies
Jam at registration roller?
I can tell you "exactly" where your jam is !
If you open the top cover and remove the imaging unit. Look straight down, and you will see a black rubber roller about 8 inches long. this is the registration roller. If you remove the four screws (two on the left side, one in the middle, and one on the right) and gently lift up your wrinkled paper will be right there. Since your are not replacing the registration assembly you do not need to remove the two connectors that attach to the main board from the registration assembly. Just remove the paper, reseat unit, and put back screws. There is a test to see if your unit has the fix that gives the drive assembly a little more power to aviod jams in the future. This is a software fix.
I believe it's available on the xerox website as a postscript snippet. xx.ps
Mar 17, 2009 | Xerox Phaser 6250 Laser Printer
NP6050 false paper jam
Can you see the paper pick-up rollers try to move and pick-up the paper? Or can you hear it make noise? Also, is the problem in paper tray 1? You may have to adjust or reform a inter lock arm on the right side door. If you push the back part of the right top door closer, will it feed the paper? If so there is adjustments for the door and look for a bent Tab on the hing part of the top door about half way up. Just a note have the paper pick-up & paper feed and paper sep rollers been replaced?
Dec 15, 2008 | Canon NP 6050 Copier
Canon NP 6050 Copier Logo
87 people viewed this question
old marine
old marine
