Question about Frigidaire GLTF2940ES Front Load Washer
E20 ERROR MY FRIGIDAIRE LTF2949FS WASHER MACHINE IS GIVING ME A E20 ERROR Y DOESN'T SPIN
  • FINGO35 Oct 13, 2008
    Thanks Rattrapp, that was the problem the impeller had a hair pin stock and wouldn't let it drain, I did it thanks to you.
  • norris_lindy Nov 14, 2008
    Thank you so much for the solution. you were right on the button. Drain pump was clogged.
  • 3 Answers
I HAD THE EXACT SAME PROBLEM E20 ERROR SO MY HUSBAND DID THE EXACT SAME THING AN DRAIN THE PUMP IM SO GLAD WE FOUND THIS WEB SITE THANKS FOR THE INFO ITS FIX NOW .THANKS SO MUCH TAMMY MADDOX
Posted on Oct 13, 2008
  • 29 Answers
It doesn't spin because it has to drain first. E20 means not draining. You'll very likely have something caught in your drain pump. If you take the two screw off at the front, very bottom of you washer you'll be able to pull down the small panel to reveal the drain pump at the right corner. if you empty all the water from your machine you can take off the spring clamp attaching the thick rubber hose from your tub to your drain pump. ( you may want to have some old towels ready ) With this off you can feel around for what's blocking the drain pump's impeller. You may want to take the screws out that secure the drain pump to the base and the other spring clamp that attaches the drain hose to the drain pump. Good luck!
E20 Error
Hello Diane Snow, thank you for your inquiry!
I understand that your Frigidaire washer is displaying "E20" error code. The "E20" error code means water is not pumping out fast enough. First, you want to check the hoses for restrictions.
If the hoses are not restricted it could be an issue with the drain pump or control board. I would suggest seeking assistance from a professional technician for proper repair. I hope this is helpful. -Matt
Oct 06, 2014 | Frigidaire Washing Machines
Frigidaire front load washer (LTF600ES1) Error E20
this is an error that indicates the tub is clogged or draining slowly
to fix this you have to go under the washer and pull the tub hose off and clean all obstructing stuff in the hose and thru the hole on the tub
Oct 18, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire front load washer (ATF6000SF1) error E20
E20 is not an exact error code. It's indicating a possible pump out problem. Here is a few possible causes of an E20 error code:
1. Restriction in the drain pump
2. Failed pump
3. Water not pumping out fast enough (crimped drain hose)
4. Too many suds ( too much detergent or wrong kind)
5. Pressure switch (not communicating with control board)
6. Loose wire at pressure switch
7. Loose wire at pump or control board
8. Failed control board
Nov 29, 2012 | Frigidaire ATF6000ES Front Load Washer
I have a Kenmore Elite washer, model 44092. The machine won't spin and the error code is E20. What is wrong with it?
The machine, based on the error code, is made by Frigidaire for Kenmore. Error code E20 pertains to a slow or no drain problem which can be due to a clogged/kinked drain hose, blocked drain filter/coin trap, or a broken drain pump. The link below provides the detailed troubleshooting procedure of this error code.
Error Code E20 on Frigidaire and Frigidaire-made (including Kenmore) Front Load Washing Machines
Aug 20, 2011 | Washing Machines
E20 error, but isn't spinning
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing Machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 14, 2010 | Frigidaire Affinity ATF7000ES Front Load...
E20 message want spin
2. Failed pump
Apr 29, 2010 | Frigidaire ATF6000ES Front Load Washer
Wont spin
check drain pump for obstruction, (access from rear panel) pull hose boot from tub and ck basket in hose. read tech sheet for code definition while your there. have plenty of towels and wet vac ready
Mar 15, 2009 | Frigidaire ATF6000ES Front Load Washer
Washer won't drain completely. gives me an error code E20. affinity atf 6000
YOU NEED TO CHECK FOR A BLOCKAGE IN THE PUMP OR THE PIPES LEADING TO THE PUMPS.ALSO CHECK IF THE PUMP PROPELLER IS SPINNING CORRECTLY AND IT HAS NOT BEEN DAMAGED.GOODLUCK.MOHAMED
Sep 16, 2008 | Frigidaire Washing Machines
E20 ERROR CODE
Plug off the mains. First drain out all your water by lowering the exit hose into a bucket or drain. You have to look for screws below the front kick-panel, the panel comes down & out. The pump is on the right side. Be prepared for dirty water. Inside the big flexible tube (coming from the tub bottom) is the filter, be prepared to find all sorts of junk here, clean out. Examine your pump also, clean out the impeller. Carefully refit all. Your machine would be fine. Don’t wait for the machine to jam to look into your filter.
Jun 26, 2008 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire affinity front loading washer
Any E20 code means your washer doesn't drain.  More than likely there is a screw, nail, coin, bobby pin, etc locking up your pump and causing it not to drain.  Keep in mind that your washer has a 1 yr warranty but some service companys will charge for this kind of repair because it is not technically covered under warranty.
Aug 21, 2007 | Frigidaire GLTR1670A Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
160 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
