Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Maytag rsw24a I have replaced the thermostat, heating element, and timer. It was working great, but then after two weeks we noticed that the center line between the fridge and freezer on the side by side was burning hot, but the refrigerator and freezer still seem to be working. I pulled it out and the condenser fan blade was not turning. I spun it with my finger and it is now turning. After about an hour of it running, the center console is now only very warm, not burning. It was working prior to my replacing the thermostat, heating element and timer. Could this one little fan not working be the cause of that center part becoming hot enough to burn someone? We have also heard a very loud noise that lasts about 3 seconds, but can't get there fast enough to see where it is coming from - it is not a high pitched noise associated with a fan going out. The fan has continued to run in spite of the loud noise. Do you think I should replace the fan motor (about $25.00) or is the compressor or condenser also going out? Thanks for your help. Crystal
Sounds like your humidity switch is "on", which is what warms the center post. Turn it off and see if the heat problem goes away, and if you get a buildup of moisture on the center post. If so, turn it back on.
Posted on Oct 05, 2008
Maytag dryer wont heat
Probably the timer. Remove the quick connect from the timer where the big red wire is that comes off the heating element. Check that leg with the leg next to it. moving the timer knob . You should get a meter reading. If you cannot get a read then that timer is fried inside. I did a video which shows one exactly like yours.
Nov 21, 2013 | Maytag MEDC200XW Dryer
I have a kenmore 400 dryer model# 11069422801 . It os not producing heat. Will randomly work but for the most part not heating. I have replaced the heating element the thermal cut out , high limit...
These timers are crappy but easy to take apart. The leaf switches inside there get a burr on it and no heat; basically like filing points on a car. Smooth up the contacts put her back and see is what I would do.
Sep 29, 2012 | Dryers
No heat. maytag model # MDE8057AYW
Hello there and thank you for choosing fixya
Investigate these five areas if your dryer is not heating up:
Proper Voltage
If your dryer won't heat up, it's possible that it is not being supplied with the proper voltage. Here are three ways to make sure power is getting to your dryer: First, make sure your dryer is plugged in. Next, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Finally, check to make sure no fuses in your fuse panel are blown. Any of these could explain why power is not getting to your dryer.
tbirdfan1_21.jpg Heating Element
It is possible that your dryer isn't heating because its heating element is defective. Heating elements are irrepairable. If yours has ceased to function properly, you will have to replace it. Open your dryer's cabinet and locate the heating element so that you can test it.
tbirdfan1_22.jpgThermal Fuse
Another possible cause for a dryer not heating up could be attributed to a faulty thermal fuse. Once a dryer's thermal fuse has blown, it is no longer of any use. If your dryer's fuse is blown, you will have to replace it. Open up your dryer's cabinet and locate its thermal fuse so that you can test it.
Thermostat
If any of your dryer's thermostats have become defective, they could be the reason that your dryer is not heating. Open up your dryer's cabinet and test each of your dryer's thermostats. If any are faulty, replace them.
tbirdfan1_24.jpgTimer motor
A defective timer motor could also cause your dryer to not heat up. Test your dryer's timer motor. If it is no longer functioning as it should, replace either the entire motor assembly, or just its motor.
Jan 23, 2011 | Maytag Dryers
Freezer & fridge works great for two weeks then stops cooling. The freezer coils have a sheet of ice covering them everytime it stops working. I can thaw out the freezer and start it up again and it...
its probably the defrost heating element located just below the evaporator coil,remove the evaporator cover and check the terminals on the element,then disconnect one wire off the element and check it for continuity
May 10, 2010 | Hotpoint HSS25GFP Side by Side...
My maytag electric dryer wont heat up
Apr 28, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
My dryer works but has no heat whats could be wrong
hello there
:please go through each of these steps that i have provided belw
investigate these five areas if your dryer is not heating up:
Proper Voltage
Heating Element
07fcef1.jpg Thermal Fuse
f9921fb.jpg Thermostat
17a0736.jpg Timer motor
Jan 25, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Heating element stays on when dryer is off.
I would advise to inspect the high limit thermostat. this device may be defective. this will cause the element to continue to operate when the unit is off as well. If the thermostat is operating correctly, replace the timer.
Aug 12, 2009 | Maytag PYE2300AY Electric Dryer
Maytag pye2300ayw runs but does not heat.
hi..the reason to this problem is your heating
element might have gone bad.
check it out..
thank u..
kindly rate my response..
Jun 30, 2009 | Whirlpool LER5636P Electric Dryer
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
209 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
