Question about Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
BRAVIA TV KDL-40V2500
I have my TV connected thru a HDMI cable to my cable box. TV screen goes on-off for a few seconds. With the HDMI cable connected the sound goes off. Without the HDMI the sounds continue. I have tried to change the HDMI but the problem persists. Do you think this is something to do with an internal failure of the screen? This was purchased around 5 months ago.
  • Anonymous Mar 25, 2014
    Model Bravia KDL 32L504. Tv powers on, picture blinks for one second and blinks off again. Green power light remains on...no blinking. This happens with HDMI & cable box connected, same without. I tried power reset with no results. Can a software update be run with the TV in this condition? Or will that make any difference.
I had the same problem and the only way i could solve it was to disconnect power from the tv, let it "reset" then it would be ok for a bit. the problem went away entirely when the cable company updated its software for its hd box. might be coincidence....
also, pre-update, the resolution wouldnt automatically set correctly. If I turned on the tv to a hi def station, it would set to 480 and only set to 1080 when i changed to a normal station then back to the hd. then it was fine. again, after the update from the cable company this went away.
Posted on Nov 05, 2008
Sony BRAVIA KDL-40V2500 audio not working
I would Google the model number carefully for "problems" "no sound" and usually this set will display some kind of error code===it may even have a hard reset to try===service manuals are available on the net/web to allow you to see how the sound circuit is set up etc.
Mar 29, 2012 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
On my sony bravia tv if i use bt vision box hdmi 1 is displayed in left hand corner of tv screen how do i turn this display off
On the remote control on the top left corner a button marked i+ is there. Press it. This will eliminate the hdmi sign.
Oct 27, 2010 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
I'm trying to use my bravia as a computer monitor.
Your Bravia should have a 15 pin PC input, this input can take most standard PC resolutions, however if you a have a video card with an HDMI port, you should set your resolution to 1920 x 1080 @ 60Hz refresh rate so that the signal can be recognized and processed, many standard PC video resolutions are not compatible with the HDMI inputs. You should not require audio cables unless you are using a DVI to HDMI connection.
Crampy
Dec 11, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
BOSE 321 DVD movie movie picure is blue. Its connected to a Sony LCD digital Wide screen TV Bravia Model KDL 40V2500 and my cable box. Could it be a loose connection.
Sounds like you are using a component cable(red,green,blue) rather than an HDMI cable.
Component cables are fine to use but if one of the 3 cables is disconnected, loose or bad, you may see blue video.
Check for loose connections or bad cables and make sure the proper color is plugged into its matching color.
Oct 25, 2009 | Bose 3·2·1 II System
How to enable "Bravia Sync" on KDL-40V2500
I also have the same problem and was wondering if you ever found out the answer to this problem Peter?
Dec 18, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Periodic tv screen blackouts
The problem is your cable box. I know you said you replaced it, but I work on TV's everyday and, sorry to say this but cable box HDMI outputs have serious issues, like no or intermittent sound and video. I have seen customers exchange their cable boxes 5 and 6 times and still have the problem. Your best bet is to use the component outputs of your cable box, visually you will not see a picture difference between component and HDMI when using a cable box. Your other solution is to get satellite; I have NEVER seen an HDMI issue with a satellite box
Nov 25, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
TV not finding Digital Channels from Cable Box
I don't know where you're located but you may want to double check with Time Warner on the availibilty of an HD box. I have TWC with an HD tier package and have an HDMI out on the box that runs directly into HDMI on this TV. Hope that helps!
Jan 17, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sony Bravia 40"
Do you have a cable or satellite box connected to the tv?
Dec 31, 2007 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
No Digital Signal to TV
make sure you have Tv on that particular HDMI input .I believe video 6 or 7 .if you do check menu make sure that input is not blocked. or you might want to try the component outputs of cable box and connect that to a component input on tv to see if that is working,,i have seen these tv HDMI input board bad..lets hoe this is not the case..
Dec 16, 2007 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sony BRAVIA KDL-40V2500 40 in. LCD HDTV Logo
343 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
