Question about E-Machines etower 667ir PC Desktop
Etower 667 need to know what the internal battery should be , dont know what type of motherboard i have ` won,t boot to bios
  • 218 Answers
Nearly all computers made in recent years use a CR2032 battery. You can pop the old one out to make sure, but if it's about the size of a quarter this is probably it.
Posted on Sep 29, 2008
Need BIOS password for Packard Bell R1938 notepad
If you don't know the password, you will need to make an BIOS reset. You must open your laptop, and find the internal battery in the motherboard. Take it off, for 10 seconds, without any power cable or battery on. After that, put the internal battery in his place, and turn on your laptop. It must open the BIOS without password needed.
May 06, 2013 | Packard Bell Computers & Internet
I have a Lenova laptop and a intel MB I am having a problem. Trying to login but the supervisor password won't let me in no matter what i try Lenova G550 2958
When you boot up to the log in screen type in administrator as user to log in if you cant log in
during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there
also
The most common way that we know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing the Cmos battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased. Hope this helps
Aug 13, 2011 | Intel Motherboard
I have problem I need password for TOSHIBA MK2565GSX..THX
also
Jul 21, 2011 | Toshiba MK2565GSX Hard drive 250 GB...
Date problem
When the Date and time error message comes up during booting up the computer, it means the BIOS requires configuration.
If this occurs every time you boot up your computer after changing the Date and Time then, this is caused by a flat BIOS battery.
The BIOS battery is ususlly a 20mm dia. 3 volt lithium battery type CR2030
Replace the BIOS battery and then configure the Date and Time and you won't get this error again.
May 14, 2011 | Computers & Internet
I need bios password for second/third hand dell latitude 131L laptop service tag is 92VRFD1 can you help
Press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there
also
The most common way that most of us know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing a battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off the battery power, the BIOS/CMOS settings will be erased.
cmos battery Under the keyboard or bottom of laptop - If you are working on a laptop computer the location of the dipswitch (almost never a jumper) can be under the keyboard or on the bottom of the laptop in a compartment such as the memory compartment.
hope this helps
dont forget to vote
Feb 21, 2011 | Computers & Internet
Motherboard Micro-Star International co. Ltd Model Z3-7529 SMBIOS Version V3-0B1 I am using Intel dual core E2180 2GHz with 1GB 667 DDR2 RAM after adding Kingston 2GB 800 DDR2 Total 3GB RAM , But...
First remove the 1 gb ram (667)
May be your hard disk has bad cluster,Or infected with virus
You can regenerate the hdd with out any data loss.
If you regenerate,your file can not delete.
Dont PANIC,
just follow the step.
I am ussing it alwayas.
Download the iso file from =http://www.fullandfree.info/software/hirens-bootcd-v100/
Write the iso from any nerro burner , through image burning option.
There are so many user mistake it.
Boot from cd
DONT PANIC follow all the steep It is very simple. (Use the down arrow key.)
1.INSERT CD TO CD TRAY
2.Boot from cd
3.Select start boot cd
FOR REPAIR THE HDD DONT PANICI
Choice hard disk tools
1.select HDD regenerator>enter
wait create it auto mode
2.Enter(If you have one HDD)
3.Press "1"ENTER for scan and repair (With out lose any data)
4. press 3 for REGENERATE ALL SECTORs
I will sugest press for "1" and enter
press( 1-9 )any one number and type mb and ENTER
Repair will Start soon.
Hope it helps
Jan 11, 2011 | Intel Motherboard
I updated BIOs and now every thing is gone.
Okay, sounds like your BIOS upgrade went south. First off, re-install the original BIOS. Usually you back up the original before upgrading. Either that, or d/l the original BIOS from emachines.com. Once you've got the BIOS working, try starting the system. I'll need to know more to help you from there.
Feb 21, 2009 | eMachines etower 466id PC Desktop
How can i run 1 or 2 DDR2pc8500 1066Mhz on a asrock 775dual 880pro< it booted,went to bios to down the speed to 667, but when windows(XP) tried to boot it went to a blue screen saying things about memory...
your motherboard supports DDRII 667/533/400 and DDR400
1066 is not supported, I have never tried to use a unsupported memory speed on a motherboard so I don't know, I know you lowered it to 667 but still the ddr2 which you have bought is not supported by default.
why buy too fast memory?
Oct 21, 2008 | Asrock 775Dual-880 Pro Motherboard
E-Machine W2060 Password issue
Hello, First you need remove password of bios. Open inside case remove battery turn on then turn off PC get back battery. If it will not help, try find slot with 3 pins 2 of them connected with each other, remove connector, turn on/off PC get back connector.
Then you need reset password of windows it is very hard you need hack it. Download it form file manager, press free, wait and download link: click
As you see file is ISO formatted and you need write it to CD disk.
Then boot from your CD and follow the instruction.
Sep 08, 2008 | E-Machines etower 633id PC Desktop
E-Machines etower 667ir PC Desktop Logo
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
