The dryer (1998/9) makes a metal screeching noise, that is sometimes continuous, and sometimes quiet. ALso drying is not very efficient. ANy solutions? IN order to repair (either the drum roller bearings etc., is there a good schematic or how to fis yourself video? Maytag's service manual drawing are worse than the Maytag Dryer! You cannot see any aspect of the design poperly and the written part is not very descriptive.
If your dryer is noisy, check these:
Rollers
Many
dryers use rollers or wheels to support the clothes drum. When these
rollers are worn, they can be noisy. You should replace the whole set
of rollers at the same time.
Idler pulley
Dryers
have a tension or idler pulley that keeps tension on the main drive
belt. When it's worn, it can be noisy. When that happens, don't
lubricate it. Just replace it.
Glides
Many
dryers use nylon or plastic glides at the front of the clothes drum for
support. When these are worn, they can be noisy. When that happens,
replace them.
Rear drum bearing
Some
dryers support the clothes drum in the rear with a center spindle
instead of rollers. The spindle may be a ball-and-socket type support
or a shaft through a sleeve. When the components are worn, they may
squeak, squeal, or rub. You can't repair them. Just replace them when
they're worn.
Blower wheel
Your
dryer's blower wheel pulls air over the heat source, through the
clothes drum, and past the thermostats, then pushes it out the exhaust
duct. The blower wheel, which is usually plastic, may wear out over
time. But if it's noisy, it may simply be clogged with lint. Clean the
blower and test to see if the dryer is still noisy. If it is, you
probably need to replace it.The following site provides mor troubleshooting info:
http://www.repairclinic.com/0088_8_1.asp#Level1_4
Hope that helps! Should you have any further questions,
please feel free to post them here.
P.S. - If you find that the solution/answer
I provided led you to, or resulted in a fix, please close the ticket with a FixYa!
rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
