Question about Compaq Computers & Internet
What is a 301 Keyboard Error and how do I correct this problem.
  • 218 Answers
Compaq used 301 as kind of a general purpose error for anything wrong with the keyboard. Some possibilities are:
1. Poor connection or keyboard unplugged
2. Bent pins or broken connection in the keyboard plug
2. Stuck key on keyboard
3. Defective or failed keyboard
4. Problem on the motherboard's keyboard input.
Check the connections, feel for any key that might be stuck, or try a different keyboard.
Posted on Sep 29, 2008
  • 33 Answers
The motherboard has device controllers that read id #'s of your hardware. When a device fails, a fail code is thrown out which is attached to the device id. Sometimes when en error has been cleared the code for that device may not. Try to boot the computer with the mouse removed & a different keyboard. Shut down & install the mouse & original keyboard. Let me know what happens
Error code 301-0001 on i-sensys MF 4450
Show error code 301-0001 after press (Problem with Canon i-SENSYS MF4140 All-In-One Laser Printer
Error code 301-0001 on i-sensys MF 4450cont: 8016185745-dulal
Nov 27, 2012 | Canon i-SENSYS MF4140 All-In-One Laser...
Error 301 on IBM 600x
HelloThe IBM error 301 POST code means the keyboard is not responding correctly. Folowing may be the reasons:-
  • You could have a stuck key, or the keyboard cable is faulty and not making proper electrical contact.
  • You could have a faulty keyboard controller.
  • You may have a faulty keyboard which may had some fluid spilt on the keys.
  • Try clean and reconnect the keyboard cable.
If this doesn't work try connecting an USB keyboard and see if this keyboard functions correctly.
If none of these work you have a motherboard problem.
Good luck, and do rate the solution if got help
Dec 08, 2010 | IBM ThinkPad 600X Notebook
Error display 301
he 301 response from your Web server should always include an alternative URL to which redirection should occur. If it does, a Web browser will immediately retry the alternative URL. So you never actually see a 301 error in a Web browser, unless perhaps you have a corrupt redirection chain e.g. URL A redirects to URL B which in turn redirects back to URL A. If your client is not a Web browser, it should behave in the same way as a Web browser i.e. immediately retry the alternative URL. If the Web server does not return an alternative URL with the 301 response, then either the Web server sofware itself is defective or your Webmaster has not set up the URL redirection correctly.
download reginout to fix it
Aug 25, 2010 | IBM ThinkPad 600X Notebook
Error code eo 301 ibm thinkpad301
keyboard error. Reseat the keyboard connection. If no resolve, replace the keyboard
Aug 09, 2009 | IBM ThinkPad 600X Notebook
Error code 301
If none of these work you have a motherboard problem. The Thinkpad 600 is a very old laptop and it would not be worth fixing. I suggest putting your money towards a new laptop.
Jul 12, 2009 | IBM ThinkPad 600X Notebook
Ff 301 keyboard error
1. This can happen if you have the mouse and keyboard plugged in the wrong ports. Can you double-check you are plugging the keyboard into the correct port.....
2. several keys pressed simultaneously
3. key on the keyboard is stuck (try a different keyboard and see if you get the same error.
Jul 23, 2008 | Computers & Internet
IBM keyboard not recognised, had 301 error, reser cmos and battery. only error message now is date/time, but can't scroll on setup screen as keyboard still wont work, tried other keyboard
Try a Microsoft/Windows update and look for the hardware update ( select Hardware updates on the left side of the page) to see if there is one for your keyboard. It may fix your problem?
Jul 19, 2008 | Computers & Internet
Error Code 07 301
With IBM Thinkpad,it telling you that some hardware is faulty, check your keyboard to make sure nothing is stuck. Also it could also be your trackpoint. Usually, replacing the damaged part gets rid of the error! However there is a bypass key sequence that allows your to continue booting the system even though it gives you error. I'm not 100% sure of what it is but somthing like ESC at boot or F1 or maybe your need the boot to the error page then press ok, then when the system comes up again press f1 or esc then. You'll have to play around with the key sequence a bit. But to get rid of the error forever you need to replace the damaged part! Regards, Armando
Apr 28, 2007 | IBM ThinkPad 600X Notebook
Computers & Internet Logo
559 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
