Question about Sony Handycam DCR-HC21 Mini DV Digital Camcorder
Handycam dcr hc21e lcd display not working
The lcd display is not working. It started with the lcd functioning only when you open it half way and later nothing appears on the display
  • 5 Answers
SOURCE: Blank screen
Hi: Check and see if there is an X as in escape out of the Menu Mode. If there is no X,then look fo OK. Good Luck. zeffy57.
Posted on May 29, 2007
  • 169 Answers
SOURCE: sony dcr hc32 LCD not working
the flexwire of the lcd monitor of your camera is already cut.....it have to repair or replace now cause that wire is very small and only skilled technician can repaired it...lot of our customer it is the common problem of there camera that why in our shop we modified that and became more durable than the original wire....
Posted on Sep 02, 2007
SOURCE: Touch Screen not responding to Touch
this sucks balls
Posted on Jul 02, 2008
  • 9 Answers
SOURCE: Handycam DCR-HC21: LCD touch keys does not work
try alamocamera.com for repairs
Posted on Jul 30, 2009
welcomejee
  • 10594 Answers
SOURCE: LCD screen not working on my Sony handycam dcr
Usually there is flexible wire between lcd board and main board of camcorder that got broken and resulted lcd does not work.
You need to replace that flexible wire by qualified camera tech.
Thanks.
Posted on Sep 20, 2009
Tip
LCD Side Screen Display Not Displaying
I managed to strip the digicam and found the MAIN FEED RIBBON CABLE DAMAGED du to normal open & close and turning of the sidescreen.
Replaced ribbon cable. PROBLEM SOLVED.
Hope this may help.
Aslam
on Feb 13, 2008 | Sony DCR-HC21E Mini DV Digital Camcorder
I cant conect in pc my web cam sony dcr hc21e handycam i have windows 7
Right, well your problem is very common, it is due to Windows 7 (I have it) not having very many drivers built-into it for cameras, and my own Sony camera driver is not in 7 either ok. So you are going to have to download your films from camera to PC with a cable called Firewire because USB cable wont work without windows drivers, firewire will.
Lets just hope your PC if it is not old has a Firewire socket at rear, as older PC wont have one.
May 24, 2010 | Samsung SONY Handycam DCR-HC21E MiniDV...
Buttons on touch panel of my DCR-HC21e Sony Handycam stopped working.
This fault is often caused by a failing flat cable that connects the LCD panel and the rest of the camera. In its early stages it is possible to get the buttons on the touch panel to work by carefuly changing the angle of the LCD panel while trying out the buttons until you get a position where they work.
When the flat cable gets worse , the picture on the LCD panel will start deteriorating and go off altogether.
At this stage you may consider having the flat cable replaced.
Oct 01, 2009 | Sony Handycam DCR-HC21 Mini DV Digital...
Sony lcd dcr-hc21e
SONY DCR-HC21E PAL - need copy of original Sony transfer CD. Have uninstalled and lost the disc. Please can anyone help with disc image file?
Sep 26, 2008 | Samsung SONY Handycam DCR-HC21E MiniDV...
"Lens cover not open" message
There is a switch sensor which will detect if the switch is open. Try switching rapidly a couple of times, as dust must be lodged.
Mar 25, 2008 | Sony DCR-HC21E Mini DV Digital Camcorder
The problem is a bad CCD inside the camera. I Sony was providing free service for some of their other models but failed to provide service (recall) on these models. contact Sony at 1-866-703-7669
Feb 07, 2008 | Sony DCR-HC21E Mini DV Digital Camcorder
How to connect dv camcorder to pc?
Hello, please check this link: http://support.sony-europe.com/dime/camcorders/DV/DV.aspx?l=en&m=DCR-HC21E If you need more info please advice. Arpi
Jul 13, 2007 | Sony Handycam DCR-HC21 Mini DV Digital...
Sony Handycam DCR-HC21 Mini DV Digital Camcorder Logo
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
