Question about Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony tv wont start up???
Kvfq75u 32inch trinitron,just moved into new flat the tv there wont switch on its red light comes on but when you try to start it up with remote or on the tv itself the red light flashes then goes off then flashes back on again but no picture?? My tv won't start up. The red light blinks and the picture won't come on. It's a Sony trinitron.
  • litlitaly7 Oct 06, 2008
    The tv doesn't click or anything. The red light keeps flashing forever. The red light doesn't go off at all. The tv is 7 years old. Do you think it is even worth fixing?
  • litlitaly7 Oct 09, 2008
    I have an Infiniti g35 and the compact disc player just stopped playing and a message that reads "cd error fo" comes on. The player won't load, play, or even release my 6 cds. It's as though the player keeps spinning and is trying to find its tracking. Anyway, that's what it sounds like. what do you think is going on?
  • 171 Answers
Here is the service manual for your TV.
http://www.techlore.com/downloads/file/7714/KV32HS500.pdf
Do the diagnostics as listed and then let me know the results.
Posted on Oct 09, 2008
  • 749 Answers
Trinitron is a great tv...a bit more expensive than other to fix as you can not just replace one part in its curcuits. you MUST buy a kit and replace every part in a defective circuit or it will keep eating components. unless it's a fuse , insist they do a full repair and not just a quick fix.
Look for an estimate before a repair, some wont charge for this.
Keep in mind that everything is switching to digital and you might consider a digital HDLCD tv that weighs a 1/4th of what your Sony does.
Hope this helps in your decision making.
  • Nesley Louis Mar 04, 2012
    In repairing power boards in a tv like the Sony KV 32FV310,replace all the capacitors which should costs less than $10 USD.Look for diode 647 and replace it $3 usd.
    Learn how to read if a capacitor or diode is good.
    Set your Resistance reading to the highest setting on a Multimeter and place the black probe on the negative side of the capacitor marked with a painted side and (-) sign and the other on the unmarked side.It must charge up to 1500 Mega-ohm or more.
    In testing Diodes set the Multimeter to Diode Setting ,which must read 1 in one direction and a large millivolt in the other e.g.588,any other readings it is considered faulty.
    Nesley J.Louis-Pre-Engineering.
    President:
  • 2,712 Answers
It seems the high voltage flyback autotransformer has failed along with the horizontal amplifier (they are slaved to each other). Do you hear any clicking sounds?
Or else it could be that the CRT tube is faulty and will need to be repaired/replaced.
Well, the only way to solve this is to get a technician take a look at the set, I'm afraid. Repairs could cost upto $100 or more, depending upon the number of components that need to be replaced,
It may be worth getting fixed up. If you decide to do so, call around, as shops have different rates and different expertise.
Hope that helps!
Posted on Sep 29, 2008
  • Swilin Sampson
    Swilin Sampson Oct 06, 2008
    Like I said, most likely an issue in the power module, or some cold solders. Can happen during moving. Enquire around for prices.
    Since the TV is 7 years old, my honest opinion would be to actually invest in a new TV. But in the end the decision is yours to make :)
    Cheers!
    IrishDruid
  • Swilin Sampson
    Swilin Sampson Oct 09, 2008
    Try a hard reset - Unplug the player from power source for about 15 minutes and replug and see if this resolves the issue. If not, it could indicate an issue with the optical assembly, which will require the services of a professional.
    (This should actually be posted as a separate query, as it is not related to the TV issue :)
    As for the TV, there is most likely a short circuit somewhere on the power board, which is why the protect mode is kicking in to take over the power management. Repairs may prove to be expensive, and considering the age of the TV, I think you got your money's worth. Any TV lasting more than 6 years without problems is a great deal. I think its best to retire the old set and simply go in for a new one.
    Cheers!
L have 32" klv32ex300 Sony bravia of 2years old, the screen goes off after been on for some time, the green light blinks once then the red keeps blink continuously in which l will loose count after 40
id check the capacitors again,esp near the one you changed.was the one that was put in the correct one? you may increase the voltage but not the uf
Mar 12, 2013 | Televison & Video
Sony bravia 32inch TV switches off after few minutes and red light blinks what is the solution
Make sure the lamp door is seated properly and back on tight. The door activates a microswitch in the TV and if it fails to do so the end result is the set shuts down with the flashing lights :
Sep 20, 2011 | Televison & Video
Television switching itself off with red light flashing.
Had same problem on a 50inch wega tv. It needed lamp replaced,not hard to replace about $180.00
from Sony.
May 07, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Picture wont come on screen
this problem is in the power supply.the red lights indicate as the standby mode.
Jan 23, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
The flashing should be a repeated number of blinks. Please post that count as that will indicate the circuit in which the set detected a problem. The set is in protective shutdown. Using hte blink count, we can determine the possible problem and solutions.
Dan
Jun 18, 2008 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony trinitron wont turn on.
these sets have a flyback problem, the cure is usually replacement.
If you are unable to replace one, then you will require a technition.
Thanks Guy9
Jun 10, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Reddish screen on sony wega kv-28fx68 100hz trinitron
it sounds like a b+ cap going bad and is intermittant that feeds the the video drivers on the crt pcb or the crt is shorting.
Oct 14, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony FD Trinitron WEGA KV-32FS100 32" TV Logo
139 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
