Question about Hotpoint DY46 Style Line Stainless Steel Electric Double Oven
I can't find the model no. on my Hotpoint Ovan!
My oven went to the hurricane without no apperant damage but on the display panel, it says FFF and my oven want come on, I can't set the clock or use any other features. I would be very grateful if someone could help. Thank You Anthony
  • ItalianoT Sep 29, 2008
    Thank You Krazytech, I tried your soloution with no luck, I can't tell if it has a reset button and where would the control be, is it behind the control panel? Thanks again
  • 725 Answers
FFF Control Error, Failed EEPROM Replace Control
You can try a hard reset . turn off the power for 1 minute.. also you can check the connections to the control .. other then that you will have to repalce the control
Posted on Sep 29, 2008
Can you diagnose the fault & advise me how to fix my hotpoint electric cooker please?
This video shows how to test and replace the faulty heater element on the fan oven on a Hotpoint double oven.
Sep 26, 2015 | Hotpoint Ovens
I have a Maytag Electric Range model MER5755QAW. It was obvious that the heating element was bad, you could see the area where it had blown out. I have replaced the heating element, and the oven will...
Just went thru this with my GE/Hotpoint oven....the oven temp sensor removed from oven should measure about 2K ohms and vary when put in ice water and hot water...if it does then problem is control panel circuit board.My oven's board was listed at $300+ so I bought new range ($500+).
Oct 14, 2013 | Ovens
Error 08 on my hotpoint ovan workes for a bit then goes off and sayes error 0 8
HELLO.
The code displayed on the oven indicate that the oven has detected an error from the source of power control (panel).
This problem can be as a result of over flow of water or liquid substance on control unit,
or when there is over flow of power supply on the oven.
when the door of the oven is not properly close etc these can be as a result of the error code displayed on the screen of the oven.
WHAT YOU NEED TO DO TO SOLVE THE PROBLEM OF THE CODE DISPLAYED ON THE OVEN,
is to off and unplugged the oven from power supply for something then plug it and allow it to load on power on it's own before any form of operating then push the reset button if any.
With this the problem of the code will be solve
If there is a need for further help get back to me with your comment.
THANKS.
Sep 18, 2011 | Ovens
We were without electricity for 2 daya following hurricane Irene. When power was restored, the oven display (time, temp, etc) did not come back on. The oven lights come on when the button is depressed. and...
Try turning off the circuit breaker to the oven for 30 min or so and then turn it back on. If it does not come back on the oven probably got a power surge and the control has been damaged. Hope that helps
Aug 30, 2011 | Whirlpool RBD305PD Electric Double Oven
Top ovan will not start when I put ovan on the blower does not wo
the problem is not the motor. You have a problem with the door switch or the operator interface.
May 04, 2010 | Bosch HBL 455 Stainless Steel Electric...
The control panel went dark. Can only read it
Not sure on the make but it appears that the timer clock display is failing. Replacement cost is typically £80 but without the make i cannot give you a accurate costing. Fitting would be extra.
Regards
Aardvark Repairs
Nov 16, 2009 | GE Profile JTP56 Electric Double Oven
Hotpoint self-cleaning oven will not release door latch and open.
no you will have to replace the catch if its more than 20 years old maybe you should think about buying a new oven
Sep 27, 2009 | Hotpoint DY46 Style Line Stainless Steel...
Supressor, transient
Hello hward,
Welcome,
You said, Hello from Baton Rouge, La. just recently nailed by Hurricane Gustav.......
during the hype of the storm, I think my wife's double oven took a electric surge and started smoking. I visually inspected the damage and saw a badly burnt and scarred flat saucer looking component (suppressor, transient)...I have ordered a replacement part and would like to know if you think that replacing this item will be all I will need to do..
If the range was under water I do not think this will be the only problem.
I believe it will cause you endless problems if it got submerged!
you may end up replacing this water logged unit!
Huuum
Thank You ,Please remember to leave a rating
Sep 07, 2008 | Whirlpool RBD305PD Electric Double Oven
Beeping sound and f8 displayed
F8 means to replace the elctronice range control board. Evidently the power failure caused damage to the board.
May 24, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Hotpoint DY46 Style Line Stainless Steel Electric Double Oven Logo
141 people viewed this question
Top Hotpoint Ovens Experts
bosch5
 Fix Your Board
Fix Your Board
Chris Hall
Chris Hall
Are you a Hotpoint Oven Expert? Answer questions, earn points and help others
