Question about Car Audio & Video
Need 2 know how 2 bypass e brake so dvd will play at all times
I have a 94 lincoln town car how do i bypass the e brake so that the dvd will play at all times?
  • chev2low98 Jan 26, 2009
    I need to know where to the run the wire that goes to the e-brake to bypass it so my tv will play all the time
    Problem Solver:
  • 6 Answers
Hi there . there is a separate wire to the brake so the screen does not come out now u have to locare that wire and send it straight to ignition and it will work while driving thankyou
KL
Posted on Sep 29, 2008
Fuse number for a 1992 lincoln
92-94 Lincoln Town Car Fuse Box Diagram - Auto Fuse Box ...
www.autofuseboxdiagram.com/8895-92-94-lincoln-town-car-fuse-box-...
Sep 11, 2012 - 92 94 Lincoln Town Car Fuse Box Map 276x300 92 94 Lincoln Town Car Fuse Box 92-94 Lincoln Town Car Fuse Box Map. Fuse Panel Layout ...
Aug 26, 2015 | 1992 Lincoln Town Car
I have a 94 lincoln town car.The gear shift wont go into gear. Nothing but play in the whole linkage
look under the hood on the firewall where the shift linkage comes through, the most likely cause is the rod popped off and needs to be re attached
Sep 23, 2011 | 1994 Lincoln Town Car
I HAVE A 1994 LINCOLN TOWN CAR SIGNATURE SERIES. I NEED TO KNOW WHAT KIND OF FRONT DISCS BRAKE PADS I NEED.
There are three kinds of brake pads,I prefer the middle ones,
1= cheap but wear fast
2=normal cost,and last about two to three years,
3=expensive,pads are ceramic and squeal coming to a stop
Jan 04, 2010 | 1994 Lincoln Town Car
I have a 1996 lincoln town car and the dummy brake light works signals and parking lights work the brake lights don't work?
check the brake switch located down at the pedal. Thhis is a button switch that allow the contact of the curcut so the lights go on. bypass this switch
Oct 31, 2009 | 1998 Lincoln Town Car
Need to know what trouble codes 33,42 and 75 mean on a 94 lincoln town car
i had a person bring a car in 2 my garage and say the exact same thing what it means is when you have anti-locking steering gauges you need to send this code in to your engine system 2 unlock it
Jun 25, 2009 | 1994 Lincoln Town Car
1999 Lincoln Town Car shifter stuck in park
Look at the swith on the brake pedal, it shoud have two green wires on it. Make sure it is not melted or the wire is broken. If it is damaged you can connect the 2 wires together to get it into gear, but this should be temporary as it bypasses the neutral safety switch.
Apr 16, 2009 | 1999 Lincoln Town Car
94 lincoln town car no brake lights or 4 way flashers
Your brake light switch went out it also controls the shift lock mechanism.
Its located on the brake pedal and costs about 15.99
Apr 04, 2009 | 1994 Lincoln Town Car
Dual xdvd700 want to permanently bypass e-brake
1. Ground the E-Brake wire.
2. Insert a DVD
Let it play until you hear sound
Press STOP twice on remote
Enter 26604
Press ENTER
Oct 27, 2007 | Jensen VM9510 Car DVD Player
Jensen vm9311
Need to know and bypass codes for the jensen 9311 but dont have the remote...
Oct 21, 2007 | Jensen VM9510 Car DVD Player
Parking Brake wire on Jensen VM9311TS
It may need to see a Positive....not a ground (the brake wire rests at ground and goes positive when the pedal is pressed). but to answer your question, the brake wire for your car is Light Green and is at the brake switch above the pedal.
Sep 19, 2007 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
Car Audio & Video Logo
363 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
