Question about Bosch Nexxt Premium WFMC6400UC Front Load Washer
Bosh error code E02
I got a new bosh washer Nexxt 500 series, I was trying to set  it up for the first wash , I followed the directions for the first wash and while doing so, I got the Error message E 02, the manual doesn't have the solution for this error code Please help.
My email is coco999@gmail.com
  • 3 more comments
  • Monty12 Oct 02, 2008
    Same E02 error on very first start up?
  • luannsemail Oct 25, 2008
    Yes, I am having the same problem. It is our first day using ours also and there is no reference to the E02 in the manual.
  • Anonymous Nov 18, 2008
    I'm a little sick of this too.
  • Anonymous Dec 27, 2008
    Me too. If anyone figures it out, please email me at jeremywood@pobox.com. Thanks.
  • Anilise Andersen-Stewart
    I am having the same issue. I NEED CLEAN CLOTHES! If anyone knows how to solve this please post answer or email me @ ms_annie@email.com
    Thanks!
Hi. I had the same problem with my Bosch washing machine and called Bosch...was told the same thing...$99.00 for service call. I managed to fix my problem by doing the following:
  • Removed hot & cold water supply hoses.
  • Took filter screens out of both hoses.
  • Removed filter from cold inlet on back of washing machine. I noticed some oily buildup on both of the cold screens so opted to not put any of them back in.
  • Then I put hot & cold water supplies back on the wall hookup, but crossed the lines where they came into the back of the machine intentionally so that the hot water line fed into the cold side of the washing machine and vice versa.
  • Then I ran a couple loads on "cold" which was actually hot water coming in to the machine.
The reason I did this was that I figured there must be some more waxy buildup inside the machine in the cold lines and hoped the hot water would melt it like when you rinse a greasy pan under hot water. IT WORKED!!! I hope this helps you.
Posted on Jan 18, 2009
How to register my new Bosh washer
You can do so online here: http://www.bosch-home.com/us/support/product-registration.html
Dec 28, 2016 | Bosch Washing Machines
Bosh 500 series dryer wont heat and rest button wont push in.
then u definately have a problem,and would be better getting a tech to look at it for u
Jan 19, 2014 | Bosch Nexxt 500 Dryer
My bosh frontload washer wont spin or drain
If it does not drain, then it will not spin.
Locate and clean pump filter.
Aug 06, 2010 | Bosch Nexxt Premium WFMC6400UC Front Load...
On the regular cycle for Bosch Nexxt 500 series, during the warm or hot cycle the washer interrupts the cycle with error code "E02" and stops washing . . . how can I fix this? I've made sure the door is...
If the unit is fed by both hot and cold it is possible that the single hot valve or one side of the double cold valve is not operating. Maybe a silly question but could one of the taps have been turned off inadvertently?
The other possibilty is that the pump filter or outlet hoses are blocked and the machine cannot empty the detergent water ready to refill with clean rinse water. To test the cold valve put the w/m on a cold wash cycle, open the drawer and check the water flow. To test the other part of the same valve, put the w/m on the rinse cycle that would take the softener or a wash cycle with prewash. Test hot valve by selecting the hottest cycle usually 90 or 95 degrees, check water flow thru drawer. Hope this helps.
Jul 10, 2010 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Noisy pump in bosch nexxt 500 washer
no its usually not that loud at all contact bosh direct to have them send you a new one or call them if its still warrantied
May 01, 2010 | Bosch Nexxt 500 WFMC3301 Front Load Washer
I put a load of clothes in my bosh nexxt 300 washer, went out to the store and such come home to put the clothes in the dryer, the door is locked, no lights on the washer. The washer is plugged in and plug...
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} This is for the WFMC6400, but it could help.
To manually unlock the door lock system, perform the following steps:
1. Unplug the power cord from the outlet.
2. Remove the lower toe panel.
3. Reach up along the inside of the front panel and
locate the bottom of the door latch assembly.
4. Located on the bottom of the door latch
assembly is a teardrop shaped tab.
Gently pull the tab down approximately 1/4 inch,
or until a click is heard.
5. The door may now be manually opened.
Pl give me a ‘very helpful’ rating for the free help, thanks!
Apr 24, 2010 | Bosch Nexxt 300 Series WFMC2201UC
I have a Bosch washer wfc5301uc it is showing error code E02
Could be a faulty inlet valve, or not enough pressure to operate valve,
Remove hose onto valve, and check the water is getting to it o/k,turning off the water to the valve before you undo the hose.
Hope this helps.
Jan 10, 2010 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Bosch Nexxt 500 Series Washer Will Not Add Water
during a normal wash cycle the washer stopped and gave an e;4 error code
Dec 21, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Bosch Nexxt Premium WFMC6400UC Front Load Washer Logo
1,059 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
