Question about Sony Ericsson W200i Cellular Phone
Ear speaker not working but speaker when turned on works fine
Dear Expert,
I dont know what happened but my ear speaker is not working fine.....but when i turn on the Speaker, it works fine.
Let me know what kind of problem it is.
Regards,
Manzoor Quazi
India
  • Anonymous Oct 03, 2008
    1. Ear speaker not working but speaker when turned on works fine
    Brigadier General:
  • 7,752 Answers
You will need to take the phone to a mobile service center and have them replaced the ear piece
Posted on Dec 28, 2008
Why no more sound in left side? the right side is fine. i moved the left side like a seesaw, then i found where the sound occur. is it the wire connection problem inside the left side? what to do?
Opened up one of the earcups and dont ask me how it was just by force. The cable that connects the 2.5 to the speaker is frail and there is quite a bit of shielded cable that can rub against each other over time. I fixed it by removing the cable and soldering in two separate cables of similar size.
Apr 21, 2016 | SOL Republic Master Tracks MFI...
Dear Expert : when I receive a call a person or I received a call , I can not hear nothing , what it is problem please,
The ear piece (ear speaker) is not working... get you ear piece replaced from a service center...
Mar 13, 2011 | Cell Phones
Bold 9000 only rings through the ear piece when it is connect. Does ring when disconnected to ear piece. When ear piece is not in my ear, I can not hear the phone ring.
Hi, what makes it when disconnected to ear piece. When ear piece is not in my ear, you can not hear the phone ring is because the ringer of the phone that makes you know when there is an incoming call on your cell phone or a message alert tone on your cell phone is damaged and does not work and makes sound to notify you .
The ringer is a tiny speaker inside the cell phone that allows you to hear incoming call from your cell phone You will need to replace the ringer inside the cell phone ....
When you replace with another ringer (speaker inside the cell phone),phone will be Ok again.
Would advice that you contact an expert in phone repairs for asistance,that will do you good to prevent more damaged on the phone...
Take care.....
Feb 09, 2011 | RIM BlackBerry Bold 9000 Smartphone
Hi. I am being faced with a recurrent problem. Again and again, the speaker in the flap stops working. so then i have to put on the speaker and talk. I showed the phone to a mechanic, they changed the ear...
the speaker in the flap stops working. so then i have to put on the speaker and talk.I showed the phone to a mechanic, they changed the ear flap with the ear piece but it worked fine for a few phone calls only.Kindly advice.
Jan 24, 2011 | Motorola Mobility A1200
Left ear doesnt give out sound
there are two reasons for which your left ear head phone is not working:
1.If the insulation between the wires(copper leads inside the cord) fails....the two leads gets short circuited and it will stop working...OR some times the cord ll be looking good but inside one of the leads got cut then one of the headphones fails...
the solution for the above problem is dont wrap the cord...this ll lead to cut or insulation failure....
2.the speaker in the left head phone got failed...
dont forget to rate me...
good luck...
Apr 15, 2010 | Bose Around-Ear Headphones - Silver
Only the left ear phone works
Try updating the firmware.
http://kb.sandisk.com/app/answers/detail/a_id/156/kw/firmware/r_id/101834
Mar 31, 2010 | SanDisk Sansa e250 MP3 Player
T43 speaker not work, use ear phone is ok, any
go into your laptop's Bios and check that the speaker are not muted in the Bios
Jun 24, 2009 | IBM ThinkPad T43 Notebook
Headset
Try leaving the charger in overnight.
Jun 24, 2008 | Motorola Mobility H500 Headset
No call volume om samsung e250
This because in your handset there will be 2 speakers
1 is loud speaker and 2 nd one is ear piece speaker....
so the loud speaker is working fine ...
There may be some loose contact in the ear piece speaker or the speaker might have got damaged ...
so if you are good at opening then just open your handset and check if there is any loose contact in the ear piece speaker .. is so fit it correctly ..
or you replace the ear piece speaker with the new one ...
if you are not good at opening then just contact the technician ...
he will do it ...
The ear piece speaker is very cheap so no problem .. just buy the ear piece speaker which is compatible to your handset in the shop if you are doing it by your self ...
the technician might take the service charge for this that s all but the ear piece speaker is too much cheap ..
any doubts reply me
i am always here to assist you
thank you
bye ...
May 14, 2008 | Samsung SGH-E900 Cellular Phone
Razr - no ear speaker sound
check for dust on the tip of speaker points.clean the points on circut board also .check speaker with multi meter if speaker damage,change it.
Jun 21, 2007 | Motorola Mobility RAZR V3
Sony Ericsson W200i Cellular Phone Logo
309 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
