Question about Kenwood Car Audio & Video
Hooking up 600 watt KAC-829 amp stereo bridgeable amplifier
  • 5 Answers
SOURCE: 600 watt 2 channel power acoustik sterling amp
On your amp, there should be a switch (on the side probably) that has "LP", "HP", and "FULL" or "OFF". This is a switch for the low pass/high pass filter. Switch it to "LP" as this will allow only low frequencies to go to your subs, what you want. If you don't have that switch, go to an audio store or online audio supplier and get either a low pass filter, band pass filter, or a cross-over, and follow the wiring diagram that comes with it to filter out the high frequencies before they get to your subs.
Posted on Oct 09, 2007
blueextc3221
  • 15935 Answers
SOURCE: orion xtr15 to a american leagacy la 660 amp
your only choice is to run the amplifier at a 4 ohm mono load - this will not reult in the amplifier making much power.
Positive on sub to Positive on amp.
Negative on sub to Negative on amp.
This is your only possibility.
Adding a second sub in the same fashion will result in a 2 ohm load, and your amplifier will run at its rated potential.
Thanks for using FixYa - a FixYa rating is appreciated for taking the time to answer your FREE question.
Posted on Mar 05, 2009
Boole5555
  • 160 Answers
SOURCE: kicker subs hook up problems
Connect one to each channel, for the best sound.
Posted on Jan 05, 2010
Testimonial: "thanks"
drsinister69
  • 2317 Answers
SOURCE: I have two Kicker DVC CVR's 12's and I want to hoo...
The best thing to do would be to get an amp installation kit, at an auto stereo store or Wal-Mart automotive department. It will have the wiring and connects that you'll need to wire everything up.
Posted on May 22, 2010
  • 6 Answers
SOURCE: how do i bridge my
Easy, you grab a dual wire cable (like the one in the back of your amp that runs to the speaker) and stick each wire on one end to the positives on your amp. Then, on the other end, twist both wires together to form one wire. Hook it into your positive connection on the sub(s). Repeat on negative side.
Posted on Aug 09, 2010
2 12" subs + 600W amp. Turn on, goes boom once, then red light
Is your gain all the way up? If it done this before, sounds like your over working the amp. Make sure your subs ohm load is capable with the amp load to. If they are 1 ohm and your amp is only 2 ohm stable, it would beat for a lil bit then go into protection mode to. Check your wires too.
May 13, 2010 | Insignia 600W Bridgeable Amplifier with...
Car audio amplifer blowing fuses
why are you in stereo for subs? mono all the way.
Feb 21, 2010 | Kenwood KAC-7252 Car Audio Amplifier
I dont no how many watt my amp has
Hi and welcome to FixYa,
To my understanding, a Kenwood KAC-628 is rated with max power of 100 watts X 2 at 4 ohms per channel. Incidentally, it is bridgeable resulting to 300watts X 1.
Good luck and thank you for asking FixYa.
Dec 23, 2009 | Kenwood Car Audio & Video
No manual for my amp.
  • Class-D Monoblock Amplifier
  • Bass Boost Level and Frequency Remote Included
  • Variable Low-Pass Filter: 50 - 200 Hz (24 dB/Oct.)
  • Variable Input Sensitivity: 200mV - 5V
  • Phase Shift: 0° / 180°
  • Variable Infrasonic (Subsonic) Filter: 0/15Hz/25Hz (18 dB/Oct.)
  • High- and Low-Level Inputs
  • 1 Ohm Stable
  • RMS Power Output:
    • 500 watts x 1 chan. @ 4 ohms
    • 900 watts x 1 chan. @ 2 ohm
  • Preamp Outputs: 1 Pair
  • Bass Boost: 0 - 18 dB @ 40 - 100 Hz (Variable)
  • Dimensions: 15" L x 11-5/16" W x 2-3/8" H
Oct 05, 2009 | Kenwood KAC-9152D Car Audio Amplifier
I got a 4 gauge power wire w a 20 amp fuse hooked up to a kenwood stereo/bridgeable amp 350 watts max power model #kac~6295 it just dnt sound rite any sugestions?
make sure you run your power and ground wires opposite of the rca/speaker wires. you tend to pick up alternator noise when all wires are bunched up together. Also, make sure you have a good chasis ground to the amp, and the stereo has also a good ground. good luck
Sep 04, 2009 | Car Audio & Video
Is it not bridgable
This amp isn't bridgeable. It's a mono amp (only one channel). You need two independent channels to bridge. Some mono amps are bridgeable if you have two identical amps but I don't think Kenwood recommends that with this amp.
Jan 27, 2008 | Kenwood KAC-9152D Car Audio Amplifier
600 watt 4 channel bridgeable mosfet power supply jensen amp
Swap the wires from one speaker to the other to see if it is the speaker or the Amp/wires.
Oct 23, 2007 | Jensen A600HLX Car Audio Amplifier
Car Audio & Video Logo
78 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
