I own a 2001 Ford Taurus and two years ago it was losing anti freeze also. Found out that the plastic recovery tank located in front of right strut mount on fender well, had a small stress crack. It only leaked when engine was at opperating temperature. If that is not the solution, check all your spark plugs for a green-ish or yellow-ish color you have a cracked head. If they all have a light tan to dark tan color (on the white porcelin) you're good. One final check would be the crankcase oil. If the oil on the dip stick has a creamy look to it then your leak is in the intake manifold and also if the oil is oddly over full. If all these inspections turn up good you then have a external leak and need to have the engine at opperating temperature and park it on a clean surface over night. Inspect the engine compartment, engine and the floor with a LED flashlight not a regular bulb flashlight. The LED light will make the antifreeze slightly glow. If the heater core is leaking, the antifreeze will run out the air conditioning condensation drain hose, check with LED light.
