Question about Linksys Wireless-G WRT54GS Router (e125894)
Linksys wrt54gs router and Xbox live
I am trying to connect to Xbox live using my Linksys wrt54gs router and am having quite a bit of trouble. I get as far as the IP address test and fail that every time. I am in the Chicago area and have a high speed connection with Comcast. I am getting the same result with a cable as I am with the wireless adapter. I have reset the modem, router, and xbox to no avail. ANY help will be truly appreciated.
Thank you
  • Scott Merrill
    Scott Merrill May 11, 2010
    Question:
    Are you able to get internet on your computer or laptop through the wireless router at all (forget the Xbox for a moment, I'm speaking specifically about the other devices). If not, I know what your problem is :)
    Let me know :)
I am trying to connect to xbox live and it comes up with MTU fail and I have no idea how to find the problem to try to fix it.
Posted on Sep 30, 2008
  • 33 Answers
Make sure that internet connection working fine first..if it is connect you xbox via wired or wireless(if wireless, make sure that you connect to your own wireless network and enter the wireless security if there is)...check if you can get an ip address, better set to obtain the ip address and dns of your xbox, if all set and still unable to access internet, access the linksys router setup page by typing 192.168.1.1 on the address bar of your internet explorer, when pop-up for username and password type admin under password, leave it empty for the username. Click administration tab and disabled UPnP. Check if your X-BOX working fine. Hope this help you.
Posted on Sep 29, 2008
  • Cindy Rey
    Cindy Rey Sep 30, 2008
    hi Guest,
    you can change the MTU on your router setup page, means you need to access the configuration page of your router first. can you please provide the model number of your router, at least I could search for that and hopefully can provide a specific steps. Thanks
IP Address Errors
It sounds like you may be having IP address conflicts. Many Xbox users have a fixed IP address set in their unit and then have a Port Forwarding done in the router to provide faster play. If you reset the router all this is lost. Then what can happen is that the router will assign a device the reserved IP address of the Xbox. When you turn the Xbox on, then it cannot connect as there is another device already assigned that address. Reconfiguration is required to prevent IP conflicts.
Dec 08, 2013 | Linksys Wireless-G WRT54GS Router...
Linksys wrt54gs changing upnp settings
Hi, you can enable UPnP on a Linksys WRT54GS router by logging in and then clicking on the Administration tab. The first sub-tab is Management, and at the bottom of that page there are buttons to enable or disable UPnP. Click Enable and then click Save Settings at the bottom of the screen.
Jul 21, 2010 | Zyxel P660HW-D1 Router
Hello i am trying to connect to me friend on xbox live with a WRT54GS linksys router and i unchecked the nat filter and the upnp is enabled but i still cant connect
PS3 and Xbox ( NON BELKIN)
You Will Have to Disable the Firewall In Your modem / Router
And IF it is a router then Open The Ports
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
And also make sure that UPnP is Enabled
May 20, 2010 | Linksys Wireless-G WRT54G Router...
Xbox live MTU failure
The reason why you're getting an MTU error is because the MTU has already reached the maximum # of packets that are being sent. To resolve it.
Access the GUI of your Linksys Router and go to the MTU settings. Set it to 1500. The lower, the better
Apr 26, 2009 | Linksys Wireless-G WRT54GS Router...
Ethernet won't reconise modem for xbox live
Once you have everything hooked up:
Ethernet cord going from modem into wireless router in port labelend internet or wan, and an ethernet cord going from the router to the xbox you should try these steps:
Unplug the power cord on the modem and plug it back in- once all the lights come back on
Unplug power cord on router and plug it back in-
Hope this helps.
Apr 07, 2009 | Linksys Wireless-G WRT54GS Router...
How do i change my NAT connection from moderate to open
This one is simple. Find the IP address that your Xbox is assigned by your router, then put it into the DMZ. This also goes for PS3 users who are having trouble with internet access.
Feb 10, 2009 | Linksys WRT160N Wireless Router
Linksys router
You haft to set the router to be static for the Xbox IP. in the settings you can sett it for gameing. just click on the gameing tab
Jan 04, 2009 | Linksys Wireless-G WRT54GS Router...
Linksys WRT54GS router needs to be rebooted frequently
Try to leave of air for an hour, untill its cold, then reconect it, if the time untill it quit conecting is consitrly longer, your Linksys is dying.
/Teis
Dec 07, 2008 | Linksys Wireless-G WRT54G Router
Xbox 360 live on wireless router
In theory you should be able to "share" your internet connection. I use a Linksys WRT54GS wireless router and I have a Linksys Game adapter on my son's 360. He has not complained about lag or slow server times unless other intensive bandwidth is being used.
Nov 09, 2008 | Microsoft Xbox 360 Console
Linksys Wireless-G WRT54GS Router (e125894) Logo
233 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
