Question about RCA 35V432T 35" TV
RCA 35" no picture, clicking zapping sound
Our tv worked fine yesterday afternoon and we went to turn it on last night.
The screen is black and it is making a loud clicking, crackling, zapping sound. Is there anything I can do? Thanks in advance.
  • bludayc Sep 29, 2008
    Thank you so much! I will try it tonight.
  • bludayc Sep 30, 2008
    Thank you so much this worked! And now my TV works again.
    We didn't use a paintbrush, but we used a can of air and the vacuum like
    you recommended. Thanks again.
  • RCA Master
  • 5,568 Answers
What you are hearing is the discharge of high voltage which if it hasn't already failed, will fail if allowed to repeat too often.
The only thing you might try after unplugging the set for a minimum of 24 hours, is to remove the back shell (shouldn't be more than 8-10 screws around the perimeter and perhaps one or two around the connector cutout) and with a clean paintbrush and a vacuum cleaner with the nozzle held close to the work area, brush the CRT (picture tube) free as possible of accumulated dust, paying particular attention to the area around the large rubber cap with a cable leading to the circuit board.
I can't stress enough that the set must be ignored to allow the 25,000 plus volts that are present on the CRT when operating are given a chance to 'bleed off.' This voltage doesn't often kill anyone since it is a short-term discharge with the set off but I have seen it punch a hole through a thumb.
If you are lucky, the horizontal circuit is not in its death throes but only discharging through a layer of typical household crud. Unfortunately, this will not likely help you and you will require a tech to locate the problem. Good luck finding one that isn't dead or retired yet; we are dwindling.
Posted on Sep 29, 2008
Color gets blotchy, then goes screen goes black
The issue is with the color wheel but you have to replace the engine inorder to get one. The cost would exceed the value.
Jan 08, 2009 | Toshiba 46HM95 46" HDTV
I have picture and no sound
Try unplugging it for a minute. You will have to go through setup again (most likely).
Some of these sets have a (software?) issue and the audio drops out maybe once or twice a year-at least that's what I've experienced. No real fix for it.
Aug 01, 2008 | GE 35GT720 35" TV
RCA P61929 picture problem...
The TV was working fine, some time during the night the power went out, its plugged into a surge protector, everything else works fine, the TV won't turn on, the fuse is fine, is there a reset switch?
Dec 06, 2007 | RCA P61927 61" Rear Projection Television
Sound but no picture
Basic repair for skilled TV repairman = solder connections on
vertical output IC.........Can be done in home.....T.
Nov 28, 2007 | Sony KV-35S42 35" TV
Mitsubishi CS026201 TV screen problems
If the picture looked good last night
then the Tube is fine. The problem is
Power suply . I think there great tvs.
Made to last .a fair price for repair
is about 80.00-100.00
Nov 12, 2007 | Mitsubishi CS-26201 TV
No picture but sound works.....
  • adjust brightness setting when playing tv.
  • adjust screen control located on flyback transformer.
  • hope this will help.
Oct 23, 2007 | Sony KV-36FS16 36" TV
TV went out
Hey Jim, The high voltage protection circuit has gone out on the D-board and will need to be replaced. The fuse to the power supply is probably fine. A good repair tech shouldn't charge over $125 for this and it only takes a couple of hours. Let me know if I can be of further assistance.
Jul 17, 2007 | RCA F27242GY 27" TV
RCA 35V432T 35" TV Logo
195 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
