Question about Kenmore 73952 Gas Dryer
Kenmore 90 series gas dryer
Dryer runs for a couple of minutes then it cuts off try to start it then it makes a buzzing noise and wont try to start till you unplug it for a couple of minutes i hear something click as if something resets then you can start it again runs cuts off again
    Genius:
  • 1,028 Answers
Possible motor overheat ..if unit has a lot of lint or has had vent problems now or in past lint may have accumilated around motor and caused it to overheat and shut off.. probably to late to save motor
Posted on Sep 29, 2008
Kenmore 600 series dryer.model # 110.67622600. wont start. light goes on & off when i push and release the door switch. when i push the starter switch it make a clicking buzzing sound. more noise when...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jun 27, 2011 | Kenmore 67632 Electric Dryer
heatman101
Jun 27, 2011 | Dryers
I have a Kenmore 90 series gas dryer Model# 7691269076912 When I push the start button it whines then nothin. I used wait a few minutes and just start running. now you push the start button, it whines then...
heatman101
Oct 20, 2010 | Kenmore 77632 Gas Dryer
Kenmore 90 series dryer, motor wont start, loud
  • Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
  • If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
  • Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Hope this will fix your problem for sure.
May 10, 2010 | Kenmore Dryers
Kenmore 80 Series Gas Dryer won't run unless empty
MORE THAN LIKELY YOUR TENSION PULLEY IS SHOT WAS IT MAKING ANY SQUEEKING NOISES
Aug 26, 2009 | Kenmore 73952 Gas Dryer
Dryer doesnt go on
I opened up the lower panel of my kenmore 90 and then removed the blower cover. I found two hair pins lodged in the blower and removed them. I tested the dryer with it open and the blower and drum began to turn again. I buttoned everything back up, and it is running fine now.
Jul 21, 2009 | Kenmore 73952 Gas Dryer
Dryer makes buzzing noise but will not run.
that is the sign of a bad dryer motor-sorry-mike
May 08, 2009 | Dryers
Kenmore gas dryer buzzes but does not run
sounds like the start windings in the motor have gone bad. The only way to fix this is to replace the motor.
Feb 04, 2009 | Kenmore 73932 Gas Dryer
Kenmore 90 series won't start timer ticks
heatman101
Dec 03, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore 73952 Gas Dryer Logo
228 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
