Question about Coleman Propane Forced Air Heater w/Electronic Ignition (50,000-80,000 BTU)
Coleman Evcon Ignition Failure
I have a Coleman Evcon downdraft mobile home furnace (modelDGAH077BBSA) that would not fire this morning. All the relays andsolonoids appear to be activating. The gas relay does open and when thesensor detects unburnt fuel it shuts down and purges the system, youcan smell the unburnt fuel at the chiminy. The system light then goesfrom steady to one blink every 2-3seconds.
Thanks,
Ken
  • sethchristy Nov 11, 2008
    ignition failure
heatman101
  • 43501 Answers
SOURCE: Coleman furnace -- fan runs, ingniter won't light,
The chances are that the furnace was running when the power went out. This will cause the high limit switch to cutout and needs to be manually reset.
You will find that switch in the blower compartment near the blower. Usually somewher near the highest point of the cabinet.
Push the little red button firmly till it clicks.
When the power goes out while the furnace is running the heat builds up because the blower shuts down immediately and causes this limit switch to cut out.
If you have a electric tester you can also follow the low voltage circuit till you find the open switch. Ther is usually a wiring schematic on the door cover of most furnaces.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Posted on Dec 09, 2009
muttandjeff
  • 359 Answers
SOURCE: Rollout Limit Switch Keeps Tripping
have someone check the gas presure most likely too high no more than 11
Posted on Dec 17, 2008
  • 189 Answers
SOURCE: coleman furnace wont fire
Check inside the door panel next to the wiring schematic, you should find the diagnostic codes. Look up 7 blinks. This should narrow down the problem. ( It sounds like a bad hot surface ignitor).
Good luck.....
Posted on Apr 10, 2009
SOURCE: I have a Coleman Evcon gas (propane) furnace. When
If the unit fires but the main blower fan doesn't come on the the unit is shutting off on a temp high limit switch and it sounds like the problem is the main blower fan motor or control
Posted on Jan 18, 2010
SOURCE: Have a Evcon Coleman Furnace shows three green
I have had the same problem with mine for the last 2 years. Remove the motor on the side of the furnace(usually held on by 3 screws) and turn the fan blades inside by hand. after sitting all summer it seems to get stuck. If it moves freely, replace the motor and try to start it again. This fixed mine the last 2 years! Hope this helped.
Posted on Oct 04, 2010
Coleman Evcon model DGAT070BDE the red light keeps flashing what does it mean
http://www.cpsc.gov/en/Recalls/2012/Fire-Concerns-Prompt-York-International-to-Reannounce-Recall-of-Gas-Furnaces-for-Manufactured-Homes/
Sep 04, 2015 | Coleman Heating & Cooling
Our coleman evcon furnace has started clicking over & over again before it starts up, we replaced the thermostat & the same thing happens.We are afraid that this is hard on the furnace & have resorted to...
Suspect that the igniter is causing the clicking (or could be a relay). Suggest having the furnace serviced. There is also a major recall for some models of the Coleman Evcon furnaces.
Oct 29, 2013 | Heating & Cooling
Coleman evcon furnace in mobile home works fine during the day but not at night. What could cause this?
I suspect water in the fuel that is freezing up due to the pressure difference across the jet and causing a blockage.
Feb 16, 2013 | Tools & Hardware - Others
Draft blower stays on all the time on my Colman Evcon that is in my mobile home.What could I check for, any sensors? Furnace runs fine otherwise.
there is a temperature sensor in the fire box that keeps the blower going til it cools down after the burner shuts off, could be faulty and keeping the fan on
Feb 14, 2011 | Tools & Hardware - Others
I have a coleman evcon furnace that wont work. The electrical box green light is not on at all so it cannot pinpoint what the error is. Any thoughts?
Hi, I would just make sure you have power to the furnace. Check breakers or look for the power switch on the electrical box. Also, some mobile homes have a wall switch that cuts power to the furnace.
Jan 16, 2010 | Coleman Propane Forced Air Heater...
I JUST BOUGHT A USED COLEMAN EVCON FURNACE MODEL #BGU09516 AND I NEED TO KNOW HOW TO VENT IT. PLEASE HELP, THANKS
It should have a two part chimmney with a 4 inch inner exhaust section and a larger 6 inch outer section that goes over the flange on the top of the furnace. If your existing chimmney does not have this you may have to buy a chimmney kit for a mobile home application.
Dec 11, 2009 | Coleman Propane Forced Air Heater...
Dec 14, 2008 | Coleman Propane Forced Air Heater...
Heating & Cooling Logo
522 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
