Kv32fq86 wega when I Turn on tv power light flashes 3 times and tv doesent come on
  • wofuller Nov 11, 2008
    no power on -- cont'l button just flashes and then nothing
  • Anonymous Mar 17, 2009
    power on,red light flashing, no screen
SOURCE: Sony Trinitron Wega kv-36fs120 wont turn on, standby/timer LED flashes 9 times.
try checking the soldered joints on the main circut board that attach the larger metal components...I re-soldered aprox 40 connections and now the tv works great!
Posted on Jan 31, 2008
  • 61 Answers
SOURCE: Sony Wega 40" TV will not turn on, standby light blinks 6 times repeatedly
Hello,For model KV-40XBR800,
Pls check following area.
Low HV Shutdown:
On the D Board.
Check IC8004/pin 7 should be 7.4v.
Check IC8006/pin 2 should be 2.5v if lower will trigger shutdown by causing pin 1 to turn on.
Check IC8006/pin 3 reference voltage 2.2v.
IC8006/pin 1 normally at 0v. If high
turns D5007 ON which turns the latch circuit Q6532,
Q6530, and Q6527 ON and turns the AC relay RY6501 OFF.
And NOTE: 6 blinks also can be Low B+ protection.
Unregulated 7.5 v from the power supply to 5v reg IC504 on the A Board. 5v to M Board Q2314
to CPU IC2300/pin 43. If 5v missing set will shutdown with 6 blinks.
Good Luck
Dals123
Posted on Oct 15, 2008
mistersony
  • 320 Answers
SOURCE: standby light flashes 3 times
A 3 flash pattern indicates that either the lamp is not seated correctly or that the lamp door is not latched properly. It can also be a fault with the switches that sense whether the lamp is seated or the door is latched. Try reseating the lamp and relatching the lamp door
Posted on Oct 20, 2008
ladywinn
  • 5138 Answers
SOURCE: Sony KV36H5500 WEGA TV (flat screen tube) will not turn on
Pull the back Off Disconnect CRT board connected at End of picture tube then turn set on and see if it comes on with volume, high voltage you can feel front of tv for static elect.... Let me know what happens then i can tell you what is wrong with TV.
Posted on Dec 27, 2008
SOURCE: Sony FD Trinitron WEGA KV-24FS100 24" TV On/Off problems
I have spent about 4 hours tonight researching several tech sites and the Sony service manual for the same problem with my Sony KV-32HS510 unit. I was able to download the manual from a website http://www.eserviceinfo.com/downloadsm/31649/Sony_KV-32HS510.html and a TV Repair training lecture paper at http://www.repairfaq.org/sam/tvfaq.htm#tvhvp .
These TV sets have a safety feature where it will shut back down if a high voltage is indicated. Unfortunately, the electronics for these safety features are not very reliable and give false indication. Letting the unit sit off lets the capacitors leak voltage as well as cool off. These two factor help with the unit not falsely indicating a high voltage condition.
The D Board seems to be the most common failure component, but a 6 times flash could be an overcurrent/voltage failure from the A, B, or M boards. A 7 times flash is a Horizontal Deflection Stopped error with no additional information given in the manual for a fix. Again, in most blogs, the D Board seemed to the source of the failures.
A refurbished D Board part no. A1300319A can be bought for around $200 with a new board at $550 per the www.partstore.com site. Then add $100-$200 for an actual TV service technician and you have a repair bill approaching the costs for a new flatscreen TV.
Some tech types posted that they have actually repaired their boards by replacing individual components for around $40. You may find a service shop that can do the same component level repair at the $100-$150 level cost. It turns out that the closest authorized Sony repair shop is 2-1/2 hours away from us. Good luck finding someone close by.
We were able to get our TV to come back on after dozens of attempts and plan to leave it on until it dies all together. I may attempt my own D Board replacement when the time comes.
Posted on Jan 07, 2009
I have a sony wega kdf 55e200. When i turn it on i get maybe 4 green flashes of the power light, followed by 3 red flashes. I've already spoken to tech support and they've explained to me that it means the...
Tries unplug,replug tv an hour later,that a reset tv back to factory setting.See,that solved ur problems.Not, than the lamp u have might gotton shorted some how.Buy a another lamp.Tries the same process.
Sep 17, 2010 | Sony Grand WEGA KDF55E2000 55" Projection...
Sony Grand WEGA KDF-60XBR950 60 green orange green red flashing light
3 blinks is a lamp cover error, did you make sure that the lamp cover is screwed in tight? Also check the lamp cover for deformity, there is a problem with your model where the set over heats and melts the lamp cover a little causing it not to make connection with the lamp cover switch. Let me know if you find either of these problems? If not we can troubleshoot a little further.
Tim Nolan
Sep 14, 2008 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Changed lamp and TV won't turn on, power light flashes 3 times
Red light blinking 3 times shows problem with lamp cover.
Lamp cover is not fixed securely in your tv after lamp replacement. Lamp cover is first thing that was removed to replace lamp, check lamp cover and make sure its back in place properly.
Thanks.
Jul 17, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
I have a Sony Wega KV-34HS420 TV that takes several tries to turn on. When I push the power button or remote power on I hear the normal click and the sound comes on for 3-5 seconds but then I hear a second...
Since the set appears to "recover", it suggests either a poor solder connection or bad cap somewhere in the power supply. The 7 blinks indicate the problem circuit is in the horizontal area. Check the regulator (STRxxxx) IC in the power supply. If you do not have experience working with TVs, please refer this repair to a shop. The regulator IC costs around $25.
Dan
Nov 16, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
TV will not turn on
Sounds like the power supply needs replacing.
TV repair is best done by a pro unless one has significant experience with it.
Charlie
Aug 15, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony grand Wega 50E20000 power light flashes 3 times
Check the fan is coming up to speed when you first switch on it should be high speed then slow down slightly. If the fan is not cooling the lamp the tv will turn off to protect the lamp
Jul 19, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
SONY GRAND WEGA KF-50WE610 can't turn on TV screen.
Ths 5 blinks usually indicate an AKB problem. There is a break in the video path. I'll look up your specific model and post the results here. Please update this if you wish to attempt the repair yourself.
Thanks,
Dan
Mar 19, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony FD Trinitron WEGA Tv KV32FQ86E two flashing led
The high voltage power supply is going bad on both units.. Pretty soon, it won't power up at all. For a fact.
Don't try to replace the power supplies, TV's are too cheap.
Feb 01, 2009 | Home Security
60 inch sony wega tv
Green flashing is normal. Red flashes are error codes. Count the error flashes.
3x - Lamp cover position or cover detect switch bad.
4x - One or more fans failed RPM test
5x - Lamp power supply/ballast failure
6x - Thermal fuse failed (usually)
Oct 16, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
Sony FD Trinitron WEGA KV-36HS500 blinking red light 6 times
smack it on top a couple of times, it works for me :)
if ya cant duct it, smack it...
seriously...
Jun 29, 2008 | Sony FD Trinitron WEGA KV-32HS500 32" TV
Televison & Video Logo
52 people viewed this question
Top Televison & Video Experts
