Question about Garland M-1 GL Gas Single Oven
Garland deck oven
When the door was closed on the gas oven ,the oven blew the door open and flames came out. what could cause this?
  • 41 Answers
Your gas valve may be freeflowing you must have this checked right away
Posted on Dec 11, 2008
I have a Garland Mater 200 electric oven and the fan continues to run even with the door open. Is there a switch / sensor that controls that?
https://www.manualslib.com/manual/55869/Garland-200.html?page=103#manual
This web site had a manual that may answer you question. It seems that here is a heat/cool switch. The cool switch is designed to function to cool the oven down by running the fan with the door open. If you close the door, it will heat so the door has to stay open.
Aug 20, 2017 | Garland Ovens
My oven when i close the flame goes off
If the oven will light and work with the door open but flames out with the door closed, you have the air input blocked somehow. I know some people line their ovens with aluminum foil, but you have to make sure that you have the air flow.
Jun 03, 2011 | Bakers Pride BAK-DS805 Gas Single Oven
I have a garland oven model st286 it wont light even though there is gas getting to it and the spark is working. It lights if you light it manually
Instructions
  1. Access the burners inside your oven by removing the access panel in the front of the oven or by opening the broiling drawer, depending on your particular model.
  2. Determine if the pilot itself is lit, since some ovens have a small flame on the pilot at all times that then grows and extends to the burner when the oven is turned on. The lack of a pilot flame indicates the oven thermostat is malfunctioning or there is a problem with the gas hose. Check the pilot itself to see if it is clogged with debris or grease that could be preventing the flame from staying lit.
  3. Determine if the pilot flame will grow if it is lit by turning on the thermostat. If the pilot flame doesn't extend, the thermostat itself likely needs replacement. If the flame is extending but the gas valve is not opening, the safety valve could be dirty or defective. The flame should be blue in color. A yellow flame indicates the pilot is dirty and is not burning hot enough to get the main burner to ignite.
  4. Light the burner on the top of the oven with a match if the igniter doesn't appear to be effective. If it lights manually but will not light automatically, the igniter is likely faulty. Do not do this if there is a heavy smell of gas in the kitchen, since there could be a risk of a fire. In that circumstance, turn the oven off, ventilate the room and call a technician.
  5. Listen for any sounds of gas hissing or a clicking sound indicating the oven is trying to turn on. If there is no response from the oven at all, the gas may not be functioning properly and will need to be examined by a technician for safety purposes
Jan 26, 2011 | Ovens
I have a commercial garland air deck gas oven model G56PB its not staying heated to the set temp. it will heat up to the set temp. then five minutes later the tempreture will drop and will not heat up to...
I have seen Garland's have issues with the pilot light. see if you can watch the cycle.It may takes several minutes. I have seen where the pilot actually lifts off the pilot assembly and go out and cause oven to fail. Turning off and on resets the failure and sometimes it will light. Start there and be patient.
May 11, 2017 | Garland Ovens
Model TE2B garland does the fan run to move
The fan runs to circulate the heat inside the oven for more even and faster cooking...That is how a convection oven works :)
Jan 14, 2010 | Garland Convection Oven - MCO-NAT Gas
Garland oven MOD# MST43RE White flames and a lot of black.....
I adjusted the air mix, main burner was full of black stuff inside so took the air compresor and cleaned it good. Now i have nice blue flame!
Gasman77
Mar 25, 2009 | Garland M-2 Oven
When Oven turns off so does oven pilot
Hi there, it is possible of the pilot being too close, but usually does not have that effect, unless the pilot is too small. But if you replaced the pilot, it should be clean, so next I would look at the gas pressure, if this is too low, the flame won't have proper burning speed, and strength, and could get drawn out. The control valve may be of the type that has a regulator built in, you may need someone skilled at gas pressure measuring, to do this, your gas supplier, appliance professional, plumber, should be able to do this.
Let us know, and thank you.
Jan 29, 2009 | Garland GPD-60-2 Gas Double Oven
My garland air deck will not heat up
I own a large repair company we charge these fees for our tech. ability I often give you people free advise but when you insult our techs try to figure it out yourself then you will know why we chargey the way I would not give you free advise you would not say thank you
Dec 31, 2008 | Garland M-1 GL Gas Single Oven
GARLAND CONVEC. OVEN - CONVEC. NOT RUNNING
it sounds to me like the door switch is not making. if you take off the bottom panel the switch is to your rightat the bottom. make sure that you kil power first brfore you remove the panet.
Dec 22, 2008 | Garland Convection Oven - MCO-NAT Gas
Model GPD-60
Look for spring or the lock tear side of the door applied small tin sheet can hold door lock and drill and then revit it.
Dec 30, 2007 | Garland GPD-60-2 Gas Double Oven
Ovens Logo
119 people viewed this question
Top Garland Ovens Experts
Dennis Boxerman
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Garland Oven Expert? Answer questions, earn points and help others
