Question about Garmin nuvi 650 GPS Receiver
Garmin nuvi 650
The voice, volume , music just stopped working . I did a reset, restore and webupdate.. Still nothing, Bought it last Nov. with Costco close out. Any suggestions?
  • 1 more comment
  • redgeedoe Sep 30, 2008
    thanks jim.. headphone jack does work. it seems as if its the internal speaker. will call garmin, thanks.
  • Anonymous Dec 28, 2008
    Brand new out of the box there is no audio at all. Even tried playing the sample music
  • Anonymous Jan 11, 2009
    how do you take the cover apart on a nuvi 650 to get at speaker and headphone jack
  • Garmin Master
  • 2,130 Answers
If you bought it last November, it may still be under warranty. You should call Garnin and see if they will replace it for you free of charge. www.garmin.com
If it's no longer covered under warranty, then I would try plugging in a set of headphones into the headphone jack and listen for audio there.
If you hear audio there, then your internal speaker is bad. I have seen this problem on many Nuvi's.
- Jim
Posted on Sep 29, 2008
No sound
Turn the volume up. Turn on the Garmin Nuvi. Tap the "Volume" button on the "Where to?" or home screen. Move the slider for the volume up.
Unmute the Garmin Nuvi. Tap the "Volume" icon again. Uncheck the "Mute" option, if it is currently checked.
Make sure the voice is not faulty. The navigation instructions are provided by a voice.To verify whether or not the present voice is faulty, you must switch the voice. Power on the Nuvi and tap the "Tool" icon. Tap "Settings" in the Tool menu. Tap the "Language" option and tap the language you want. Then select another voice to use. Now go back to the home screen and enter an address into the "Where to?" option. See if you can hear sound now.
Update the Garmin Nuvi with WebUpdater. Download and install WebUpdater from the Garmin website (see Resources). Launch WebUpdater on the computer, and connect the Nuvi to the computer with the USB cable. The software will detect the Nuvi and locate all updates for the device. Confirm that you want to update the device when prompted and WebUpdater will download the updates to the Nuvi.
Reset the Garmin Nuvi. A master reset will restore the Nuvi to its factory configurations and delete all favorites and waypoints that have been added. Power off the Nuvi and unplug it from any power source. Hold your finger down on the bottom right corner of the Nuvi screen, at the same time power the device back on. When asked "Do you really want to erase all user data?," remove your finger from the bottom corner of the screen and tap "Yes." The device will reset and sound should be restored.
Here is a direct link to the user manual >>
http://static.garmincdn.com/pumac/nuvi_1100_1200_1300_1400_OM.pdf
Jan 06, 2012 | Garmin Nuvi 1490LMT GPS Receiver
Tip
Garmin Nuvi 1450 Webupdate Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi...
Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245 , Nuvi 1250, Nuvi 1255, Nuvi 1260
Models: Nuvi 1300, Nuvi 1300, Nuvi 1310, Nuvi 1340, Nuvi 1350, Nuvi 1370, Nuvi 1390
Models: Nuvi 1410, Nuvi 1440, Nuvi 1450, Nuvi 1490
Does your Garmin Nuvi 1450 GPS get stuck or freeze at startup, or when loading maps?
Looking to reflash the firmware / system software for your Garmin GPS device?
Replacing the brains of your Garmin GPS is the surest way to resolve freezing, hanging, and erratic behavior. Keeping the system software and firmware in your Garmin GPS current and up-to-date is also the best way to keep it performing well.
Your GPS may not start properly at all, and display a 'System Software Missing" message. This tip will describe how to restore your Garmin Nuvi GPS system software using Garmin Webupdater.
  1. The first step is to download the WebUpdater software.
  2. Plug in your Nuvi GPS into your PC with the USB cord.
  3. Run the WebUpdater program to install it to your computer and update the system software of your GPS.
Your Garmin Nuvi should now be running as good as new.
I hope that helps.
________________________________________
Garmin Nuvi 1450 Manual Download
Garmin Nuvi 1450 QuickStart Download
Garmin Nuvi 1450 Favorites Backup
Garmin Nuvi 1450 Hard Reset
on May 27, 2010 | GPS
Tip
Garmin Nuvi 1390 Webupdate Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi...
Does your Garmin Nuvi 1390 GPS get stuck or freeze at startup, or when loading maps?
I hope that helps.
Garmin Nuvi 1390 Manual Download
Garmin Nuvi 1390 QuickStart Download
Garmin Nuvi 1390 Favorites Backup
Garmin Nuvi 1390 Hard Reset
on May 15, 2010 | GPS
The voice will not come on. It's not on mute and I have rebooted it a few times
A Garmin Nuvi 1300 that won't start, freezes on 'loading maps,' or is acting erratically is symptomatic of having corrupt firmware.
To correct this, I recommend backing up your favorites, clearing all user data, and if it still is stuck, then updating your Nuvi firmware.
Follow these three steps to take to get your Garmin Nuvi 1300 running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
Garmin Nuvi 1300 Manual Download
Garmin Nuvi 1300 QuickStart Download
Garmin Nuvi 1300 Favorites Backup
Garmin Nuvi 1300 Hard Reset
Garmin Nuvi 1300 Webupdate
Apr 17, 2010 | Garmin nuvi 1300 Car GPS Receiver
Tip
Garmin Nuvi 1350 Webupdate Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245...
Does your Garmin Nuvi 1350 GPS get stuck or freeze at startup, or when loading maps?
I hope that helps.
Garmin Nuvi 1350 Manual Download
Garmin Nuvi 1350 QuickStart Download
Garmin Nuvi 1350 Favorites Backup
Garmin Nuvi 1350 Hard Reset
Tip
Garmin Nuvi 1210 Favorites Backup and Restoration Procedure Models: Nuvi 1200,...
Would you like to back up a copy of your Garmin Nuvi 1210 Favorites and Waypoints?
Backup and Restoration Procedure for Favorites:
  1. From the Nuvi drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer.
  2. After a hard reset or loss of data, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
  3. On the next power cycle, the Favorites will be read from 'temp.gpx' into the non-user accessible memory area on the Nuvi where they are actually stored.
I hope that helps.
Garmin Nuvi 1210 Guide Download
Garmin Nuvi 1210 QuickStart Download
Garmin Nuvi 1210 Webupdate
Garmin Nuvi 1210 Hard Reset
We have 3 nuvi265w that have no voice. Also one will not pair to any bluetooth device. They had voice in the beginning and now do not. I did the update downloads and that seems to be when we stated having...
I can help you reset and fix your Garmin Nuvi 265W. If your nuvis are not acting properly after a webupdate, try it again with the newest webupdate software (available below). After backup up your favorites, and performing the webupdate, try the hard reset AFTER the webupdate. This sequence has been known to help.
  2. Download and then run Garmin WebUpdater to replace its firmware / system software.
  3. Perform a Hard Reset.
I hope that helps.
Nuvi 265W Manuals here.
Oct 04, 2009 | Garmin Nuvi 265W GPS Receiver
Downloaded and installed Bluetooth firmware update - Won't Pair
I recommend rerunning the webupdate software available below, which was updated March 30, 2010. Run through the update steps again.
  3. Download and then run Garmin 265WT WebUpdater to replace its firmware / system software.
After successful webupdating, a hard reset is often helpful at this time, too.
I hope that helps.
Nuvi 265WT Manuals here.
Sep 09, 2009 | Garmin nuvi 265 Car GPS Receiver
I have lost my sound on my garmin 750 gps
I had a similar problem on my vacation. the voice stopped working suddenly. in my case i could get it working again by reselecting the voice (american/british etc) in the language section. for some reason it had reset to blank.
but i still cannot get the text to speech to work.
Feb 27, 2009 | Garmin nuvi 750 GPS Receiver
Garmin nuvi 650 GPS Receiver Logo
262 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
