Question about Ovens
Oven door outer glass shattered
I have a kenmore oven and the outer glass shattered. it appears to be tempered glass, because it shattered like a windshield. how do i get it replace and how much does it cost!
  • Anonymous Mar 18, 2014
    removal of outer glass on oven door
  • 725 Answers
Will need a model number to tell you the correct price ... most will have to replace the door... you can also give sears a call .. if you gripe loud ... they may replace it for you...
Posted on Sep 29, 2008
I have a Frigidaire Caprice double oven, 45 years old, the inner glass panel on the top oven door has shattered. I am not having any luck with finding replacement glass, any ideas?
take a profile of the glass shape (cut out the shape from cardboard) and go to a glass supply shop ( glass windows , doors , shower screens etc)
they should be able to cut and then temper the glass to make it heat proof for the door
if they cannot temper it they should be able to tell you where you can get it done
Nov 12, 2016 | Frigidaire Ovens
Please tell me if Electrolux EKG5547XN Cooker Main Oven Glass Door would fit my EOB6632U
Glass oven door is not compatible.
First of all, the oven door EKG5547XN has only two glasses, inner and outer, while the oven door EOB6632U has three glasses; inner, middle and outer.
EKG5547XN
Inner glass oven door, part number: 349 00 30-01/6, silkscreened; dimension: 456 x 323 mm, tempered glass.
Front glass oven door, part number: 349 10 45-14 / 6, stainless.
EOB6632U
Inner glass oven door, part number: 899661 92 68-78 / 3,
silkscreened; dimension: 479 x 391 mm, tempered glass.
Middle glass oven door: dimension: 447 x 380 mm.
Front glass oven door: dimension: 589,5 x 466 mm.
Dado
Mar 28, 2015 | Electrolux Ovens
Korting oven
contact the dealer/ distributor in your area or contact the maker direct. You may be up for a new door as sometimes the glass is glued into the door for sealing purposes.
May 18, 2013 | Ovens
The outer oven door glass shattered suddenly how do I change it?
I depends on how old your oven is. If you're lucky you may be able to get a replacement glass. If not take some measurements and see a glass supplier. You will need a piece of tempered glass.
Feb 07, 2011 | Ovens
The outer glass on my hotpoint oven door has shattered do i need special replacement glass
You must replace it with the glass as supplied by the manufacturer, as it is is special heat tempered glass.
Nov 11, 2010 | Hotpoint DY46 Style Line Stainless Steel...
Amana oven model ACF4225AC the big oven power ...
have and Amana oven/stove model ACF4225AC that is 8 yrs old. Middle glass (thick tempered) part # 32028101 completely shattered. Oven was not on for at least a week, noone was near it,was not hit,and at 9 AM while I was in other room it just shattered into a million pieces. Went to dealer- looked up part and found it was no longer available. I have been checking internet appliance part companies, and e-bay to no avail. Cannot find replacement glass. Any suggestions? Thanks, Jim
May 21, 2010 | Ovens
Kitchen Aid microwave door -- outer glass
Lisa, I do not have a solution, but have the same problem. My KA superba micro has been used about 10 times. While it was off, and while no one was home, the outer glass in the door shattered. I suspect this may be a defect.
Jun 19, 2009 | KitchenAid Architect Series KEMC308KSS...
TKC 8522/2 top oven outer door shattering
It is not a fault with the door, and this sort of event occurs quite often, so is not uncommon.
All sorts of things can cause this, sudden change in temp, getting the glass wet whilst it is still hot, a knock or bang form an earlier time could have weakened the glass.
The list is quite long..
Depending on your household insurance, some policys cover for breakage of glass fittings, would be worth checking.
Plz rate my solution
.Thanks.
Dec 30, 2008 | Tecnik TKC8522 Electric Double Oven
Whirlpool oven door
the rep is right as of yet there is no recalls on this problem and yes they are tempered but in my many travels I hve only seen two do this once you have the glass replaced this will take care of the problem also if you use a oven cleaner that is not made for self cleaning ovens and get even a drop on the glass it will shatter
Oct 19, 2008 | Whirlpool RBS245PD Electric Single Oven
Outer glass plate
glass was not tempered correctly contact the manufacture or possibly industrial glass products in ambridge pa they make them
Dec 14, 2007 | Miele H326-3 B Electric Single Oven
Ovens Logo
813 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
