Question about Frigidaire Refrigerators
Ice maker will only dispence crushed no cubes
  • skally Oct 30, 2008
    I have the same problem, Ice maker will only dispense crushed not cubed, Light on display is on and will change from crushed to cube but will not dispense cubed ice
  • bseawright Jan 11, 2009
    I have the same problem; maks crushed ice and no cubes.
    Problem Solver:
I have the same problem; been doing some reading and it sounds like a solenoid problem. There's apparently a solenoid behind the ice maker that controls the crushed/cubed option. So either the switch is bad, the wiring is bad, or the solenoid is bad. Just my guess, but that's where I'm leaning so far.
Posted on Dec 15, 2008
Dispencing crushed ice only on cubed setting
Remove the ice maker and check to see if ice is blocking the dispenser door from opening completely.
Jan 16, 2011 | GE GSH25JSTSS Stainless Steel Side by Side...
GC3SHEx300 ice dispencer does not dispense cube or crush ice. Water comes out, lights work. it is not deactivated.
Sep 06, 2010 | Whirlpool 21.8 cu. ft. Side-By-Side...
My ice maker produces ice just fine, however when I try to receive "Cubed Ice" it dispences it "Crushed". It makes no difference if the front panel "Cubed Ice" button is pushed or the "Crushed Ice" button...
Not sure what brand you have but I had a similar problem with a dispenser once. The ice dispenser would freeze up and couldn't change over from one to the other and I'd have to take it out and let it thaw occasionally and then it would be fine for several months again. If your ice bin is in the door this may be what you need to do.
Jan 25, 2018 | KitchenAid KSRG22FK Side by Side...
Ice maker stuck on crush, continues to crush ice when cube button is pushed.
Remove ice bucket,check solonoid on back wall behind bucket may be stuck in up position pull down and recheck dispencer.
Jul 14, 2009 | Frigidaire GLHS66EE Side by Side...
Will not dispence ice, crushed or solid cubes, will dispence h2o
If the ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
and if the ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Please do rate the solution as "FixYa" and revert for further assistance.
Apr 09, 2009 | GE Energy Star 22.0 Cu. Ft. Side-By-Side...
Ice cube button is lite but the only dipenses crushed ice
We have had this problem on occasion. The lever up in the ice dispencer gets jammed with frost and ice. If you remove the ice bucket/auger and let it thaw or just rinse it with water and dry it. Give it a try. -Matt
Mar 13, 2009 | Frigidaire FRS26R4A Side by Side...
Ice cube maker only dispences crushed ice no cubes
remove ice bin look at small square opening reach in with your finger and pull down on vertical rod if it doesn't come down you'll have to remove complete auger asm from freezer (remove 2 1/4 screws and unplug electrical connection lift asm up and pull forward ) set out at lest 24 hours for asm to defrost and dry out then reinstall auger asm
Dec 19, 2008 | Frigidaire FRS3R5EMB Side by Side...
Ice maker will only dispence ice cubes and not crushed ice
what brand? I cannot see your reply due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Nov 28, 2008 | Whirlpool Refrigerators
test the solenoid voltage in auger assy. its a little tricky.
Jul 30, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
480 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
