Question about Garden
Cut orange extension cord
While cutting shrubs today , I inadversely cut the extension cord. Can it be repaired?
  • 163 Answers
Yes it can. you have to slice and solder the wires together and wrap tightly with vinyl electrical tape. if your not familiar with soldering you can have it repaired at your local repair center.
Posted on Nov 28, 2008
How do I put a light switch on a extetion cord
You want a light switch on extension cord.
What kind of light switch do you have? You posted under GFCI device which is totally different than ordinary wall switch.
And what type of extension cord?
Add a comment with more information.
If ordinary light switch is installed on 3-wire outdoor extension cord:
Slice open the side of cord and you see 3 wires: black, white and green.
Cut the black wire in half and connect each end to brass screw on light switch.
If ordinary light switch is install on indoor 2-wire extension cord.
Look at plug and notice there is a wide blade and narrow blade.
Narrow blade is hot. You want the wire connected to narrow blade.
Cut that wire in half, but do not cut other wire.
Connect each end of wire to brass screw on light switch
If you want to install line switch onto indoor 2-wire extension cord:
Narrow blade is connected to hot wire.
Open line switch.
Connect each end of black wire to brass screw. OR if no screws, then place cut wire in open grooves.
Tuck other wire into groove and then reassemble switch.
Jul 05, 2011 | Leviton 8299 Combination Switch / Smart...
It looks like the plug on the blower melted slightly now the blower doesn't work can it be repaired
Parts are few for these machines (all I found was the blower tube). That being said, you can carefully cut off and remove the faulty male plug and replace it with a repair piece like you would add onto a damaged extension cord (outdoor type). They are made of plastic, but are fairly sturdy. Just carefully cut away the old male connector (the shrod isn't really necessary and remove the wiring from it. After purchasing the male-type plug replacement, rewire it and you will be set to go. To eliminate the male cord and the female end of the extension cord you will use from pulling apart when in operation, just loop the female end cord around the cord of the blower and it will hold in place.
Mar 19, 2011 | Toro 51585 Power Sweep 7 Amp 2speed...
I have an older model RCA television ( but it's ot all the hook ups for today) and my dog accidentally ate through the cord, should I take it to a shop or just buy a used tv somewhere else & not even...
I guess it depends how far up the cord your dog ate through it! You could cut the cord off at the bite, fit a new plug and use an extension cord to reach the socket. Other than that, I don't think its an expensive job to get a complete new cord fitted - depending on the repairer, it should still be cheaper than a replacement tv
Feb 04, 2011 | RCA Televison & Video
I want to replace the cord/plug is it easy?
Malibu power packs are 1-piece units that can't be taken apart.
However you can cut off the cord and leave about 4-6" of cord sticking out, and then splice into the cord that's sticking out.
Usually I buy heavy orange or black extension cord with male-female plugs on each end.
I cut off female end and use that end to splice into the cord that's sticking out.
How to splice wire.
Use knife and slice down the cord lengthwise... just cut through the outer plastic covering.
Pull the outer cover cover back to reveal black and white wires.
Cut off extra cover.
Cut back insulation on each black and white wire.
Now you have 2 black wires and 2 white wires/
Twist together the copper wire on whites and cover with plastic electrician tape.
Do the same with copper wires on blacks.
Now the blacks are joined/ and whites are joined, and each has tape over copper wire.
Wrap black tape around both sets of wires until all the black and white is covered with several wraps of tape.
That's it. Plug it in.
Nov 23, 2010 | Intermatic Malibu 300W Power Pack...
Pulses when cutting
if your using a extension cord, either, 1-dont. 2-get a shorter one. 3-get a cord set up for rvs & convert the end for standard(cheaper than buying a welder type extension cord). if your not, the wiring or the breaker may not be matching the draw. make sure something isnt using same breaker as you. (fridg, ac etc).
Feb 10, 2010 | Lincoln Pro Cut 55
Cut extension cord
This happens a lot with circular saws too.
You can strip off the insulation from each side of the cut and connect the wires (be sure to match colors!) and wrap the whole assembly in electrical tape, but you really are best off replacing the cord.
If you do repair it, tie a knot in the cord so there's no stress on your repair job when you tug on the cord.
I just did some reading and found out the name of the knot you want is actually the "Euro death-knot" (best example is in this picture)
Tie it with the cut ends just like the ropes in the picture, then do your splice job on the ends of the wires.
Aug 03, 2009 | Electric Garden
How is float switch testing and troubleshooting ?
I use a float switch to automatically top off the water in my fishtank.  the best method I can suggest for testing the unit is to get an extension cord that you are comfortable with cutting.  Cut one of the 2 wires of the extension cord, and put the float switch in-line on this one cut wire.  Be sure to use wire nuts or something that can cover up the exposed connections where the float switch connects to the extension cord.  Once everything is buttoned up, plug the extension cord into an outlet and plug a small device which does not require much power into the other end of the extension cord, a small nightlight or something would work great.  Now move the float up and down on it's shaft to see if the connection is established to power the device.  This is essentially the same configuration that I use for my fish tank topoff and the deivce at the end of the extension cord is a pump which sits in a rubbermaid full of water.  Works great!!  Hope this helps.
Regards,
Joe
May 07, 2009 | Zoeller 10-0034 Switch-Mate Pump Float...
Fan not working
THE FAN MAY OR MAY NOT HAVE OILING PORTS ON THE MOTOR. IF NOT, THE MOTOR NEEDS REPLACED. IF THERE ARE OILING PORTS ON THE FAN MOTOR, TRY SPRAYING SOME WD-40 IN THEM AND THEN ADDING SOME LIGHT MACHINE OIL TO THE MOTOR. THE OILING PORTS ARE SMALL HOLES AT EACH END OF THE MOTOR WHERE THE MOTOR SHAFT EXITS THE MOTOR HOUSING.
Mar 22, 2008 | Kenmore 54501 Dehumidifier
Garden Logo
1,169 people viewed this question
Top Garden Experts
EugenesDIYDen
EugenesDIYDen
Dennis Key
Dennis Key
john h
