Question about Philips HTS-6500/37 System
FB 201 PHILIPS MAGNAVOX HIGH POWER SUBWOOFER
When hooking up system does subwoofer have speaker wire connections, and if so, to what? I mean aside from the two cords that run from it. Help please. We have no manual. THANK YOU
  • Anonymous Mar 24, 2009
    explain how speaker wires should be hooked up
SOURCE: find dvi cable: links dvd to subwoofer
u need a 15 pin vga cable male/male just got one today
Posted on Nov 29, 2008
easyq
  • 144 Answers
SOURCE: Sound from 3 channels only
Hi, first of all did you verify with the manual if it is possible to run a testsignal through all 5 channels?
One of the most common problems in this case is the basic settings of the device. If you don't have the manual, mostly you can download them from manufacturers website. Chances are that for some reason the setting is set 3.0 stereo (also known as 3channel sound) which is always the 2 fronts and the centre speaker.
Best thing to do it is take a DVD with THX on it and run the THX setup, it will send test signal to all channels.
Posted on Jan 15, 2009
ThaMp3Doctor
  • 8596 Answers
SOURCE: i have the philips hts3440/37 none of the speakers work.
Doubtful that it is as serious as a fuse, unless it was working before and now it's not.
Are you getting no sound when watching DVD's? Try adjusting the volume on the home theater system - press the SURR button until it says "Dolby" or something like that.
Make sure it is connected like this:
Posted on Feb 21, 2009
  • 6 Answers
SOURCE: Info on the SW9800 Subwoofer
I need that junction box too, som one have?Please
Posted on Sep 11, 2009
SOURCE: I have a Philips home theater HTS9810 and the
where did you buy the HTS9810 I have been looking for it everywhere
Posted on Feb 24, 2010
The wires from Line level converter where to hook them up?
Firstly, and definitely, your "black" is subwoofer line out.
Check your AV receiver if the subwoofer option is activated. I've known some receivers that have the option to disable subwoofers and push all the bass into their front speakers.
Next, you have to check if your subwoofer is on or off? what about the volume of the sub?
If your subwoofer is passive, which means it does not require powering up using the mains, then you will have to get a seperate amplifier to power the sub up.
Jun 05, 2012 | Cerwin Vega Audio Players & Recorders
When I hook up the speakers in the back to the left and right side for the in and out, do I connect the front or rear speakers. do the speakers connect to the subwoofer first then to my receiver or the...
I was trying to find an owner's manual or picture of the rear panel of the sub, but had no luck. The subwoofer is a powered type - or "active" speaker. This means it has a built in amplifier. These active subs usually provide for one or both "low level" and "high level" inputs. Low level signals are usually carried by shielded coaxial cables and have RCA type plugs on the end. The low level is also called "line level". This is an un-amplified signal that might be heard on cheap earphones - but that's about it. It is similar to the output of a tape deck, DVD or phonograph. These signals require an amplifier to be heard. If you have a sub woofer output on your receiver or amplifier, you could run a patch cable between the low level input on the subwoofer and the subwoofer output of the amp or receiver. You receiver or amp may call this output "low frequency effects" or similar. The front and rear speakers would then connect directly to the receiver or amp's corresponding connections.
If you lack low level outputs on the amp or subwoofer, you'll need to run speaker wires from the amplifier or receiver's front left and right speaker output terminals to the subwoofer's high level input terminals. High level signals are speaker connections or amplified signals. These are typically connections that accept bare wire connections. The front speakers would then connect to the subwoofer's front left and right speaker output terminals. The rear speakers connect to the amplifier.
I hope this helps - and good luck!
Nov 24, 2010 | Cerwin Vega AVS-632 System
I need pinout assignments for a Philips 5.1 Home Theater Speaker system (PWR2006-37)? It has a DB-15 style input connector that hooks to the output of a Philips dvd / amp / control unit. this was...
Pin assignment is as follows (not sure of levels required- preamplification / attenuation may be necessary:
1: Control 0/5V.
2: Unused
3: Unused
4. Center speaker in
5. Ground
6. Ground
7. Subwoofer in
8. Ground
9. Unused
10. Ground
11. Left Front speaker in
12. Right Front speaker in
13. Ground
14. Right surround (rear) in
15. Left surround (rear) in
Jul 10, 2010 | Philips DVP642 DVD Player
I have a pyle blue wave 12inch 800w subwoofer for a car hook up?
that just means it is dual channel.
if you have a stereo amp just run the left wire to one terminal and the right wire to the other terminal.
if your amp is mono run the wires to the first terminal and then from there to the second set of terminals.
PLEASE NOTE that by doing that you are bridging the speaker if the speaker was 4ohms to start with you just dropped it to 2 ohms so make sure your amp can handle that.
Dec 24, 2009 | Pyle 12" Molded Blue Cone High Power...
I have a subwoofer with standard speaker wire connection, how to I attach to a receiver with a subwoofer cable?
The Subwoofer is Likely Passive....meaning no amplifier is within the enclosure itself....the incompatible connectors mean you cannot connect the subwoofer itself to your surround sound system.
look for a Suitable stand-alone (1 Channel) Amplifer with sufficent power.....connect the RCA Imputs (subwoofer cable) to the Recievers RCA subwoofer output....then connect the amplifier's output to the the wire going into the subwoofer enclosure....if there is a plastic connector simply cut it off and strip the wires down a sufficent lenght....then secure the wires to the output of the amplifier.
if you do this make sure you know the ohm rating of the subwoofer and the minimum ohm rating of the amplifier your using.
Nov 24, 2009 | Sony BRAVIA DAV-HDX267W Theater System...
Connect powered subwoofer
  • If your receiver has a dedicated subwoofer line level output, we recommend connecting your subwoofer to this jack. Most receivers will have just one (mono) subwoofer output, while quite a few subs require two inputs. You can use an RCA "Y" adapter cord , which is a cable with one female RCA jack at one end, and two male RCA plugs at the other. Some receivers require menu settings (such as "sub-on" or "front speakers-small") that must be made before the sub output will be active.
  • Nov 22, 2008 | Audio Players & Recorders
    HTS3440 Philips No Sounds from Subwoofer
    check the wire connections....and check the settings in the player..
    Nov 08, 2008 | Audio Players & Recorders
    Subwoofer will not work when connected
    cheak setting in sterio out put for sub on ect does woofer have sperk wire going in and out use them then ok
    Feb 11, 2008 | Velodyne CT-80 Subwoofer
    Lost instructions
    The 'Subwoofer' output on your receiver is used to connect to a powered subwoofer with a built in amplifier. Your KLH speakers use what is called a 'passive' subwoofer, it gets its power from the receiver and then passes the higher frequencies to the left and right front speakers after taking out the low frequencies for the subwoofer. A speaker system with a passive subwoofer is good for casual listening, but a powered subwoofer is required for really hearing low frequencies and rumble in movies. The KLH speakers you have were highly rated in their time for their price. The four satellite speakers and center channel speaker have very good sound compared to the little 'midget' surround sound speakers most people buy today.
    Here's how you hook them up:
    - The left and right front channels from your receiver terminals should go to the terminals on the subwoofer marked 'From Amplifier'
    - Your left and right front speakers are then connected to the subwoofer terminals marked 'To Speakers', they do not connect directly to your receiver.
    - Your center speaker is connected to your receiver terminals marked 'Center'
    - Your rear speakers are connected to your receiver terminals marked 'Surround'
    That should get you up and running. If the bass isn't good enough with the passive subwoofer, you can get a decent powered subwoofer like the Velodyne VX-10 for about $150 and 'kick it up a notch'. Good luck and enjoy....
    Jan 07, 2008 | KLH HT-9900 System
    Philips HTS-6500/37 System Logo
    1,811 people viewed this question
    Top Philips Audio Players & Recorders Experts
    Gyula Lacz
    Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
