Question about Konica Minolta magicolor 2300DL Laser Printer
Konica Minolta magicolor 2300W printer
I ran completely out of black toner and I can't get the machine to advance so I can take the old one out and replace it. I went to Status, Print, and tried to select Replace Toner, but it does not allow me to make the selection. PLEASE HELP!!!!!!1
  • 4 more comments
  • juris Sep 29, 2008
    I did reset the unit but the problem persists. Any other advice?
    I followed the directions posted - it does not work. Is there some other way to make the cartridge advance so I can take out the old black and replace it?
    None of the responses has addressed the problem. I can not get the machine to advance the cartridges so that the black can be removed and replaced.
    Thank you for the link - it only gives the same instructions that I have already tried, however. I need to know if there is an alternate way to get the black toner to advance so I can remove and replace it. It is not happening automatically when I follow the instructions. Is there a way to do it manually?
    The unit is the 2300W and it has four toner cartridges. When you select Status, Print, Toner Replace it is supposed to rotate the toner cartridges so you can remove the one that is out of ink. It is not allowing me to select Toner Replace - nothing happens and it is not rotating the cartridges.
    Thank you for your suggestions. Your instructions tell me to remove toners and print cartridges, however, and that is my problem -- I can only remove one toner cartridge because the machine will not advance in order to give me access to the others. They are hidden within the machine until the machine rotates to the one that needs to be replaced - it is not rotating.
    Sergeant:
  • 208 Answers
HI,
I want you to do these,
1. clean toner chip reader, remove drum and all toners, under the toner rack there is a 3 pin chip reader, use pressure air to clean it.Try to print now.
2.If its not rotating now, then you have to perform Drum Rotation Functional Check.
Follow these steps:
The photosensitive drum, located in the print cartridge, must rotate for the print process to
work. The photosensitive drum receives its drive from the main drive assembly.
NOTE This test is especially important if refilled print cartridges have been used.
1. Open the print-cartridge door.
2. Remove the print cartridge.
3. Mark the drive gear on the cartridge with a felt-tipped marker. Note the position of the
mark.
4. Install the print cartridge and close the print-cartridge door. The startup sequence should
rotate the drum enough to move the mark.
5. Open the print-cartridge door and inspect the gear that was marked in step 3. Verify that
the mark moved.
If the mark did not move, inspect the main drive assembly to make sure that it is meshing
with the print cartridge gears. If the drive gears appear functional and the drum does not
move, replace the print cartridge.
Hope my info solves your problem,
Thanx for using fixya,
Waiting for your comments......
Posted on Sep 29, 2008
    Sergeant:
  • 320 Answers
Please click on the below link or copy the URL and paste it in your web browser. Click on any one query and fix your problem.
http://images.google.co.in/imgres?imgurl=http://www.worldclassink.com/ABMIMAGES/T.KONICA_2_10.GIF&imgrefurl=http://www.worldclassink.com/Konica_Minolta_QMS-Toner-Troubleshoot.html&h=322&w=280&sz=9&hl=en&start=4&um=1&usg=__l2QZrpg9UlctAB1qb5yk22gQRdY=&tbnid=6e68XrIE3OA6VM:&tbnh=118&tbnw=103&prev=/images%3Fq%3Dhow%2Bto%2Bremove%2Btoner%2Bin%2Bprinter%2Bkonica%2Bmagicolor%2B2300%26um%3D1%26hl%3Den%26client%3Dfirefox-a%26rls%3Dorg.mozilla:en-US:official%26hs%3DQDp%26sa%3DN
Thank you............
    Brigadier General:
  • 6,966 Answers
Specific instructions for your particular model and concern is detailed with illustrations here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
  • Louie  Role
    Louie Role Sep 29, 2008
    Hi again,
    On your postback/comment, may I kindly asked at which step the unit fails to operate as detailed in the instruction(s)?
    Additionally, does your unit have Rotate Toner key?
  • Louie  Role
    It would appear that for some reason, the carousel of your Konica 2300W is stuck. If you could not perform the Toner cartridge Rotation/Replacement using the Status Display/Printer Tab/Toner Replace as explained in the linked procedures, it may be required that the catridges be manually removed one at a time until the desired color is reached. Pls reference below image.
    This is better explained in detail in page 99 of the Service Manual of the Konica 2300W.
    Scholar:
  • 148 Answers
TRY TO RESET THE UNIT FIRST.
  • 2 more comments
  • Zander Rovic Ocampo
    Zander Rovic Ocampo Sep 29, 2008
    If the current cartridge you are using is a 4500K cartridge, and you
    forget to reset the printer panel, you will probably get a premature
    message that reads 'low' or 'empty' or 'replace'.
    DID YOU GOT THIS MESSAGE...?
    For
    the toner to be released, it is necessary to remove the cartridge
    sealing tape. This is a clear plastic strip which is pulled out from
    inside the toner cartridge. In order to remove the sealing tape, you
    will need to break the tab that is connected to the toner cartridge and
    pull. It should FULLY come out of the toner cartridge. When you remove
    the seal, a small amount of toner will come out with it. We recommend
    pulling the seal over a trash can. If the seal was not fully removed
    from the cartridge when you pulled it because it got broken, use
    scissors to cut the seal. If, after you have cut the seal, the margin
    of the printouts look faded, the cartridge will have to be replaced.
    It
    will be necessary for you to change a toner cartridge when your laser
    machine indicates that you are out of toner. If it indicates that the
    toner is low, you may still be able to print a few hundred more pages.
    • In
      order to change your toner cartridge you need to know what model of
      laser machine you got. There are two names somewhere on the machine.
      One is the name of the laser machine (e.g. ucrit01), and the other is
      the name of the model (e.g. HP LaserJet 5m). The latter is the name you
      need. By knowing this name, you will be able to buy the right cartridge
      for your machine.
    • Turn the machine off and open the top cover.
    • Then, open the front cover and pull the drum unit assembly.
    • Press
      down the lock lever and remove the old cartridge from the drum unit. In
      order to remove the cartridge, pull it upwards and away from the laser
      machine. The cartridge should come out without making much effort.
    Remove the new cartridge from its packaging, and rock it gently for a few seconds so as to distribute the toner evenly.
    Do not expose the cartridge to the light for long (no more
    than a few minutes). While exposed, cover the cartridge with a piece of
    paper or cloth.
    • Take
      off the seal from the toner cartridge (a small tab that is attached to
      a plastic film strip). Make sure you remove this or your laser machine
      will only print blank pages.
    • Install
      the new cartridge into the laser machine by following the arrows or
      other cues in the machine that will help you align the cartridge
      properly. It should slide in using a small amount of force. If it
      doesn’t, check the cartridge is properly aligned and make sure you are
      using the correct cartridge. You can find out which toner cartridge is
      compatible with your laser machine in our website.
    • When the cartridge is seated, close the top cover.
    • Turn on your laser machine.
    Print
    test pages: if they look good, package the empty cartridge and recycle
    it-optional. If there are repeated defects, streaks, faded out pages,
    etc. on your test pages that were not there before you changed toner
    cartridge, there must be a problem with the cartridge. Install a new
    one, and print some test pages. If they are clean, it means the first
    toner cartridge was faulty. If both cartridges have problems, there
    something wrong with the machine.
    KEEP US UPDATED
    1. Open the Status Display and check which toner color is empty. Then, choose “toner replace” from the print menu.
    2. Select the color of the cartridge you need to replace from the color list box
    3. Select the cartridge capacity (1500 or 4500). Then, click “OK”
    4. When you see the toner indicator on the control panel flashing, open the printer front cover and the carousel will
    reposition automatically so that the appropriate cartridge can be removed.
    5. Take the cartridge from the tow holes in its front and pull it straight out about 6”. Then use your left hand to help pull out the cartridge.
    6. Unwrap the new toner cartridge from its package.
    7. Remove the sealing tape.
    8. Check the colored end of every cartridge to be replaced since this corresponds to a color inside the toner cartridge
    slots. Install the cartridge in the slot of the same color.
    9. Take the cartridge with your left hand and put the thumb and index finger of your right hand into the two holes in
    the front of the cartridge. Then insert it, making sure that the guides on the cartridge fit into the rails in the
    carousel. Push the new cartridge gently into the machine.
    10.
    Then, close the printer front cover.
    The machine will run a calibration cycle which lasts 150 seconds after replacing any consumable. If the cover is opened
    before the “ready” indictor on the control panel light up and the error indicator turns off, the machine will stop and
    repeat this cycle.
Konica Minolta Magicolor 2300W not transferring toner to paper.
Clean the paper feed rollers,the fusing unit rollers and print the blank page(min.10-15) for clean the upper fuser hot roller.Agiting the toner.
Jan 28, 2013 | Minolta magicolor 2300W Laser Printer
Konica Minolta Magicolor 2300W firmware needed
firmware is located on secure web site try having a Konica Minolta tech come out and flash the firmware
Apr 15, 2010 | Minolta magicolor 2300W Laser Printer
After replacing black toner cartridge printer displays Drum Low
The drum and the black printer cartridge are two separate items. You will have to purchase a new drum for it. I just had to do the same thing and it ran me $150.00 at Staples.
May 19, 2009 | Konica Minolta magicolor 2430 DL Laser...
Replcing the black toner on the Minolta Magic color 2300w
You can press the 'rotate toner' button which is the blue one next to the toner indicators on the top panel or you can open it up and with two hands on either side of the entire cartridge, turn it manually. You will hear clicking sounds as you turn it. I've done this safely replacing all four toners twice over now.
Mar 25, 2009 | Konica Minolta magicolor 2500W Laser...
Driver
Here is the link to download your driver.
Thanks
Mar 12, 2009 | Konica Minolta MAGICOLOR 2300W LASER...
To change opc drum in konica minolta
To Change OPC DRUM UNIT in KONICA MINOLTA 2300 w
Switch Printer Off
Open Front Door Cover
Remove Waste Toner Box
Lift Transfer Belts Blue Knob until it's placed at 11 o'clock. (it's directly behind the waste toner box)
The OPC DRUM UNIT is directly under the BLUE KNOB
SQUEEZE HANDLE and PULL OUT the OPC UNIT
Be VERY CAREFUL NOT TO SCRATCH THE GREEN COLOURED ROLLER on the OPC DRUM UNIT.
Replace new OPC DRUM and turn BLUE KNOB of TRANSFER BELT back to 7 o'clock position
Replace Waste Toner Box, Close Front Cover and Switch On.
Status Display will show OPC Drum at 100%
(You can also replace the fuse in the OPC DRUM UNIT and save yourself HUNDREDS on a new one)
I posted this on another solve problem previously, worth looking at.
Jan 06, 2009 | Minolta magicolor 2300W Laser Printer
Konica Minolta Magicolor 2300 DL - Fatal Error Code 0EH ????
I had the same problem one time, they told me to pull out all of the toner cartriges, power off, power on, power off, replace all cartridges and the problem went away.
Who knows why. If this doesn't work....
Call Konica Minolta tech support.
They were pretty helpful to me.
Dave
Nov 28, 2007 | Minolta magicolor 2300W Laser Printer
Help replaceing a toner
Here is what you do.... turn off the power, open the door to access the toner cartridges. You'll see the access port to pull the cartridge out. There will be a small picture to the top left showing to use your two fingers to pull it out. Between the pic and the opening there is a square hole with a round plastic tube in the center of it. Take a car or house key and stick it in the hole. When you do, you can now rotate the cartridges by sticking your finger in the individual cartridge holes. Rotate the cartridges until to can freely pull out the one that needs to be replaced. Put the new one in, close the door, turn on the printer... Ta-DA!!
Nov 07, 2007 | Konica Minolta MAGICOLOR 2300W LASER...
Konica Minolta magicolor 2300DL Laser Printer Logo
468 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
