Question about Kodak EasyShare Z710 Digital Camera
Flash not working
I try to take a picture and every time the "open flash" lights up. the flash is opened and it still won't flash. please help me?
  • 1 more comment
  • jennskisses Oct 12, 2008
    I turn my camera on and the flash opens but when you try to take a picture the flash doesn't not work. And the camera is saying that flash isn't open. It won't read that its open... I have tried to push the flash button and the icon on the screen flashes twice.
  • heather1995- Nov 23, 2008
    How do I change the flash bulb?
  • micklk Jan 11, 2009
    camera was dropped and now the flash does not work and i get a error message to "OPEN FLASH" even though flash is open.
Note that the SCN setting on the option dial is for Text and will not engage the flash. Make sure you are using an option for which auto-flash is enabled. Otherwise, it is possible the flash is spent. The bulbs do wear out eventually.
Posted on Oct 31, 2008
Won't stay on
i could be that the rechargeable batter is weak. try replaceing the battery for a new one. also check that the connections for the battery are clearn.
I hope this was useful.
Feb 15, 2013 | Sony Cyber-Shot DSC-P52 Digital Camera
Nikon D80 takes picture but wont set off flash
has the camera been in any cold weather or hot conditionds in a car?
the camera deffintly has a fault it has nothing to do with the settings any more
could be due to wearther conditions.
do u have warrenty this item? it will have to be professinally looked at i searched the web and its saying there is a seprate chip inside the camera that produces the flash unit ,and if you had to pay to get it fixed roughly 65 dollars
Jul 05, 2008 | Nikon D80 Digital Camera with 18-135mm...
LG Rumor Touch flashing red light won't work
Open menu and check the settings, open settings and scroll under the lights and it must be switched to ON.
Jul 04, 2012 | LG Rumor Touch
My canon powershot SD 1000 will take outdoor pictures but wont take any with low light and the flash won't work. I see that someone else asked the same question but I can see what advice was offered
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help. Recommend trying the pencil tapping fix listed in the link. It worked on my SD1000 with the same problem.
Jun 04, 2011 | Canon PowerShot SD1000 Digital Camera
When we take a picture, the flash does not open an...
The flash getting stuch is a common problem with the Canon Rebel ( or Kiss) series. Set the camera in Auto mode in a dim place. Hold the flash unit gently from both sides and try to help it open while pressing the photo button. Do not use force if this does not work the first time - try it again.
Once open, clean the sides of the flash unit in case some dust is causing this problem.
May 20, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Drum light on HL2030 won´t go off!
Open the front door, and press the go button until the lights flash, after closing, press the go button 3 times for a printout showing the drum as full again. The instructions come with the new drum...
Jul 30, 2009 | Brother HL-2030 Laser Printer
When ever i take a picture, the orange light turns on acting like its going to take a picutre but it doesnt. When i take it off flash, it takes the picture.
The orange light blinking means the flash is charging, once the light goes off you can go ahead take picture with flash. Your light keeps blinking because the flash is not ready.
Try with fully charged batteries. If it won’t work, you may have an open fuse or something wrong with the flash circuit.
Apr 05, 2009 | Canon PowerShot A550 Digital Camera
Flash pops up, but flash closed warning stays
My E5700 did this a couple of times. The fix for my flash was that the unit wasn't actually popping all the way open. I closed it, then manually poppped open the flash and gave it a gentle upward tug. The flash seemed to lock into position -- and has worked fine since. I hope your fix is as simple as with my E5700.
I hope this helps!
Regards,
CharlieJ
[Please rate this solution, if it helps you.]
Nov 01, 2008 | Nikon Coolpix 5700 Digital Camera
Dcr-hc19e & picture package menu & macromedia flash player
Go to http://www.ppackage.com/e/download.html#dl
and download the latest version of pic package 1.8 at the bottom. solved the problem in 30 seconds!
Apr 26, 2008 | Video Cameras
This could be a faulty unit.  Take it back to where you bought it and hopefully you are still under you warranty.
Mar 09, 2008 | Nikon D80 Digital Camera with 18-135mm...
Kodak EasyShare Z710 Digital Camera Logo
170 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
