Question about Epson Stylus 1400 InkJet Photo Printer
Power and ink light on steady
I have a bulk ink system on the 1400 and the monitor shows all cartridges are empty. Have used this ink system for months with no problem. Any ideas.
I removed the bulk cartridges and installed the original cartridges, then powered up the printer. Reinstalled the bulk cartridges.
Posted on Oct 01, 2008
My printer is not HP it is Brother MFC-260C
The printer uses several ways to show ink levels. When you replace the cartridge it askes if it has been replaced, Say yes and it sets the ink level monitor to full. As the cartridge empties it them checks through an electronic eye system through the cartridge. When it cannot see any ink it says it is empty.
Replace the cartridges and it should fix the problem.
Feb 22, 2016 | Brother MFC-260C All-In-One InkJet Printer
I have a canon mg5320 printer. I just filled 4 of yhe 5 cartridges but it still shows them almost empty, what can I do?
This is perfectly normal. Your printer has no idea you filled the cartridges. Keep using the printer - until it stops with 'ink out' error, then press the 'OK' button (on printer) momentarily. If that clears the error, you can resume printing.
If pressing OK doesn't do anything, press and HOLD the 'STOP' button for about 6 seconds - or until the error clears. This will disable the ink monitor - for the 'empty' cartridge.
You will have to repeat same process for each cartridge that turns 'empty'. Once all cartridges are disabled, you don't have to do anything - except keep refilling the ink.
You can find more info on this here:
Canon ink level monitor ink tanks how to disable
Feb 27, 2015 | Canon PIXMA MG5320 All-in-One Printer
How to read ink levels in an epson nx110
All Epson printers (well, the ink ones) have a small utility built-in called the STATUS MONITOR. If you click on the MAINTENANCE tabbed page in the Properties, you can start this just by clicking on the item. It will show the ink levels. Normally, this status monitor should start up whenever you print - with an option to show the ink levels, as they do not auto appear when printing, compared to the option shown above. Note that the monitor does NOT actually shown the real ink levels as the chips on the cartridges and the internal electronics within the printer simply work on the number of prints made - so often when showing empty - there will in fact be ink left unused inside the cartridges. For this reason alone, worth your while getting some refillable cartridges and bulk ink (normally in 100ml bottles - so you would get equivalent about 10+ refills and save lots of hard earned dosh!) but you would also need an inexpensive chip resetter. My advice is get the refillables with ink (most compatible inks are as good as - some better - than Epson's own expensive original cartridge inks) and when one cartridge shows requires replacing, you remove all the cartridges, fill them all, reset the chips and replace - that way you show all as full and on ly have one cleaning cycle - thus also saving lots of ink normally wasted when replacing one cartridge - each requiring a cleaning cycle and loss of other inks. I have no idea where in the World you live so cannot recommend a supplier - just use or to find suitable suppliers convenient to yourself.
May 29, 2014 | Epson Stylus Multifunction Inkjet Printer/...
How can I stop ink spots on photos and documents?
Ink leakage can occur if the bulk ink reservoirs are at a level above the printer. Let the two in the same level.
This can also occur because of quality of paper or ink.
Apr 11, 2012 | Epson Stylus 1400 InkJet Photo Printer
Need to change ink catrege help
Using the printer's control panel In some circumstances, you may need to replace an ink cartridge before it is empty.
If the fonth.gif ink out light is flashing or is on, replace the empty ink cartridge as described in Replacing an Empty Ink Cartridge.
To replace an ink cartridge before the fonth.gif ink out light flashes or the Status Monitor notifies you that the cartridge is empty, follow the instructions in this section.
r_caut.gif Caution: r_space.gif Do not remove the cartridge from the printer until you are ready to replace it with the other one.
r_1.gif Make sure that the printer is on. The fontp.gif power light should be on, but not flashing.
r_2.gif Lower the output tray, then open the printer cover.
r_3.gif Press the fonth.gif ink button. The print head will move to the ink cartridge replacement position, and the fontp.gif power light will begin to flash.
r_space.gif r_note.gif Note: r_space.gif r_space.gif Do not press the fonth.gif ink button over three seconds. Otherwise the printer starts cleaning the print head.
Jun 13, 2010 | Epson Stylus CX6600 All-In-One InkJet...
Ink level indicator is showing empty, but just recently replaced
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink or toner cartridge?
Please consider the following:
If you are using a refilled or third party cartridges that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks or toner causing problems with print quality or damaging the physical printhead or photo conductors.
If you are using factory new ink or toner cartridges, then please call the manufacturer’s Technical Support for assistance with the warranty on the cartridges
Feb 22, 2010 | Canon PIXMA MP460 All-In-One InkJet...
Epson *******.. it won't let me printing with only black ink when another ink is empty
The ink cartridge is empty when the associated INK OUT light is showing a steady red light upon powering up your unit. The printer is now in an offline state and you are not able to print in any color. This is a protection feature of the printer, to prevent air from being pumped through the printhead that has no ink.
Jul 25, 2009 | Office Equipment & Supplies
Light cyan ink didn't work on epson 1400
Get yourself a couple of sets of empty cartridges from
It is so easy to fill your own from the removable rubber cap, on the top of the cartridge. Not to mention what you will be doing for the environment.
I have been using these for over a year and have saved a ton of money
This man also sells the ink that you will need. ALSO tell him to send them empty, otherwise he will automaticly send them full of "pigment "ink, because you want to use an ink dye
Al C
Jul 22, 2009 | Epson Stylus 1400 InkJet Photo Printer
Red light on steady
If the ink light is on steady red, that means the black or color ink cartridge is nearly empty. Obtain a replacement black or color ink cartridge. To know which cartridge is out of ink, check the ink levels using EPSON Status Monitor 3 (Windows) or EPSON Status Monitor (Macintosh). If you just replaced the cartridges before you got the error light, that means that the replacement cartridge is not recognized by your printer. Please reseat cartridges. Then turn the printer on and off. The cartridges maybe bad also.
If the paper light is on steady red, try to reload 10-20 sheets of regular paper into your printer. When printing on CD/DVD, CD/DVD tray is not inserted in the printer. Insert the CD/DVD tray in the printer and press the paper button.Could also be that the printer has loaded more than one sheet of paper at a time. Load paper in the sheet feeder, and then press the paper button to resume printing. If the CD/DVD guide is open, close the CD/DVD guide, load paper and then press the paper button.
May 17, 2009 | Epson STYLUS R230 InkJet Photo Printer
Epson Stylus  1400 InkJet Photo Printer Logo
176 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
