See like pc was hanged
There are many things that might cause your PC or any application in your PC like outlook express to run slowly or freeze or even restart at time and then. It could be a fragmented disk, fragmented registry; a virus, Trojan, or spy ware; high CPU and/or utilization due to too many programs running; high disk I/O; caused by an infection.
To check your CPU and memory utilization, run Task Manager. You can start Task Manager by pressing CTRL+ALT+DEL and then clicking on the Task Manager Button. In Task manager, click on the Performance tab and check CPU Usage and PF Usage. PF Usage is an indicator of memory usage. If one or both of these is high, click on the Processes tab, and sort the columns by CPU or Memory to see what processes are consuming the resource. If you are not sure what the process "Image name" is for, Google the name and you should find what the process is for.
If your CPU and memory usage are reasonable, then you may have a different issue. Even if you running anti-virus software, it may be beneficial to scan your PC with another scanner to check for viruses. No anti-virus software is 100% perfect at catching everything. Here are a few good virus scanners that you can run to check your PC:
So here is the best solution that I can suggest for you is to scan your
PC with a very strong antivirus, here is the link to get it.Its very good.
http://f1226ed7g6j0vsm6nlwdh440fx.hop.clickbank.net/?tid=DMWDH6W3
To clean up registry there is another very good application which will keep your PC registry out of trouble caused from spywares.
http://6d099feff2g50wdmmpgh0brrf1.hop.clickbank.net/?tid=DMWDH6W3
