Question about Kenmore 53603 / 53606 Stainless Steel Side by Side Refrigerator
Water line to Kenmore refigerator is brown
I was cleaning the interior of my Kenmore refrigerator when I discovered that the water line running to ice maker and water dispenser is brown! (There are several feet of this water line tightly coiled at the interior rear of the refrigerator.) Does the line need to be replaced? Are there any health concerns...Safety of water,etc.? Thanks for your help
  • 2,712 Answers
Some tubes turn brown gradually with age. This is normal. But if yours is not made of that material (not sure what its called), then it could be that the pipe is dirty. If this be the case, it is definitely better to get the line replaced, as it is definitely a health concern. I would recommend getting a filter fitted to the line as well, just as a precaution..
Posted on Sep 29, 2008
My kenmore refigerator ice maker stopped making ice.
Could be that the solenoid that feeds water to the ice maker is not working properly.
Also make sure that the freezer temp is at least 10 degrees or less - if not the ice making cycle will not commence.
Mar 12, 2017 | Kenmore Refrigerators
Automatic ice machine is producing brown ice
What is your water source and how does the water look from other areas, such as kitchen sink, toilet/shower? Did technician replace water line / tubing ? Lowe's and Home Depot carry tubing. Take off and replace. What has changed in your environment recently????
Cause and effect.
Mar 05, 2014 | Refrigerators
Restricted waterdispenser flow on my Kenmore Coldspot refrigerator.
find the shut off valve for the water line to the refigerator.turn it closed all the way the open it up.this will clean the line. if that dont help you need to change out the water valve on the refrigerator...
Oct 22, 2013 | Kenmore Refrigerators
I have a GE Profile Performace Refrigerator and the water dispenser and Ice maker are not getting any water. No water is coming into the refrigerator. Water line to refigerator is working. What may
Check the water solonoid on the lower right side facing the rear of the unit. the water line connects to it. sounds like it might be defective.
Apr 07, 2012 | GE Refrigerators
We have side by side Kenmore and on freezer side we are getting prozen water under the slide out drawers on the bottom on interior. We have cleaned it out and it refreezes and when we turned off water to...
Your drain line is frozen and not allowing the defrost water to drain to the pan below. The drain hole is at the bottom of the evaporator coil in the freezer behind the metal rear panel. You may need to remove the panel to access it. You can use hot water to thaw it out and you should be in good shape.
Mar 24, 2011 | Kenmore Side by Side Refrigerator
Hi I have a Whirlpool Refigerator and it drips water from the frezzer into the refigerator thru the two opening up in the back middle opening from the frezzer to the refigerator. It does this off and on
sounds like the drain live from freezer to outside is clogged. the water isnt making it you the condensate pan but coming out in the refrigerator. try finding and cleaning the drain line.
Mar 02, 2011 | Whirlpool 21.0 cu. ft. Top Freezer...
Generally a filter is a add on feature. If you do not see a filter in the water line that supplies the ice maker then there is generally not a filter. You can purchase a water filter from any local hardware store and install it yourself.
Aug 04, 2010 | Refrigerators
See brown looking water running in front refrigerator
This very well might be a drain hole inside of your refrigerator that is plugged up.
Freezers use a heater to melt the ice to prevent build up of ice. They are automatic deicers. This water drains sometimes in the refrigerator back to the catch tray, or out the back to the catch tray. The catch tray is at the bottom where the water simply evaporates after a while. If you have a water hookup to your refrigerator then you would have a lot of water and it would be clearer. So I am betting it is just a drain hole inside the refrigerator bottom under all the drawers is clogged and the water is pooling out from there. Just clean it and you should be fine
Mar 14, 2010 | Kenmore Refrigerators
Bad tasting water and ice from refridgerator.
i agree with rpbuice but in addition to flushing the water line you may need to replace the line then using the water dispencer run out about a gallon of water thru the door. this will clear the reservoir of bad tasting water. for the i/m throw out all of your ice then let it make a couple of batches and throw out that ice as well be sure to clean your ice bucket very good to remove any lingering tastes from the old ice.
fyi bad tasting water is generally from bad water supplies. good luck..
Jan 19, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore 53603 / 53606 Stainless Steel Side by Side Refrigerator Logo
181 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
