Question about Refrigerators
ICE CUBE LEVEL
I HAVE A HOTPOINT FRIDGE FREEZER ON TOP. IS THERE ANY WAY CHANGE THE WATER LEVEL TO CHANGE THE SIZE OF CUBES?
    President:
  • 2,712 Answers
You could try restricting the flow of water from the water line to make smaller cubes..
Posted on Sep 28, 2008
The Ice maker has stopped working.
There are usually 2 small solenoid valves that are used to control water. Both are generally installed at the rear close to the bottom of the fridge. One of the solenoids controls the water flow for drinks and the other is to control water flow to the ice maker. You can determine which is which by tracing the water supply tubes from the freezer compartment to the solenoid or by process of elimination. The latter method requires that you feel for movement (clicking) or heat on the water dispenser solenoid while someone starts to fill a glass with water from the fridge.
Before going any further, make sure that the ice cube detection arm in the freezer is not up. Gently push the arm down if it is. When ice cubes are ready, the ice maker turns on a small heater to break the bond of the ice cubes to the cube mold. The arm is lifted up and out of the way. Then the mechanical fingers wipe or push on the cubes to dislodge them from the ice cube mold and they fall into the container. The arm is then lowered again and rests on top of the ice collected in the container. The position of the arm when resting on the ice cubes determines whether or not any more ice cubes are made.
If the arm is hanging down, then ice cube production should be on. The problem may be either a faulty solenoid valve (mentioned above), switch in the ice maker assembly - the detection arm in particular or wiring between.
Jun 18, 2010 | Maytag MFI2568AE Side by Side French Door...
How do you change the ice cube setting on the 25cf LG French Door bottom freezer? I cannot see anywere in the manual where it indicates where you change this setting?!
The icemaker requires a water pressure of 1.5 - 8.5kgf/cm2. It is acceptable if the water supply fills a cup of 180cc with water in 3 seconds. The icemaker produces small cubes if the water fed into it is not enough and lumped together if too much water is supplied. In order to obtain the desired size of ice cubes, the amount of water supplied to the ice maker needs to be adjusted. Adjust the valve supplying water to the icemaker or the unit in general in such a way that right amount of water fills the ice tray.
Nov 05, 2009 | LG LFX25960 Bottom Freezer French Door...
Water is leaking inside the refrigerator and the ice cube aren't freezing completely (cube is a hollow shell of ice)
Possibly it is because fridge is not cooling correctly(Ice cubes hollow).. Suggest proper defrost. if it is cooling partially, it shows cooling is trying to take place (Make sure before you switch on after defrost, check for proper water drainage.Water must flow to the compressor once defrosted.Take note if the fan runs correctly.
Sep 20, 2009 | Whirlpool 18.9 cu. ft. Top Freezer...
How do i get clean ice cubes from frigidare?
In order to get as clean an ice cube as possible, it all depends on the quality of the water that goes into the ice maker. If you have a water softener, your cubes will always be a bit cloudy, since the added salt slows down the freezing slightly and thus the cubes get cloudy.
That said, there are a few things you can do to improve your water. Adding a whole house water filter with a sediment charcoal filter, will remove the impurities and help to improve the overall taste. Then add an inline charcoal filter on the water line into the fridge. That will filter your water a bit more and help further improve the clarity and taste of the cubes.
Beyond that, you might want to look into a reverse osmosis system to really get the best possible tasting water you can.
The old adage of "garbage in, garbage out" is a good analagy for water quality issues, so you need to figure out what's in your water in order to take the steps to treat your water for the best possible results.
I recall that Sears offers free water testing (to help sell water softeners) so that's an option, as well as getting a home water test you can perform yourself.
Hope that helps you with your situation. Best regards!
Jul 31, 2009 | Frigidaire FRT17G4B Top Freezer...
Just got Neff ice cube, crushed ice maker and ice
Will probably find the freezer fan has failed.Push in the door switch on left hand front of freezer with the door open & you should here fan running,if not new fan required.
Jul 01, 2009 | Neff K3965XO Side by Side Refrigerator
Magic Chef Side by Side MOdel RC224RDA
I have the same problem. It turned out to be a problem with the doors. When my kids go to get a snack and close the fridge door (read slam the door) the air pressure pops the seal open on the freezer door causing the ice cubes to begin melting. The bottom items stay frozen (warm air rises). It took me a long time to work this out.
Remove the ice maker tray. Remove the ice blob, being careful to put the u-shaped wire ice-level sensing wire thing, in the up position or the system will dump ice and water all over the freezer. Put all back clean and dry and buy a velcro adhesive strip and install it on top of the freezer door to prevent the door from always blowing open.
Hope this helps
Jul 03, 2008 | Magic Chef (CSD2610KRW) Top Freezer...
Freezer burn on ice-cubes
Black mould around the freezer seal is normal if it has built up over a long period of time or has stood in damp environments. Normally hot soapy water can clear this right up. The ice taste would probably be resolved by fitting or changing the water filter, and / or cleaning the ice maker module located at the top of the freezer section and any route that the ice would take. Cleaning solutions for ice makers are available you just might need to call a local engineer for some advice on where to get some in your area. Hope this helps.
Feb 07, 2008 | Refrigerators
Refrigerators Logo
54 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
