Question about Kenmore 72189 Air Conditioner
No air conditioning
We plugged it in and it feels like a fan not air conditioner. We checked the settings and it is on air condition not fan and when we turn the speed of the fan up it stays the same. We bought it at sears and it was listed as used and had a manual but it appears to not be for that model. What should I do or is there something that I should have done but did not because I had no directions.
    President:
  • 1,314 Answers
Well why is it listed as used should have been returned listed lets say some one turned it on and it didn't cool and brought it back well it is used but didn't work if its under warranty call for service or return your self make them give you a new on
but if not open the case and check the connectors on the compressors terminals let me know what you find
Posted on Sep 29, 2008
Pro Standard Fan mount
Since the failure of an air conditioner to turn on, loss of air conditioner cooling capacity, reduced air conditioning output temperatures, loss of cool air supply, or even loss of air flow entirely can be due to a variety of problems with one or more components of an air conditioner or air conditioning system, after reviewing the lost air conditioner cooling diagnosis procedures described in this article, be sure to also review the diagnostic procedures at each of the individual air conditioning diagnosis and repair major topics listed just below. To return to our air conditioning and refrigeration home page go to AIR CONDITIONING & HEAT PUMP SYSTEMS.
Electrical problems on HVAC systems: Keep in mind that despite the depth of technical detail you will find here about all components of air conditioners and heat pumps, most service calls for non-working air conditioners or heat pumps turn up an electrical problem. So if your A/C system is just not working at all be sure to check all of our electrical and control setting suggestions first.
Mechanical problems on HVAC systems: tend to fall into these groups: refrigerant leaks, dirty condenser coil or unit, dirty evaporator or cooling coil, or burned out (or hard-starting) compressor motors. We have also seen a number of problems with fans and fan motors in both the compressor/condenser unit and in the air handler/blower fan unit. Some of those fan problems are mechanical - like a loose fan belt or blade. MORE DETAILS
Nov 13, 2012 | Heating & Cooling
Mec portable air condition shows E5 on the screen after i on the air cond about 15-30minutes. Once it showed E5, cool air was not feel but just like fan air. what is the problem?
MEC portable aircond show P1 after on in a 1 and half hour. Once it showed P1, cool air was not feel but just like fan air. what is the problem?
Jun 02, 2012 | Heating & Cooling
Air conditioning is not engaging when button is pushed to turn on.
Air Conditioner No air coming from air conditioning vents
  1. Check the air conditioner fuse and replace as necessary.
  2. Air conditioner system discharged. Have the system evacuated, charged and leak tested by an MVAC certified technician, utilizing approved recovery/recycling equipment. Repair as necessary.
  3. Air conditioner low pressure switch defective. Replace switch.
  4. Air conditioner fan resistor pack defective. Replace resistor pack.
  5. Loose connection, broken wiring or defective air conditioner relay in air conditioning electrical circuit. Repair wiring or replace relay as necessary.
May 31, 2011 | 2007 Buick Terraza CXL Wagon
Thermo set "heat" and "Auto
Check the fan relay. These relays are used to cut the fan on and off when the thermostat is set in the air conditioning or heating mode or when you move the thermostat to the "Fan On" position. The low voltage usually the green thermostat wire is wired to terminal #1. The low voltage common wire to terminal #3. One line voltage wire is attached to terminal #4. The high speed blower wire usually black is attached to terminal #2. When the thermostat calls for air conditioning or "Fan On" the 24 volt coil is energized, the terminals 4 and 2 close. This causes the fan to come on in high speed. When your home cools down and the thermostat cuts the air conditioner off, the low voltage coil terminals 1 & 3 are denergized, and the fan goes off. Sometimes these little relays stick which causes the fan to run all the time or will not make good contact, which causes the fan to not run in the "Fan On" or air conditioning mode.
Nov 16, 2010 | Weather King 10AJA6001AH Air Conditioner
Do not feel air flow from ruud air conditioning
Problem can be several things. Check air filter first. If filter is clean, contact a licensed air conditioning contractor.
Jun 06, 2010 | Ruud UAMB Air Conditioner
Setting air condition for 1st time
Check whether you have set the OFF timer.
Check thermostat / thermistor.
May 26, 2010 | NewAir ACP-1000E Portable Air Conditioner
Heater air conditioner unit does not expel air
unless you have zones installed i.e. day and night you will probably find that the main duct off the unit has fallen off
Jun 15, 2009 | Heating & Cooling
Fan setting only works
Air Conditioners have a fan speed relay built in the unit, faster for cold air and slower for warm heated air. It is very possible that your relay is defective
Oct 20, 2007 | Ruud UAMB Air Conditioner
Air condition won't work
THE CLICKING SOUND IS A RELAY PULLING IN ITS LIKE A SWITCH CONNECTING TWO WIRES. THIS IS A GOOD SOUND BUT IS USALLY FOLLOWED BY SOMETHING COMING ON FAN ETC... CHECK TO SEE IF YOUR UNIT HAS AN LED LIGHT ON IT AND HOW MANY TIMES IF ANY DOES IT BLINK?
Jun 08, 2007 | GE AGM24DJ Electronic Room Air Conditioner
Kenmore 72189 Air Conditioner Logo
62 people viewed this question
Top Kenmore Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
John Tripp
John Tripp
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
