Question about Dryers
I have a electric dryer and when I push the stsrt button the motor hums and will not start.
    President:
  • 2,712 Answers
If your dryer doesn't work at all, it could be because of problems with:
Power from the house Checkto see whether there's power getting to the dryer. Is it plugged in? Ifyou plug something else into the outlet, does it work? If not, checkfor a blown fuse or tripped circuit breaker.
Door switch Ifthe door switch or the door-switch actuator is defective, the dryerwon't work and you need to replace the failed component. The switch isinside the dryer main housing near the door frame. Sometimes you needto raise or open the top or front of the dryer to reach the switch.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, yourdryer either just stops heating, or it doesn't work at all. Be sure toinspect the venting/heating system before replacing the fuse to put thedryer back into operation. (You can't re-set this type of fuse.)
Wiring Oftenthe main wiring connection from the house, at the dryer, burns and theconnection breaks. In this has happened to your dryer, you need toreplace the power cord and the terminal block inside the dryer to whichthe wire is attached.Hope that helps! Should you have any further questions,please feel free to post them here.
P.S. - If you find that the solution/answerI provided led you to, or resulted in a fix, please close the ticket with a FixYa!rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on Sep 28, 2008
Frigidaire electric dryer. 1.5 years old, stopped turning and only hums when button is pushed
Hello
Is it a pleasant sounding hum, like the sound of a motor running? If so , probably your belt broke.If that hum goes on and on for several minutes, it's definitely belt. Bad motor or start relay, would cut out quickly. Either way ,youv'e got to pull out machine and pull off back to inspect.
Aug 18, 2011 | Frigidaire GLEQ642A Electric Dryer
Dryer does not start when I push the on button the motor hums.
If the motor continues to hum afteer letting go of the button, then it is likely a broken drum belt. If the motor hums but stops when you let go of the button, something is preventing it from turning. This could be a seized motor or a drum that is stuck, or something caught in the fan blade.
Nov 28, 2010 | Frigidaire GLER341A Electric Dryer
My neptune dryer sounds like it is going to start but then fails
sounds like a bad motor. when it hums when you push start, open the door. put a piece of tape on the door switch to hold it in. at the same time, push the start button and turn the tub with your other hand. if it starts, this only confirms it is a bad motor. the motor will need replaced. good luck. shane
Jul 01, 2009 | Maytag Neptune MDE5500AY Electric Dryer
When you push start button, it makes noise but won't start.
This is a A.C. hum that you are hearing. this is a warning sign. You are experiencing motor failure. the actual windings inside of the motor are losing their potential to hold an even current due to breakage. the shutdown is a safety feature built in the control panel to prevent electrical spark/fire.
Feb 14, 2009 | Kenmore 659 Electric Dryer
Dryer drum ot turning but start button hums like it supposed to
sounds like your motor might be stuck and the motor is sitting there trying to run until it trips out on the overload
Jan 22, 2009 | Whirlpool LER4634J Electric Dryer
DRYER WON'T START WHEN START BUTTON IS PUSHED
if its a humming than a click,,wont start for a few mintues,,than the hum again ,,your motor is shot,,,replace,,onthejob
Jan 05, 2009 | Kenmore 62872 Electric Dryer
Dryer just used it and won't restart...just hums can you help?
Hi. thanks for your question. If the dryer just hums when you push the start button, the problem could be the motor. To check lift up the top. remove the front , check the motor, ,
Jan 01, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Dryers Logo
135 people viewed this question
Top Dryers Experts
